Multi-factor Authentication with SignalWire
User guide to building MFA
Luca Pradovera
Multi-Factor Authentication (MFA) verifies a user by sending a short secret token over Short Message Service (SMS) or a voice call, then confirming the token they enter. This guide explains how to use SignalWire’s Multi-Factor Authentication API to request a token via SMS or voice using Representational State Transfer (REST) Hypertext Transfer Protocol (HTTP) calls, which parameters control token length, expiration, attempts, and message content, and how to verify a token using the interaction ID returned by the request endpoint.
How to Build Multi-Factor Authentication Applications with SignalWire
Multi-factor authentication (MFA) is used to authenticate users of an application through the use of a secret token that is sent to them over SMS text or a voice call. It is commonly used for logging in to secure systems, but it is also gaining popularity as a one-time password (OTP) mechanism to authorize transactions or to sign documents and contracts.
SignalWire's multi-factor authentication API provides a simple and secure flow to request and verify tokens via REST HTTP calls.
Requesting a token via SMS
To request a token via SMS, the API requires a to parameter as the minimal payload to be sent in a CURL request to the /api/relay/rest/mfa/sms endpoint.
curl https://your-space.signalwire.com/api/relay/rest/mfa/sms \
-X POST \
-u 'YourProjectID:YourAuthToken' \
 -H 'Content-Type: application/json' \
-d '{
 "to": "+15557788999"
This request will result in a message being delivered with Your Personal Authorization Code is XXXXXX.
If using SMS, you have the option of using SignalWire's outbound number which is already registered with the Campaign Registry. That way, you will not have to do your own registration. In case you would like to use a non-standard message parameter, however, you will need to provide your own from number, as SignalWire is only able to send the pre-approved text via its registered route.
Requesting a token via voice
To request a token via voice call, again supply a to parameter as the minimal payload to be sent in a CURL request to the /api/relay/rest/mfa/call endpoint.
curl https://your-space.signalwire.com/api/relay/rest/mfa/call \
-X POST \
 -d '{
The above will place a call to the to number and read Your Personal Authorization Code is XXXXXX via text-to-speech to them.
Optional parameters
There are a few parameters you can use to control the interaction and customize the API to your workflow.
  • to: The E164 number to use as the destination (and only mandatory parameter).
  • from: The E164 number from your account to use as the origin of the message. Campaign registry practices apply to this if using SMS.
  • message: The message to read or send to the caller. The message must fit within one segment of 160 characters on sms (70 characters when using non-GSM symbols) if using SMS, or 500 characters including the token if using voice. Defaults to "Your Personal Authorization Code is:".
  • token_length: The number of characters in the token, from 4 to 20. Defaults to 6.
  • max_attempts: The number of allowed tries, including the first one, from 1 to 20. Defaults to 3.
  • allow_alphas: Set to true or false, whether to include letters or just numbers in the token. Defaults to false (numbers only).
  • valid_for: The number of seconds the token is considered valid for. Defaults to 3600, with a maximum of 604800 and a minimum of 0.
For example, the following CURL requests a token via SMS, specifying a from number, a custom message, allowing letters in the code, and asking for an eight-character token. It also sets validity to two hours and allows for four retry attempts.
-X POST \
 -d '{
 "to": "+15557788999",
 "from": "+5554433222",
 "message": "Here is your code: ",
 "allow_alpha": true,
 "token_length": 8,
 "valid_for": 7200,
 "max_attempts": 4
Verifying a token
No matter which method you use to request the token, the application making the request will receive a JSON response similar to the following:
 "id":"8630cc54-f6b2-45dd-b73b-cce28eb668d8",
 "success":true,
 "to":"+15557788999",
 "channel":"call"
The most important data in that JSON is the id field, which you need to save and use for the verification step. After the request, your user will have received the secret token over the chosen channel. Your application should present them with a way to input their code, and then use the verify endpoint to check the token.
Using the ID above, your request would look like the following. Note that the interaction ID is passed in via the URL.
curl https://your-space.signalwire.com/api/relay/rest/mfa/8630cc54-f6b2-45dd-b73b-cce28eb668d8/verify \
-X POST \
 -d '{
 "token": "<TOKEN-TO-CHECK>"
The response will be a simple JSON payload with a success boolean value.
 "success": true
Possible return values
The verify endpoint will return "success": false only if the token is actually wrong in respect to the interaction ID passed in.
It will return an HTTP code 404 Not Found in the following cases:
  • The interaction ID is incorrect
  • The token has already been verified successfully once
  • The maximum number of attempts has been reached
  • The valid_for time has been exceeded and the token has expired
Sign up for a SignalWire account
Sign up for a SignalWire account here. It includes $5.00 of free credit to get you started.
Your account will be made in trial mode, which you can exit by making a manual top up of $5.00.
Please feel free to reach out to us on our Community Discord if you need guidance!
Frequently Asked Questions
What is Multi-Factor Authentication (MFA)?
Multi-Factor Authentication (MFA) authenticates a user by sending a secret token over SMS text or a voice call, then requiring the user to enter that token to confirm their identity.
How does SignalWire’s Multi-Factor Authentication API work?
An application requests a token from SignalWire over REST HTTP, SignalWire delivers the token to the destination phone number over SMS or a voice call, then the application verifies the token by calling the verify endpoint using the interaction ID from the original request.
How do you request an MFA token via SMS?
Send a POST request to the /api/relay/rest/mfa/sms endpoint with a to parameter set to the destination phone number. SignalWire sends a token message, using a default message format unless you customize it.
How do you request an MFA token via voice call?
Send a POST request to the /api/relay/rest/mfa/call endpoint with a to parameter. SignalWire places a call to the destination number and reads the token using text-to-speech.
Which parameters control token length, expiration, and retry attempts?
Common controls include token_length (default 6), valid_for (seconds until expiration), and max_attempts (how many tries are allowed). You can also set allow_alphas to include letters, and customize message and from depending on channel and compliance constraints.
How do you verify an MFA token, and what failures can occur?
The request response includes an id you must store. Verify by POSTing the token to /api/relay/rest/mfa/{id}/verify. Verification returns success: false when the token does not match the interaction ID. The API can also return HTTP 404 if the interaction ID is invalid, the token was already verified, the maximum attempts were used, or the token expired.
