Snippet: Text to Email
We'll take a regular SMS text message as the input and generate an email as the output!
Applications of this code could be as simple as a 'note to self' or as broad as a gateway for emailing certain people as part of a text-based advertising campaign.
You will need a machine with Python installed, the SignalWire SDK, a provisioned SignalWire phone number, and optionally Docker if you decide to run it in a container.
For this demo, we will be using Python, but more languages may become available.
  • Python
  • SignalWire SDK
  • SignalWire Phone Number
  • MailGun Account (For administrator notifications, https://www.mailgun.com/)
  • Docker (Optional)
Methods and Endpoints
Endpoint: /sms-webhook
Methods: GET OR POST
Endpoint to accept incoming text messages from SignalWire space and forward them to MailGun.
Setup Your Environment File
  2. Save new file called .env
SIGNALWIRE_SPACE=
SIGNALWIRE_PROJECT=
SIGNALWIRE_TOKEN=
SIGNALWIRE_NUMBER=
MAILGUN_DOMAIN=
MAILGUN_API_TOKEN=
# Send Email From Address
# Send email to address for administrator notifications
# Email subject for admin notifications
EMAIL_SUBJECT=Forward Text To Email
Build and Run on Docker
Let's get started!
For Python:
docker pull signalwire/snippets-text-to-email:python
  • Or build your own image:
docker build -t snippets-text-to-email .
  • Run your image:
docker run --publish 5000:5000 --env-file .env snippets-text-to-email
Build and Run Natively
For Python:
More Documentation
Support
