Snippet: Simple Dynamic IVR
This snippet will show you how to implement a dynamic interactive voice response menu by creating the actual menu trees easily and dynamically in a simple json object.
  • Python
  • SignalWire SDK
  • SignalWire Phone Number
  • Docker (Optional)
Methods and Endpoints
Endpoint: /get_menu
Methods: GET OR POST
Requests generate a menu, it will default to main menu if no menu is specified.  The get_menu, will look for dtmf entries to select action for routing and moving along a menu tree.
Endpoint: /get_voicemail
Requests to get_voicemail, produce a LaML Voice response to simulate an endpoint.
Setup Your Menus
  1. Edit the menus.json file
This example file has 3 menus Each menu contains a index, which is equal to the keypress on the menu, a verbiage, and an action
  "main": {
    "1": {
      "verbiage": "For sales press 1",
      "action": "/get_menu?menu=sales"
    "2": {
      "verbiage": "For tech support press 2",
      "action": "/get_menu?menu=tech"
  "sales": {
    "1": {
      "verbiage": "For partners, press 1",
      "action": "/get_voicemail?group=sale_partners"
    "2": {
      "verbiage": "For assistance with a purchase, press 2",
      "action": "/get_voicemail?group=sale_support"
  "tech": {
    "1": {
      "verbiage": "For issues with your internet, press 1",
      "action": "/get_voicemail?group=internet_support"
    "2": {
      "verbiage": "For issues with your cell phone, press 2",
      "action": "/get_voicemail?group=mobile_support"
Setup Your Environment File
  2. Save new file called .env
SIGNALWIRE_SPACE=
SIGNALWIRE_PROJECT=
SIGNALWIRE_TOKEN=
SIGNALWIRE_NUMBER=
# Hostname
HOSTNAME=
Build and Run on Docker
Let's get started!
For Python:
docker pull signalwire/snippets-simple-dynamic-ivr:python
  • Or build your own image:
docker build -t snippets-simple-dynamic-ivr .
  • Run your image:
docker run --publish 5000:5000 --env-file .env snippets-simple-dynamic-ivr
Build and Run Natively
For Python:
More Documentation
Support
