Data is protected in transit and at rest using industry-standard encryption protocols, regardless of the channel or device.
TLS 1.2/1.3 for encrypted signaling across HTTP, SIP, and websockets
SRTP + DTLS for voice and video
AES-256 and RSA-4096 encryption for storage
Secure transmission across HTTPS and encrypted websocket channels
These controls help secure communications across voice, video, messaging, fax, and AI-powered interactions without relying on third-party service boundaries to maintain protection.
Continuous monitoring of platform for abuse, anomalous behavior, and potential threats across the real-time communications stack
Static and dynamic code analysis in the CI/CD pipeline
Real-time intrusion detection with automated alerting
Continuous vulnerability scanning and behavior analytics
Third-party penetration tests and independent security audits
Because signaling, media, routing, and orchestration run inside the same platform, detection and response can be applied with broader context and fewer blind spots than fragmented, multi-vendor environments.
Voice, video, messaging, fax, and AI workloads run in separate, controlled environments within a unified platform. We separate workloads, restrict access, and enforce strong authentication across all systems.
Isolated environments for voice, video, messaging, fax and AI services
Scoped credentials for every application and integration
Role-based access control with two-factor authentication (2FA)
Fine-grained permission management for internal and external tools
Strict security controls are applied across a single platform architecture, helping teams enforce policy more consistently across every interaction type.
