Reduce Call Volume with SMS-Enabled Automatic Callbacks
Cut hold times with this pre-built SMS enabled callback feature
Abbi Minessale Headshot
Abbi Minessale
Senior Product Marketing Manager
An SMS-enabled callback flow reduces call volume and hold times by letting customers request a callback without waiting on hold. This guide shows how to build a simple system where texting a number adds a caller to a callback queue, and calling the number offers an option to request a callback by text. It includes the endpoints you need to receive inbound SMS and calls, place callers in a queue, and trigger a callback when an agent is available, plus instructions to run the example in Python or Docker.
As instrumental businesses are facing alarmingly high call volumes that they’re not used to, the calls are sometimes so frequent that many people can’t even get through.
Canadian airline WestJet has a 10 hour call waiting time for customers looking to change their travel plans. Over 16 million people in the US have been filing for unemployment and the odds of ever reaching a human representative are very low. Most calls drop before getting to an IVR and those who make it through are told to call back later because no representatives are available. Madison, Wisconsin’s Department of Workforce Development has seen over 1.5 million calls in a single week; that’s 160 calls per second at a 6,208% call volume increase. Banks are also sporting much higher wait times than usual. One Citigroup Inc. customer found themselves on hold for 3 hours and never got to talk to a representative.
So how can we help?
Of course, part of the problem is a lack of human representatives to answer the phone but that doesn’t mean customers need to be waiting on hold for hours. There are a few useful callback features that can help businesses in a crisis handle call volume and we’re going to show you how to implement them into your own call center.
A callback feature is as simple as it sounds. Callers are given an option to be placed in a queue, and can hang up and receive an automatic callback when a representative is free instead of having them waiting on hold for hours. Adding a callback feature to your IVR is one way to make sure that your lines aren’t overwhelmed with people waiting to get through to an agent and saves your customers valuable time. SMS integration takes this a step further, allowing customers to request a callback via text without ever having to make an initial call.
With SignalWire, you can integrate SMS to free up phone lines. When customers text your business number, they can text with your system to figure out which department to speak to and get added to the callback list without ever having to make an initial call. That way there are no robots to talk to, no waiting on hold, and no overwhelming your phone lines.
Below, we will show you how to add this feature to your own system. The snippet itself is hosted here. Want to try it out? We have a demo hosted with phone number: +1 (864) 936-1337. Simply call or text to see how it works!
Getting started
So how does everything work? If you text the provisioned phone number, it will add your number to a queue to be called back. If you call the provisioned number, it will put you in a queue, and then if you press 1 it will send you a text, and hangup. It will then call you back when it is your turn.
Please note: for this demo, the call backs are driven by timers to give an idea of how it works.
You will need a machine with Python installed, the SignalWire SDK, a provisioned SignalWire phone number, and Docker if you decide to run it in a container.
Running the snippet
Methods and endpoints:
Endpoint: /text_request_call
Methods: GET OR POST
Endpoint to accept incoming text messages from SignalWire space.
Endpoint: /enter_queue
Endpoint to place callers into queue.
Endpoint: /wait_url
Endpoint to handle people on hold in queue.
Endpoint: /request_callback
Endpoint to process request call back.
Endpoint: /connect_agent
Endpoint to connect agent to caller
Endpoint: /wait_url
Endpoint: /wait_url
Endpoint: /wait_url
Set up environment file:
  2. Save new file callled .env
## This is the full name of your SignalWire Space. e.g.: <a target="_blank" delay="150" aria-describedby="slack-kit-tooltip" href="http://example.signalwire.com/" rel="noopener noreferrer">example.signalwire.com</a>
SIGNALWIRE_SPACE=
SIGNALWIRE_PROJECT=
#Your API token - you can generate one on the `API` page in your Dashboard
SIGNALWIRE_TOKEN=
# The phone number you'll be using for this Signal. Must include the `+1` , e.g.: <a target="_blank" delay="150" aria-describedby="slack-kit-tooltip" href="tel:+15551234567" rel="noopener noreferrer">+15551234567</a>
SIGNALWIRE_SPACE=
SIGNALWIRE_PROJECT=
SIGNALWIRE_TOKEN=
SIGNALWIRE_SPACE=
SIGNALWIRE_PROJECT=
SIGNALWIRE_TOKEN=
SIGNALWIRE_SPACE=
SIGNALWIRE_PROJECT=
SIGNALWIRE_TOKEN=
Build and run on Docker:
Use our pre-built image from Docker Hub:
For Python:
docker pull signalwire/snippets-queue-request-callback:python
For Python:
For Python:
For Python:
Or build your own image:
docker build -t snippets-queue-request-callback
Run your image:
docker run --publish 5000:5000 --env-file .env snippets-queue-request-callback
Build and run natively for Python:
1. Replace enviroment variables
Try it out!
All you need to do to get started is sign up for a space.
Still have questions? Reach out to our 24/7 live support team on our Discord community.
What is an SMS-enabled callback feature?
An SMS-enabled callback feature lets customers request a callback by text, or request one during a call, so they can hang up instead of waiting on hold, then receive an automatic callback when it is their turn.
How does an SMS callback reduce call volume and hold times?
Instead of keeping callers connected in a hold queue, callers can request a callback and disconnect. That reduces the number of active calls waiting for an agent and improves the customer experience by eliminating long hold times.
How does the callback flow work at a high level?
If a customer texts the provisioned phone number, their number is added to a queue to be called back. If a customer calls the number, they are placed into a queue and can press 1 to receive a text and hang up, then the system calls them back when it is their turn.
