Snippet: Call and Text by Proxy
This snippet will show you how to create a bi-directional mask for those wishing to hide their phone number for voice and text messages.
If you ever had a situation where you wanted to keep your personal phone number private between two parties, this example will help you out. Services like Lyft, and Uber use technology like this every day to protect passengers and drivers personal phone numbers. There are many use cases for this and we hope you find it helpful.
  • Python
  • SignalWire SDK
  • SignalWire Phone Number
  • Docker (Optional)
Methods and Endpoints
Endpoint: /lookup-session
Methods: GET OR POST
When this is called, it will lookup an active proxy session and bascially create a back to back phone call that is proxied, or a proxied text message.  LEG A <-> SIGNALWIRE PROXY <-> LEG B
Setup Your Environment File
  2. Save new file called .env
SIGNALWIRE_SPACE=
SIGNALWIRE_PROJECT=
SIGNALWIRE_TOKEN=
# The proxy 1 phone number you'll be using for this Snippets. Must include the `+1` , e$
SIGNALWIRE_NUMBER_1=+14346613376
# The proxy 2 phone number you'll be using for this Snippets. Must include the `+1` , e$
SIGNALWIRE_NUMBER_2=+14346613377
Modify your Proxy Session File
  1. Edit proxy_sessions.json
    "Session_Id": "Demo123",
    "Participant_A_Number": "+15551237654",
    "Participant_B_Number": "+15553883000",
    "Proxy_Number": "+15556611212"
    "Session_Id": "Demo234",
    "Participant_A_Number": "+15555181212",
    "Participant_B_Number": "+12347896543",
Build and Run on Docker
Let's get started!
For Python:
docker pull signalwire/snippets-call-text-proxy:python
  • Or build your own image:
docker build -t snippets-call-text-proxy .
  • Run your image:
docker run --publish 5000:5000 --env-file .env snippets-call-text-proxy
Build and Run Natively
For Python:
2. Modify proxy session file
3. From command line run, python3 app.py
More Documentation
Support
