MCP Gateway
What is MCP?
The Model Context Protocol (MCP) is an open standard for connecting AI systems to external tools and data sources. MCP servers expose “tools” (functions) that AI models can call — similar to SWAIG functions but using a standardized protocol.
The MCP Gateway acts as a bridge: it runs MCP servers and exposes their tools as SWAIG functions that SignalWire agents can call. This lets you leverage the growing ecosystem of MCP tools without modifying your agent code.
Architecture Overview
Diagram showing the MCP Gateway architecture connecting SignalWire agents to MCP server processes.
MCP Gateway bridging MCP servers with SignalWire agents.
When to Use MCP Gateway
Good use cases:
  • Integrating existing MCP tools without modification
  • Using community MCP servers (database connectors, APIs, etc.)
  • Isolating tool execution in sandboxed processes
  • Managing multiple tool services from one gateway
  • Session-based tools that maintain state across calls
Consider alternatives when:
  • You need simple, stateless functions (use SWAIG directly)
  • You’re building custom tools from scratch (SWAIG is simpler)
  • Low latency is critical (gateway adds network hop)
  • You don’t need MCP ecosystem compatibility
Components
ComponentPurpose
Gateway ServiceHTTP server that manages MCP servers and sessions
MCP ManagerSpawns and communicates with MCP server processes
Session ManagerTracks per-call sessions with automatic cleanup
mcp_gateway SkillSignalWire skill that connects agents to the gateway
Installation
The MCP Gateway is included in the SignalWire Server SDK. Install with the gateway dependencies:
pip install "signalwire-sdk[mcp-gateway]"
Once installed, the mcp-gateway CLI command is available:
mcp-gateway --help
Setting Up the Gateway
1. Configuration
Create a configuration file for the gateway:
"server": {
"host": "0.0.0.0",
"port": 8080,
"auth_user": "admin",
"auth_password": "your-secure-password"
"services": {
"todo": {
"command": ["python3", "./todo_mcp.py"],
"description": "Todo list management",
"enabled": true,
"sandbox": {
"enabled": true,
"resource_limits": true
"calculator": {
"command": ["node", "./calc_mcp.js"],
"description": "Mathematical calculations",
"enabled": true
"session": {
"default_timeout": 300,
"max_sessions_per_service": 100,
"cleanup_interval": 60
Configuration supports environment variable substitution:
"server": {
"auth_password": "${MCP_AUTH_PASSWORD|changeme}"
2. Start the Gateway
# Using the installed CLI command
mcp-gateway -c config.json
# Or with Docker (in the mcp_gateway directory)
cd mcp_gateway
./mcp-docker.sh start
The gateway starts on the configured port (default 8080).
3. Connect Your Agent
The mcp_gateway skill connects agents to the gateway across all languages:
LanguageSyntax
Pythonself.add_skill("mcp_gateway", {"gateway_url": "http://localhost:8080", "services": [...]})
TypeScriptawait agent.addSkillByName('mcp_gateway', { gateway_url: 'http://localhost:8080', services: [...] })
class MCPAgent(AgentBase):
super().__init__(name="mcp-agent")
# Connect to MCP Gateway
"auth_password": "your-secure-password",
"services": [
{"name": "todo", "tools": "*"}, # All tools
{"name": "calculator", "tools": ["add", "multiply"]} # Specific tools
self.prompt_add_section(
"Role",
"You are an assistant with access to a todo list and calculator."
agent = MCPAgent()
Skill Configuration
The mcp_gateway skill accepts these parameters:
ParameterTypeDescriptionDefault
gateway_urlstringGateway service URLRequired
auth_userstringBasic auth usernameNone
auth_passwordstringBasic auth passwordNone
auth_tokenstringBearer token (alternative to basic auth)None
servicesarrayServices and tools to enableAll services
session_timeoutintegerSession timeout in seconds300
tool_prefixstringPrefix for SWAIG function names”mcp_“
retry_attemptsintegerConnection retry attempts3
request_timeoutintegerRequest timeout in seconds30
verify_sslbooleanVerify SSL certificatestrue
Service Configuration
Each service in the services array specifies:
"name": "service_name", # Service name from gateway config
"tools": "*" # All tools, or list: ["tool1", "tool2"]
Tools are exposed as SWAIG functions with names like mcp_{service}_{tool}.
Gateway API
The gateway exposes these REST endpoints:
EndpointMethodPurpose
/healthGETHealth check (no auth)
/servicesGETList available services
/services/{name}/toolsGETList tools for a service
/services/{name}/callPOSTCall a tool
/sessionsGETList active sessions
/sessions/{id}DELETEClose a session
Example API Calls
# List services
curl -u admin:password http://localhost:8080/services
# Get tools for a service
curl -u admin:password http://localhost:8080/services/todo/tools
# Call a tool
curl -u admin:password -X POST http://localhost:8080/services/todo/call \
-d '{
"tool": "add_todo",
"arguments": {"text": "Buy groceries"},
"session_id": "call-123",
"timeout": 300
Session Management
Sessions are tied to SignalWire call IDs:
  1. First tool call: Gateway creates a new MCP process and session
  2. Subsequent calls: Same session reused (process stays alive)
  3. Call ends: Hangup hook closes session and terminates process
This enables stateful tools — a todo list MCP can maintain items across multiple tool calls within the same phone call.
# Session persists across multiple tool calls in same call
# Call 1: "Add milk to my list" -> mcp_todo_add_todo(text="milk")
# Call 2: "What's on my list?" -> mcp_todo_list_todos() -> Returns "milk"
# Call 3: "Add eggs" -> mcp_todo_add_todo(text="eggs")
# Call 4: "Read my list" -> mcp_todo_list_todos() -> Returns "milk, eggs"
Security Features
Authentication
The gateway supports two authentication methods:
"server": {
"auth_password": "secure-password",
"auth_token": "optional-bearer-token"
Sandbox Isolation
MCP processes run in sandboxed environments:
"services": {
"untrusted_tool": {
"command": ["python3", "tool.py"],
"sandbox": {
"enabled": true,
"resource_limits": true,
"restricted_env": true
Sandbox levels:
LevelSettingsUse Case
Highenabled: true, resource_limits: true, restricted_env: trueUntrusted tools
Mediumenabled: true, resource_limits: true, restricted_env: falseTools needing env vars
Noneenabled: falseTrusted internal tools
Resource limits (when enabled):
  • CPU: 300 seconds
  • Memory: 512 MB
  • Processes: 10
  • File size: 10 MB
Rate Limiting
Configure rate limits per endpoint:
"rate_limiting": {
"default_limits": ["200 per day", "50 per hour"],
"tools_limit": "30 per minute",
"call_limit": "10 per minute"
Writing MCP Servers
MCP servers communicate via JSON-RPC 2.0 over stdin/stdout. The gateway spawns these as child processes. Here’s a minimal example:
#!/usr/bin/env python3
# greeter_mcp.py - Simple MCP server that the gateway can spawn
"""Simple MCP server example"""
import json
import sys
def handle_request(request):
method = request.get("method")
req_id = request.get("id")
if method == "initialize":
return {
"jsonrpc": "2.0",
"id": req_id,
"result": {
"protocolVersion": "2024-11-05",
"serverInfo": {"name": "example", "version": "1.0.0"},
"capabilities": {"tools": {}}
elif method == "tools/list":
return {
"jsonrpc": "2.0",
"id": req_id,
"result": {
"tools": [
"name": "greet",
"description": "Greet someone by name",
"inputSchema": {
"type": "object",
"properties": {
"name": {"type": "string", "description": "Name to greet"}
"required": ["name"]
elif method == "tools/call":
tool_name = request["params"]["name"]
args = request["params"].get("arguments", {})
if tool_name == "greet":
name = args.get("name", "World")
return {
"jsonrpc": "2.0",
"id": req_id,
"result": {
"content": [{"type": "text", "text": f"Hello, {name}!"}]
return {"jsonrpc": "2.0", "id": req_id, "error": {"code": -32601, "message": "Method not found"}}
def main():
for line in sys.stdin:
request = json.loads(line)
response = handle_request(request)
print(json.dumps(response), flush=True)
main()
Testing
Test with swaig-test
# List available tools (including MCP tools)
swaig-test greeter_agent.py --list-tools
# Execute the greet tool
swaig-test greeter_agent.py --call-id test-session --exec mcp_greeter_greet --name "World"
# Generate SWML
swaig-test greeter_agent.py --dump-swml
Test Gateway Directly
# Health check (no auth required)
curl http://localhost:8080/health
# List services
curl -u admin:secure-password http://localhost:8080/services
# Get tools for the greeter service
curl -u admin:secure-password http://localhost:8080/services/greeter/tools
# Call the greet tool
curl -u admin:secure-password -X POST http://localhost:8080/services/greeter/call \
-d '{"tool": "greet", "session_id": "test", "arguments": {"name": "World"}}'
# List active sessions
curl -u admin:secure-password http://localhost:8080/sessions
Docker Deployment
The gateway includes Docker support:
cd mcp_gateway
# Build and start
./mcp-docker.sh build
# Or use docker-compose
docker-compose up -d
# View logs
./mcp-docker.sh logs -f
# Stop
./mcp-docker.sh stop
Complete Example
# greeter_agent.py - Agent with MCP Gateway integration
"""Agent with MCP Gateway integration using the greeter MCP server"""
class GreeterAgent(AgentBase):
super().__init__(name="greeter-agent")
"services": [
{"name": "greeter", "tools": "*"}
"Role",
"You are a friendly assistant that can greet people by name."
"Guidelines",
bullets=[
"When users want to greet someone, use the mcp_greeter_greet function",
"Always be friendly and helpful",
"The greet function requires a name parameter"
agent = GreeterAgent()
Troubleshooting
IssueSolution
”Connection refused”Verify gateway is running and URL is correct
”401 Unauthorized”Check auth credentials match gateway config
”Service not found”Verify service name and that it’s enabled
”Tool not found”Check tool exists with /services/{name}/tools
”Session timeout”Increase session_timeout or default_timeout
Tools not appearingVerify services config includes the service
See Also
TopicReference
Built-in SkillsBuilt-in Skills
SWAIG FunctionsDefining Functions
