Browser SDK Web Components
The Browser SDK contains a suite of flexible web components that can be used to create UI.
Install
npm install @signalwire/web-components@latest
Or load from a CDN:
<script type="module" src="https://unpkg.com/@signalwire/web-components"></script>
Components
Ready-to-use call UI elements. Most components consume context from a parent <sw-call-provider> (or <sw-call-media>) automatically.
ComponentDescription
<sw-audio-level>Real-time audio level visualizer — animated bar graph
<sw-call-controls>Mute audio, mute video, screen share, and hangup buttons
<sw-call-dialpad>Context-aware DTMF dialpad — sends tones to the active call or bubbles a sw-dial event
<sw-call-media>Remote video container and root context provider — wrap call components inside it
<sw-call-provider>Top-level context provider that bridges an external Call and DeviceController into Lit context
<sw-call-status>Displays call state label and elapsed duration timer
<sw-call-widget>All-in-one call widget — handles client init, dialing, media, controls, and optional AI transcript
<sw-click-to-call>Single-button widget that dials on click and shows mute/hangup once connected
<sw-device-selector>Drop-up buttons for microphone, camera, and speaker selection with optional live preview
<sw-directory>Searchable contact list with dial actions from the SDK directory
<sw-local-camera>Local camera preview with a muted overlay
<sw-participant-controls>Per-participant moderation controls: mute, video mute, remove, volume, pin
<sw-participants>Renders positioned overlays for each remote participant
<sw-self-media>Local video preview — consumes callContext from a parent <sw-call-media>
UI Primitives
Low-level layout and control components used to build custom interfaces. These are presentational and do not couple to the SDK.
<sw-ui-alert>Confirm / alert dialog primitive — use directly or via the showPrompt() helper
<sw-ui-background>Decorative full-bleed background that crossfades from a blurred thumbnail to a hi-res image
<sw-ui-call-layout>Fluid call layout — splits into video + transcript based on container aspect ratio
<sw-ui-content-drawer>Slide-in drawer for agent-pushed content (markdown, HTML, snippets) mid-call
<sw-ui-control-bar>Call controls bar: mic, camera, speaker, screen share, hand raise, transcript, fullscreen, hang-up
<sw-ui-dialpad>Presentational 12-key DTMF keypad — pure UI, no SDK coupling
<sw-ui-dropup>Tiny pop-up menu that opens above its anchor and closes on outside click
<sw-ui-icon>Inline SVG icon component backed by the bundled icon set
<sw-ui-modal>Native <dialog> wrapper with bounce-in/out animations and body scroll lock
<sw-ui-responsive-container>Aspect-ratio-aware sizing wrapper for hosting call surfaces inside a modal
<sw-ui-split-button>Pill-shaped icon button with optional chevron dropdown — atomic block for control bars
<sw-ui-transcript-view>Chat-bubble timeline rendering AI transcript entries with rich meta payloads
