How to Send Text Messages to an Email Address
How to generate email output from SMS input
Forwarding SMS messages to email lets developers bridge mobile messaging with existing inbox-based workflows. Using SignalWire’s Messaging API, inbound SMS can be received via webhooks, processed programmatically, and delivered as emails through standard mail providers. This pattern is commonly used for alerts, support notifications, logging, and automation, allowing teams to react to text messages without building a custom UI or monitoring dashboards.
How to Send Text to Email with SignalWire
Sending SMS messages that automatically convert into email notifications is a powerful pattern for alerting, logging, or automating workflows without a dedicated UI. Whether you want to notify a team when certain keywords are texted in, forward customer replies to support inboxes, or build an SMS-to-email gateway, this article shows how to build that with SignalWire’s Messaging APIs and a mail delivery service like Mailgun.
What you’ll learn
  1. Why you might forward SMS to email
  2. How SMS-to-email gateways work
  3. A secure sample implementation using Python plus SignalWire
  4. How to run in Docker (optional)
  5. Best practices for production use
What you need before you start
Before diving into code, make sure you have:
  • A SignalWire project with Messaging API enabled
  • A SignalWire SMS-capable phone number
  • A mail delivery provider (e.g., Mailgun, SendGrid, SES)
  • Python 3.x installed
  • Optionally, Docker for containerized running
How SMS to email works
At a high level:
  1. A user sends an SMS to your SignalWire number.
  2. SignalWire receives the message webhook.
  3. Your webhook handler reads SMS content and metadata.
  4. Your server forwards that message as an email via an email API.
  5. The destination email address receives the content instantly.
This pattern bridges cellular messaging and email delivery without manual steps.
Methods and endpoints
Endpoint: /sms-webhook
Methods: GET OR POST
Endpoint to accept incoming text messages from SignalWire space and forward them to MailGun.
Set up your environment file
  2. Save new file called .env
SIGNALWIRE_SPACE=
SIGNALWIRE_PROJECT=
SIGNALWIRE_TOKEN=
SIGNALWIRE_NUMBER=
MAILGUN_DOMAIN=
MAILGUN_API_TOKEN=
# Send Email From Address
# Send email to address for administrator notifications
# Email subject for admin notifications
EMAIL_SUBJECT=Forward Text To Email
Build and run on docker
Use our pre-built image from Docker Hub:
For Python:
docker pull signalwire/snippets-text-to-email:python
Or build your own image:
docker build -t snippets-text-to-email .
Run your image:
docker run --publish 5000:5000 --env-file .env snippets-text-to-email
Build and run natively
For Python:
1. Replace enviroment variables
Best practices
  • Validate input: Only forward trusted SMS from expected numbers.
  • Security: Protect your webhook endpoint with tokens or signatures.
  • Retries: Use background jobs and queues for robust email delivery.
  • Compliance: Respect SMS opt-in, TCPA, and other messaging laws.
  • Error monitoring: Log send statuses and API failures.
Common use cases
  • Alerting ops teams when a keyword is received
  • Creating tickets in helpdesk systems from SMS replies
  • Notifying administrators of inbound messages in real time
  • Automating logging and audit trails for SMS conversations
Support
If you have any issues or want to engage further about this snippet, join our fantastic Discord community and chat with others in the SignalWire community!
How do I send text messages to email?
To send a text message to an email address, you need a programmable SMS number and a webhook that receives inbound messages. When someone texts your number, the webhook captures the message content and metadata, and your application forwards it as an email through a mail delivery service like Mailgun or SendGrid. SignalWire's Messaging API handles the inbound SMS side, while your server receives the webhook, reads the SMS content, and sends it to any email address you configure.
Can I forward MMS to email too?
Yes. MMS includes media attachments; you can download the media URLs from the webhook and attach them to the email via your email API.
Do I need a special number for forwarding SMS to email?
Any SMS-enabled number from SignalWire will work. Dedicated long numbers or toll-free numbers minimize carrier filtering.
How do I handle replies from email back to SMS?
You can parse incoming email (e.g., via webhook) and use SignalWire’s Messaging API to send a reply SMS.
