Snippet: Text Subscription
This snippet will show you how to make a phrase based subscription service using LaML, creating and maintaining multiple campaigns, and their associated subscribers. The list administrator can broadcast to specific campaigns. The list administrator is notified of new subscribers via email, and of removal requests. If you reply with stop, or unsubscribe, the number will be placed in a black list.
  • Python
  • SignalWire SDK
  • SignalWire Phone Number
  • MailGun Account (For administrator notifications, https://www.mailgun.com/)
  • Docker (Optional)
Methods and Endpoints
Endpoint: /text_inbound
Methods: GET OR POST
Endpoint to accept incoming text messages from SignalWire space.
Handles campaign subscriptions and removal requests
Endpoint: /broadcast_msg
Send message to campaign subscribers by phrase and message.
Setup Your Environment File
  2. Save new file called .env
SIGNALWIRE_SPACE=
SIGNALWIRE_PROJECT=
SIGNALWIRE_TOKEN=
SIGNALWIRE_NUMBER=
MAILGUN_DOMAIN=
MAILGUN_API_TOKEN=
# Send Email From Address
# Send email to address for administrator notifications
# Email subject for admin notifications
EMAIL_SUBJECT=Text Subscription Admin Notification
Setup Your Campaign File
  1. Edit campaign.json to suit your needs, the file is a json object, that can handle multiple campaigns.
    "Id": "1",
    "Name": "signalwire-demo-1",
    "Phrases": [
      "signalwire"
    "Subscribers": [
    "Id": "2",
    "Name": "signalwire-demo-2",
    "Phrases": [
      "original"
    "Subscribers": [
Setup Your Do Not Contact File
  1. Edit donotcontact.json to suit your needs, the file is a json object and is global. This has no entries by default.
"DoNotContact": []
Build and Run on Docker
Let's get started!
For Python:
docker pull signalwire/snippets-text-subscription:python
  • Or build your own image:
docker build -t snippets-text-subscription .
  • Run your image:
docker run --publish 5000:5000 --env-file .env snippets-text-subscription
Build and Run Natively
For Python:
2. Setup you Campaign File
3. Setup your Do Not Call File
4. From command line run, python3 app.py
More Documentation
Support
