Flexible AND Turnkey
An AI backend is already built for you, it just needs you to tell it what to do. You can quickly configure AI agents programmatically through simple prompts and SignalWire connects it to a phone call for you. Our platform allows for deep customization so you can leverage AI Voice agents or whatever you need, whether it be IVR, voicemail that isn’t voicemail, customer support, a virtual receptionist, or something way cooler nobody has thought of yet.
Flexible DE 1
Half-second Latency
SignalWire Call Fabric architecture allows for the lowest latency possible at all points of orchestration, ensuring smooth and responsive user experiences that mimic real life conversations. Our agents are designed with advanced barge cutoff so that you don’t get cut off by the AI when you pause to think and the conversation can flow without interruption. The latency is so good, you might need to turn it down to give your human callers some time to catch up.
Flexible DE 2
Integrate Wherever and Whenever
Married to your current setup? We get that. There’s no need to rip and replace a perfectly good system in order to update your IVR or create a virtual personal assistant. When you build with SignalWire, you can add voice AI to any application and any infrastructure. Even better, now you can make changes and updates to your application without messing under the hood.
