Snippet: Dial By Voice
This snippet will show you how to implement a dial phone number by voice application, prompting the caller to say a phone number, and then connecting to the spoken phone number, as recognized using ASR.
  • Python
  • SignalWire SDK
  • SignalWire Phone Number
  • Docker (Optional)
Methods and Endpoints
Endpoint: /dial-prompt
Methods: GET OR POST
Handles incoming LaML requests for provisioned phone number, and prompts user to say a number to call, and asks them if the wish to dial it. Speech Input: (Yes or No)  If the number to dial can not be understood it will prompt again.
Endpoint: /dial-verify
Dials the number, after a successful Yes. is detected and verified from the user.  If the user does not say Yes. they get a goodbye message.
Build and Run on Docker
Let's get started!
For Python:
docker pull signalwire/snippets-dial-by-voice:python
  • Or build your own image:
docker build -t snippets-dial-by-voice .
  • Run your image:
docker run --publish 5000:5000 --env-file .env snippets-dial-by-voice
Build and Run Natively
For Python:
More Documentation
Support
