SWAIG 101: Your Complete Guide to Voice AI Function Integration
Master SignalWire's AI Gateway with the Agents SDK - from basics to production deployment
Jon Gray
SignalWire AI Gateway (SWAIG) lets voice AI agents call backend functions in real time, bending external API calls and business logic directly into live voice conversations without brittle webhook chains. This guide explains how SWAIG works with the Agents SDK, from the @SWAIGFunction decorator and DataMaps to rich request contexts and advanced patterns, so developers can integrate external services into voice AI systems with minimal complexity.
This guide will walk through the basics of creating an AI Culinary Companion by integrating Spoonacular with a voice AI agent. Follow along in the Recipe AI Agent Github Repo
What is SWAIG?
SignalWire AI Gateway (SWAIG) allows voice AI agents to delegate tasks to your backend via HTTP POST. Think of it like CGI (Common Gateway Interface) - where a web server hands off execution to an external program using raw query strings or form-encoded data - but for AI agents.
Traditional AI function integration often looks like the Model Context Protocol (MCP): multiple services stitched together, lots of orchestration, and brittle webhook chains. It works, but it’s imperative and heavy.
The key difference? SWAIG allows you to incorporate external API calls into your AI agent conversation in real time - seamlessly, during natural voice conversations, without awkward pauses or "please hold" moments.
Why SWAIG + Agents SDK Changes Everything
Traditional voice AI architecture requires multiple services, webhook management, and complex orchestration. The SignalWire Agents SDK eliminates this complexity: the agent SDK allows you to set up these functions, set up a web server, and build complex AI agents (with POM), ALL IN A SINGLE PYTHON FILE!
Here's your complete voice AI system:
SWAIG 101: Understanding the Basics
Step 1: The @SWAIGFunction Decorator
The @SWAIGFunction decorator is your gateway to real-time API integration. Here's how our recipe agent example demonstrates the pattern:
Key Elements:
  • name: How the AI identifies the function
  • description: Tells the AI when to use this function
  • Parameters: Automatically parsed from voice input
  • Type hints: Enable automatic validation
Step 2: DataMaps for Declarative API Integration
The DataMap system handles API calls declaratively. Instead of imperative code with error handling, you describe what you want:
DataMap handles automatically:
  • HTTP request formatting
  • Parameter substitution (${variable} syntax)
  • JSON response parsing
  • Error handling and retries
  • Response transformation
Step 3: Understanding SWAIG Request Context
SWAIG requests include rich context: The function name (e.g., "search_movie"), Parsed arguments in the structured argument.parsed field, The full argument schema (argument_desc) to describe expected inputs, Session, caller, and project context so you can make smart decisions without additional lookups
This rich context enables powerful patterns like automatic authentication using caller ID.
Advanced SWAIG Patterns
Custom Logic with SwaigFunctionResult
For complex business logic beyond simple API calls, use custom SWAIG functions with the SwaigFunctionResult class:
SwaigFunctionResult enables:
  • Natural language responses for the AI to speak
  • Action data for conversation state management
  • Complex response orchestration
Error Handling and Graceful Degradation
Production SWAIG functions handle failures elegantly:
State Management Across Conversations
SWAIG functions can persist data across phone calls using the built-in state management:
Universal SWAIG Patterns
The beauty of SWAIG? This pattern works with ANY API. Swap out Spoonacular for:
  • E-commerce: Product searches and inventory checks
  • Travel: Flight prices and hotel availability
  • Finance: Stock quotes and account balances
  • Healthcare: Appointment scheduling and prescription refills
  • Real Estate: Property listings and market data
  • Customer Service: Account lookups and order status (using caller ID for automatic authentication)
Need authenticated APIs? SWAIG handles that too. The rich context includes caller information, so you can automatically authenticate users and access their personal data without asking them to recite account numbers over the phone.
Integrating with the Agents SDK
Setting Up Your Agent Foundation
The AgentBase class provides the foundation for creating AI-powered agents using the SignalWire AI Agent SDK. It extends the SignalWire Markup Language (SWML) Service class, inheriting all its SWML document creation and serving capabilities, while adding AI-specific functionality
Configuring AI Behavior with POM
The Prompt Object Model (POM) structures AI behavior configuration:
Context-Aware Function Availability
Define which SWAIG functions are available in different conversation contexts:
SWAIG Best Practices
1. Function Design Principles
  • Single responsibility: Each SWAIG function should do one thing well
  • Clear descriptions: Help the AI understand when to call your function
  • Sensible defaults: Use optional parameters with reasonable defaults
  • Error handling: Always handle API failures gracefully
2. DataMap Optimization
3. State Management Strategy
  • Use session state for conversation-specific data
  • Use global state for shared/cached data
  • Implement state cleanup for expired data
  • Consider state size limits for performance
4. Voice-Optimized Responses
Production Deployment Guide
Environment Configuration
Set up your environment variables:
Single File Deployment
The AgentBase class automatically handles deployment environments:
Automatic environment detection:
  • Local development: Starts web server
  • AWS Lambda: Configures as Lambda handler
  • Docker: Handles containerization
  • Cloud Functions: Adapts automatically
Testing Your SWAIG Functions
Test individual functions during development:
Common SWAIG Patterns and Examples
Pattern 1: Simple API Integration
Pattern 2: Multi-Step Business Logic
Pattern 3: Authenticated User Data
Troubleshooting Common Issues
DataMap Parameter Problems
Missing Error Handling
State Management Issues
Next Steps: Building Your SWAIG Application
1. Start with the Recipe Agent
Clone and explore the complete recipe agent implementation to understand all SWAIG patterns in context.
2. Study the Documentation
3. Explore More Examples
4. Build Your First Agent
Follow these steps to get your SWAIG agent running:
Step 1: Set Up Your Python Environment
Step 2: Get Your API Keys
Step 3: Run Your Agent Server
Step 4: Expose Your Local Server. Install ngrok and expose your local server to the internet:
Copy the public URL (e.g., https://983f-93-41-16-193.ngro...)
Step 5: Configure Your Phone Number
  • Buy a phone number in SignalWire Dashboard
  • Create a new Resource → Script → SWML type
  • Set to "External URL" and input your ngrok URL
  • Test by calling your number!
Detailed setup instructions: Handle incoming calls from code
Welcome to SWAIG development—where enterprise voice AI becomes as simple as writing Python functions, and your biggest architectural decision is choosing meaningful function names.
Ready to dive deeper? The recipe agent demonstrates every pattern covered in this guide. Use it as your foundation for building sophisticated voice AI applications with SWAIG and the SignalWire Agents SDK.
What is SignalWire AI Gateway (SWAIG)?
SignalWire AI Gateway (SWAIG) is a system that enables AI voice agents to integrate real-time external API calls into voice conversations, avoiding complex webhook orchestration.
How does the @SWAIGFunction decorator work?
The @SWAIGFunction decorator tells the AI how to identify a function, describes when to use it, and lets the agent call it with structured parameters.
What are DataMaps in SWAIG?
DataMaps let developers describe API requests declaratively, handling parameter substitution, HTTP formatting, response parsing, and error handling automatically.
What context does a SWAIG request include?
A SWAIG request includes the function name, parsed arguments, full argument schema, session info, caller data, and project context, enabling smart decisions without extra lookups.
What are some advanced SWAIG patterns?
Advanced patterns include custom logic via SwaigFunctionResult, graceful error handling, session-wide state management, and authenticated API access, all usable in production voice AI.
