Snippet: Queue Callback Request
This snippets will show you how to request a callback from a voice call or text message so you can have your customers keep their sanity, while avoiding long hold times by offering this useful option. Customers can call and request a callback by pressing a digit, or they can text message the number and request a callback when the next agent is available.
  • Python
  • SignalWire SDK
  • SignalWire Phone Number
  • Docker (Optional)
Methods and Endpoints
Endpoint: /text_request_call
Methods: GET OR POST
Endpoint to accept incoming text messages from SignalWire space.
Endpoint: /enter_queue
Endpoint to place callers into queue.
Endpoint: /wait_url
Endpoint to handle people on hold in queue.
Endpoint: /request_callback
Endpoint to process request call back.
Endpoint: /connect_agent
Endpoint to connect agent to caller.
Setup Your Environment File
  2. Save new file called .env
SIGNALWIRE_SPACE=
SIGNALWIRE_PROJECT=
#Your API token - you can generate one on the `API` page in your Dashboard
SIGNALWIRE_TOKEN=
# The phone number you'll be using for this Snippets. Must include the `+1` , e.g.: +15551234567
SIGNALWIRE_NUMBER=
Build and Run on Docker
Let's get started!
For Python:
docker pull signalwire/snippets-queue-request-callback:python
  • Or build your own image:
docker build -t snippets-queue-request-callback .
  • Run your image:
docker run --publish 5000:5000 --env-file .env snippets-queue-request-callback
Build and Run Natively
For Python:
More Documentation
Support
