Snippet: Dial By Voice Directory
This snippet will show you how to implement a dial by voice directory - to lookup a contact in your datasource and dial them by voice. This example can be expanded to use LDAP or any datasource.
You will need a machine with Python installed, the SignalWire SDK, a provisioned SignalWire phone number, and optionally Docker if you decide to run it in a container.
  • Python
  • SignalWire SDK
  • SignalWire Phone Number
  • Docker (Optional)
Methods and Endpoints
Endpoint: /dial-prompt
Methods: GET OR POST
Handles incoming LaML requests for provisioned phone number, and prompts user to say a name, and performs lookup against a directory, and asks them if the wish to dial the contact. Speech Input: (Yes or No)  If contact is not found, it will prompt again.
Endpoint: /dial-verify
Dials the number, after a successful Yes. is detected and verified from the user.  If the user does not say Yes. they get a goodbye message.
Configure Your Directory
    "Id": "1",
    "First_Name": "Kevin",
    "Last_Name": "Garabedian",
    "Address": "+15554327812"
    "Id": "2",
    "First_Name": "John",
    "Last_Name": "Smith",
    "Address": "+15551234567"
    "Id": "3",
    "First_Name": "Mr",
    "Last_Name": "Magoo",
Build and Run on Docker
Let's get started!
For Python:
docker pull signalwire/snippets-dial-by-voice-directory:python
  • Or build your own image:
docker build -t snippets-dial-by-voice-directory .
  • Run your image:
docker run --publish 5000:5000 snippets-dial-by-voice-directory
Build and Run Natively
For Python:
More Documentation
Support
