Snippet: Text Two Factor Authentication
This snippet will show you how to implement basic two factor authentication via an text message, creating an authentication request from your application, and presenting a challenge via text message that can be verified by a web call.
  • Python
  • SignalWire SDK
  • SignalWire Phone Number
  • Docker (Optional)
Methods and Endpoints
Endpoint: /request-auth
Methods: GET OR POST
Request a text challenge session, GET or POST 'number' to create a challenge session.
Endpoint: /validate-auth
Validate a text challenge session, GET or POST 'number' and 'auth_code' to vaidate.
Will return 200 (OK) or 403 (Forbidden)
Setup Your Environment File
  2. Save new file called .env
SIGNALWIRE_SPACE=
SIGNALWIRE_PROJECT=
SIGNALWIRE_TOKEN=
SIGNALWIRE_NUMBER=
Build and Run on Docker
Let's get started!
For Python:
docker pull signalwire/snippets-text-two-factor-auth:python
  • Or build your own image:
docker build -t snippets-text-two-factor-auth .
  • Run your image:
docker run --publish 5000:5000 --env-file .env snippets-text-two-factor-auth
Build and Run Natively
For Python:
More Documentation
Support
