SelfParticipant
SelfParticipant is the local user’s view of themselves on a call. It extends Participant — inheriting every remote-side observable and control method — and adds the local-only surface area: device selection, screen sharing, the local MediaStream, and the per-call SelfCapabilities that gate which controls the server allows. Instances are created by the call on join and obtainable via call.self$.
Device-related methods (selectAudio*, selectVideo*, addAudioInputDevice, disableVideoInput, etc.) update the local capture and renegotiate the peer connection automatically. Screen-share methods (startScreenShare, stopScreenShare) acquire a getDisplayMedia track, publish it to the call, and update screenShareStatus$ accordingly. Media-processing toggles (setAutoGainControl, setEchoCancellation, setNoiseSuppression) modify the active audio track in place.
For checking whether a given action is permitted before exposing it in the UI, read capabilities (the underlying SelfCapabilities instance, which itself exposes each capability as both a snapshot and an observable).
Extends
Implements
Properties
capabilities
SelfCapabilities
Capabilities for this participant. Contains all capability flags as both observables and values.
id
stringRequired
Unique member ID of this participant.
Accessors
addressId$
Observable of the participant’s address ID.
audioMuted$
Observable indicating whether the participant’s audio is muted.
autoGain$
Observable indicating whether auto-gain control is enabled.
callId
Call ID for this participant’s leg, or undefined if not available.
deaf$
Observable indicating whether the participant is deafened.
denoise$
Observable indicating whether noise reduction is active.
destroyed$
Observable that emits when the instance is destroyed
echoCancellation$
Observable indicating whether echo cancellation is enabled.
handraised$
Observable indicating whether the participant has raised their hand.
inputSensitivity$
Observable of the conference-only microphone energy/gate sensitivity level for this member.
inputVolume$
Observable of the participant’s server-side microphone input volume as reported by the mix engine.
isTalking$
Observable indicating whether the participant is currently speaking.
lowbitrate$
Observable indicating whether low-bitrate mode is active.
meta$
Observable of custom metadata for this participant.
name$
Observable of the participant’s display name.
nodeId$
Observable of the server node ID for this participant.
noiseSuppression$
Observable indicating whether noise suppression is enabled.
outputVolume$
Observable of the participant’s server-side speaker output volume as reported by the mix engine (FreeSWITCH channel write volume).
position$
Observable of the participant’s layout position.
screenShareStatus$
Observable of the current screen share status.
studioAudio$
Observable indicating whether studio audio (raw/unprocessed audio) mode is enabled.
target
The member’s own RPC target triple. Throws ParticipantNotReadyError until the member’s call context has been received.
type$
Observable of the participant type (e.g. 'member', 'screen').
userId$
Observable of the participant’s user ID.
videoMuted$
Observable indicating whether the participant’s video is muted.
visible$
Observable indicating whether the participant is visible in the layout.
Methods
addAdditionalDevice
Adds an additional media input device to the call.
addAudioInputDevice
Adds or replaces the primary audio input device with optional constraints or stream.
addInputDevices
Adds or replaces primary input devices (audio and/or video).
addVideoInputDevice
Adds or replaces the primary video input device with optional constraints or stream.
destroy
Destroys the participant, releasing all subscriptions and references.
disableStudioAudio
Disables studio audio mode by restoring all audio processing to enabled. Sets echoCancellation, noiseSuppression, and autoGainControl to true.
enableStudioAudio
Enables studio audio mode by disabling all audio processing. Sets echoCancellation, noiseSuppression, and autoGainControl to false.
end
Ends the call for this participant.
mute
Mutes local audio. Falls back to local device mute if the server RPC fails.
muteVideo
Mutes local video. Falls back to local device mute if the server RPC fails.
remove
Removes this participant from the call.
removeAdditionalDevice
Removes an additional media input device by ID.
selectAudioInputDevice
Selects the audio input device for future calls. Optionally saves as a preference.
selectAudioOutputDevice
Selects the audio output device. Optionally saves as a preference.
selectVideoInputDevice
Selects the video input device for future calls. Optionally saves as a preference.
setAudioInputDeviceConstraints
Updates the audio input track constraints for the active call.
setAudioInputSensitivity
Adjusts the conference-only microphone energy gate / sensitivity level for this member.
setAudioInputVolume
Sets the server-side microphone volume on this participant’s bridged call leg.
setAudioOutputVolume
Sets the server-side speaker volume on this participant’s bridged call leg (FreeSWITCH channel write volume) — what this participant hears from the mix before it reaches their client.
setInputDevicesConstraints
Updates both audio and video input track constraints for the active call.
setMeta
Replaces custom metadata for this participant.
setPosition
Sets the participant’s position in the video layout.
setVideoInputDeviceConstraints
Updates the video input track constraints for the active call.
startScreenShare
Starts sharing the local screen.
stopScreenShare
Stops the current screen share.
toggleAudioInputAutoGain
Toggles automatic gain control. Exits studio mode if active.
toggleDeaf
Toggles the deafened state (mutes/unmutes incoming audio).
toggleEchoCancellation
Toggles echo cancellation. Exits studio mode if active.
toggleHandraise
Toggles the hand-raised state.
toggleLowbitrate
Participant.toggleLowbitrate
toggleMute
Toggles the participant’s audio mute state.
toggleMuteVideo
Toggles the participant’s video mute state.
toggleNoiseSuppression
Toggles noise suppression. Exits studio mode if active.
unmute
Unmutes local audio. Falls back to local device unmute if the server RPC fails.
unmuteVideo
Unmutes local video. Falls back to local device unmute if the server RPC fails.
updateMeta
Merges values into custom metadata (unlike setMeta which replaces).
