Why do you need it?
This snippet might be helpful to you if you need to pull your message records from SignalWire into a more readable format or somewhere easy to store for your own records. You can use one or more of the following parameters to further filter your records and return only the specific information that you need: DateSentBefore, DateSentAfter, From, Status, and To. This example shows how to filter all messages by a particular date range, status, from number, and to number.
What does it do?
This code snippet will allow you to list all the messages made (both outbound and inbound) from your SignalWire Project and export them as a CSV. You can choose the parameters you’d like to uncomment in order to filter the returned calls, or leave it with no parameters to return all of them.
Technical specifications
You must have the SignalWire PHP SDK installed. You can install that here.
You will also need to make sure that the vendor/autoload.php path points to the correct location on your computer. To copy this example exactly, you will need to install the SDK within the folder that contains this script.
ProjectID - Your project ID is an alphanumeric string that tells the SignalWire SDK where to find your project. You can find this in an easily copyable format by going to your SignalWire Portal and clicking the API tab on the left-hand side.
SpaceURL - Your space URL is the domain of your space, i.e. example.signalwire.com. This can also be found in an easily copyable format within the API tab in your SignalWire space.
You will need to change the date range to the one that fits your needs and uncomment any other parameters that you wish to use.
Comments
This snippet uses the PHP SDK to query SignalWire and return all the call data matching the parameters that you set. This data is inserted into a CSV file with the following columns:
From phone number
To phone number
DateSent
Status (queued, sending, sent, delivered, undelivered, failed, receiving, received)
Message SID (361d7f20-f30d-4baf-b8ca-c7912dleaacf)
Getting Started Guide
Start a free trial
