Snippet: Text to Text Forwarding
This Snippet will show you how to forward text messages to another phone number or device... Have you ever wanted a way to allow your customers to send you a quick message or wanted to take a quick note. This text to text example will allow you to do just that.
  • Python
  • SignalWire SDK
  • SignalWire Phone Number
  • Docker (Optional)
Methods and Endpoints
Endpoint: /forward-text
Methods: GET OR POST
Endpoint to accept incoming text messages from SignalWire space and forward them to MailGun.
Setup Your Environment File
  2. Save new file called .env
SIGNALWIRE_SPACE=
SIGNALWIRE_PROJECT=
SIGNALWIRE_TOKEN=
SIGNALWIRE_NUMBER=
# The phone number to forward messages To
FORWARD_TO_NUMBER=
Build and Run on Docker
Let's get started!
For Python:
docker pull signalwire/snippets-text-to-text:python
  • Or build your own image:
docker build -t snippets-text-to-text .
  • Run your image:
docker run --publish 5000:5000 --env-file .env snippets-text-to-text
Build and Run Natively
For Python:
More Documentation
Support
