Snippet: Voicemail Transcription
This snippet will show you how to implement a transcription process for a recorded voicemail message. The resulting text will be emailed to the given address.
You will need a machine with Python installed, the SignalWire SDK, a provisioned SignalWire phone number, and optionally Docker if you decide to run it in a container.
  • Python
  • SignalWire SDK
  • SignalWire Phone Number
  • MailGun Account (For administrator notifications, https://www.mailgun.com/)
  • Docker (Optional)
How this Voicemail Transcription application works
We are going to build off of our Simple IVR Menu, and add ring groups
Methods and Endpoints
Endpoint: /voice_entry
Methods: GET OR POST
Handles incoming voice requests
Endpoint: /transcribe_webhook
Processes the transcription actions, i.e Sending Email.
Endpoint: /recording_webhook
Provided for informational purposes, if you would like to see the recording status information.
Endpoint: /hangup
Handles voice hangup.
Setup Your Environment File
  2. Save new file called .env
MAILGUN_DOMAIN=
MAILGUN_API_TOKEN=
EMAIL_FROM=
EMAIL_TO=
EMAIL_SUBJECT=Voicemail Transcription
Build and Run on Docker
Let's get started!
For Python:
docker pull signalwire/snippets-voicemail-transcription:latest
  • Or build your own image:
docker build -t snippets-voicemail-transcription .
  • Run your image:
docker run --publish 5000:5000 --env-file .env snippets-voicemail-transcription
Build and Run Natively
For Python:
More Documentation
Support
