Snippet: Sentiment Analysis
This snippet will show you how to identify and analyse the sentiment or emotion of the call. This is good for POST-call analysis or with some simple modification, can be used in real-time, to actively route caller.
You will need a machine with Python installed, the SignalWire SDK, a provisioned SignalWire phone number, and optionally Docker if you decide to run it in a container.
  • Python
  • SignalWire SDK
  • SignalWire Phone Number
  • Docker (Optional)
How this Sentiment Analysis application works
Sentiment is a score from 0 to 1, that identifies the caller's emotion. You point a SignalWire phone number to the /voice_entry endpoint and it will assign a score, and read it back to you.
Methods and Endpoints
Endpoint: /voice_entry
Methods: GET OR POST
Requests to voice_entry, produce a LaML Voice response to gather a clip for analysis.
Setup Your Environment File
  2. Save new file called .env
## This is your key for Microsoft cognitive services
MICROSOFT_KEY=
Build and Run on Docker
Let's get started!
For Python:
docker pull signalwire/snippets-sentiment-analysis:python
  • Or build your own image:
docker build -t snippets-sentiment-analysis .
  • Run your image:
docker run --publish 5000:5000 --env-file .env snippets-sentiment-analysis
Build and Run Natively
For Python:
More Documentation
Support
