The Best Way to Use SignalWire for SIP Trunking with Asterisk or FreePBX
Asterisk/FreePBX and SignalWire: PJSIP is best
Modern SIP trunk providers can deliver inbound calls from multiple IP addresses due to elastic infrastructure, which breaks older Asterisk and FreePBX configurations that identify providers by a single source IP. This article explains why inbound calls can be misclassified or rejected when using chan_sip, and why Asterisk’s PJSIP stack is the most reliable approach for SignalWire SIP trunking, including how to identify inbound calls by domain instead of IP and route them correctly by extracting the dialed number from SIP headers.
Why Inbound SignalWire Trunk Calls Can Fail in Asterisk and FreePBX
If you are using (or want to use) SignalWire for SIP trunking with Asterisk or FreePBX, then you will get the best results on inbound calls with PJSIP.
According to Asterisk:
“PJSIP is the future of SIP in Asterisk, and has been available since Asterisk 12. As of the release of Asterisk 17, chan_sip has been marked as deprecated, and will receive no further development work.”
A good number of Asterisk and FreePBX users are connecting with SignalWire to take advantage of our highly disruptive pricing for SIP connectivity and US and Canadian DIDs. When your Asterisk or FreePBX registers to SignalWire to receive inbound calls, those calls will arrive from a number of different IP addresses, not just the one your Asterisk registered to.
This is not uncommon with modern SIP providers, and is a product of our elastic infrastructure.
This is, however, an issue for Asterisk’s older SIP channel, chan_sip, but people continue to use it.
Why chan_sip misidentifies inbound trunk calls
In chan_sip there are two types of SIP connections. One is called a ‘user’ and the other is called a ‘peer’. You may be thinking about ‘type=friend’. That simply means that the SIP connection in question can be seen as a user or a peer at any given point in time.
Generally speaking, we tend to think of a user sending calls to Asterisk and a peer accepting calls from Asterisk, but this is not strictly true, as peers can also send calls to Asterisk.
One of the differences between users and peers is the way that they authenticate with Asterisk:
  • Peers are authenticated by IP address
  • Users are authenticated by username and password/secret
This is where issues can arise, as when a SIP call comes into Asterisk, it first tries to match it to any Peer profiles it has (based on IP address), so calls that arrive from IP addresses other than the *single IP address* that Asterisk has associated with SignalWire will be counted as unrecognized.
One could, in theory, create a SIP peer profile in Asterisk for every single IP address that SignalWire may send calls from. But that is highly impractical as new IP addresses could be introduced at any point in time.
Once an inbound call has been checked against Asterisk’s list of peers, it will then try matching against any user profiles it has. And there is a problem here too: SignalWire is not expecting to be challenged for a username and password as it delivers the calls, and therefore does not respond to such a challenge from Asterisk.
So chan_sip in Asterisk is just not very good at recognizing incoming calls from SignalWire (or any other SIP provider that sends calls from multiple IP addresses).
The way around this is to set up the default context that Asterisk will send inbound calls into to process calls that come from SignalWire, and that will include obtaining the dialed number from within the SIP header.
Why PJSIP is the best option for SignalWire SIP trunking
The best thing to do would be to use PJSIP in Asterisk. This is because PJSIP gives you the opportunity to set an AOR profile with a SIP domain, and this provides a way to identify any inbound calls from that SIP domain as being from SignalWire, and then direct them into the appropriate context.
You will still need to extract the dialed number from the SIP header for routing purposes.
Have more questions about building with SignalWire? Bring them to our team and community on Discord.
Why does my Asterisk or FreePBX trunk reject inbound calls from SignalWire?
Inbound calls may arrive from multiple IP addresses, and older configurations that identify a provider by a single source IP can treat those calls as unrecognized, especially when using chan_sip.
Why is PJSIP recommended over chan_sip for SIP trunking?
Asterisk has deprecated chan_sip and PJSIP supports more flexible identification and routing patterns, including matching calls using SIP domain concepts instead of relying on a single provider IP.
Do SIP trunk providers always send calls from the same IP address?
Not necessarily. Modern providers can send calls from multiple IPs due to elastic infrastructure and routing changes, so configurations that assume a single inbound IP can break.
How do I route inbound trunk calls if I cannot match by source IP?
A common approach is to route inbound calls based on SIP headers that indicate the dialed number, and to identify the trunk using a stable domain identifier instead of source IP.
Can I make chan_sip work anyway?
There are workarounds, but they are brittle because new provider IPs can appear over time, and the provider may not respond to inbound authentication challenges the way chan_sip expects.
