Snippet: Voice Two Factor Authentication
This snippet will show you how to implement basic two factor authentication via a voice call, creating an authentication request from your application, and presenting a challenge via voice phone call that can be verified by a Web API call.
  • Python
  • SignalWire SDK
  • SignalWire Phone Number
  • Docker (Optional)
Methods and Endpoints
Endpoint: /request-auth
Methods: GET OR POST
Request a challenge session, GET or POST 'number' to create a voice challenge session.
Endpoint: /validate-auth
Validate a voice challenge session, GET or POST 'number' and 'auth_code' to vaidate.
Will return 200 (OK) or 403 (Forbidden)
Setup Your Environment File
  2. Save new file called .env
SIGNALWIRE_SPACE=
SIGNALWIRE_PROJECT=
SIGNALWIRE_TOKEN=
# The phone number you'll be using for this Snippet. Must include the `+1` , e.g.: +15551234567
SIGNALWIRE_NUMBER=
# Hostname
HOSTNAME=
Build and Run on Docker
Let's get started!
For Python:
docker pull signalwire/snippets-voice-two-factor-auth:python
  • Or build your own image:
docker build -t snippets-voice-two-factor-auth .
  • Run your image:
docker run --publish 5000:5000 --env-file .env snippets-voice-two-factor-auth
Build and Run Natively
For Python:
More Documentation
Support
