Search and Knowledge
Knowledge search transforms your agent from a general-purpose assistant into a domain expert. By connecting your agent to documents — FAQs, product manuals, policies, API docs — it can answer questions based on your actual content rather than general knowledge.
This is called RAG (Retrieval-Augmented Generation): when asked a question, the agent first retrieves relevant documents, then uses them to generate an accurate response. The result is more accurate, verifiable answers grounded in your authoritative sources.
Good use cases:
  • Customer support with FAQ/knowledge base
  • Product information lookup
  • Policy and procedure questions
  • API documentation assistant
  • Internal knowledge management
  • Training and onboarding assistants
Not ideal for:
  • Real-time data (use APIs instead)
  • Transactional operations (use SWAIG functions)
  • Content that changes very frequently
  • Highly personalized information (use database lookups)
Search System Overview
Build Time:
Documents -> sw-search CLI -> .swsearch file (SQLite + vectors)
Runtime:
Agent -> native_vector_search skill -> SearchEngine -> Results
Backends:
BackendDescription
SQLite.swsearch files - Local, portable, no infrastructure
pgvectorPostgreSQL extension for production deployments
RemoteNetwork mode for centralized search servers
Diagram showing the search flow from agent query through vector search to document results.
Search flow from query to results.
Building Search Indexes
Use the sw-search CLI to create search indexes:
## Basic usage - index a directory
sw-search ./docs --output knowledge.swsearch
## Multiple directories
sw-search ./docs ./examples --file-types md,txt,py
## Specific files
sw-search README.md ./docs/guide.md
## Mixed sources
sw-search ./docs README.md ./examples --file-types md,txt
Chunking Strategies
StrategyBest ForParameters
sentenceGeneral text--max-sentences-per-chunk 5
paragraphStructured docs(default)
slidingDense text--chunk-size 100 --overlap-size 20
pagePDFs(uses page boundaries)
markdownDocumentation(header-aware, code detection)
semanticTopic clustering--semantic-threshold 0.6
topicLong documents--topic-threshold 0.2
qaQ&A applications(optimized for questions)
sw-search ./docs \
--chunking-strategy markdown \
--file-types md \
--output docs.swsearch
This strategy:
  • Chunks at header boundaries
  • Detects code blocks and extracts language
  • Adds “code” tags to chunks containing code
  • Preserves section hierarchy in metadata
Sentence Chunking
sw-search ./docs \
--chunking-strategy sentence \
--max-sentences-per-chunk 10 \
Installing Search Dependencies
## Query-only (smallest footprint)
pip install "signalwire-sdk[search-queryonly]"
## Build indexes + vector search
pip install "signalwire-sdk[search]"
## Full features (PDF, DOCX processing)
pip install "signalwire-sdk[search-full]"
## All features including NLP
pip install "signalwire-sdk[search-all]"
## PostgreSQL pgvector support
pip install "signalwire-sdk[pgvector]"
Using Search in Agents
Add the native_vector_search skill to enable search:
LanguageSyntax
Pythonself.add_skill("native_vector_search", index_file="./knowledge.swsearch", count=5, tool_name="search_documents")
TypeScriptawait agent.addSkillByName('native_vector_search', { index_file: './knowledge.swsearch', count: 5, tool_name: 'search_documents' })
class KnowledgeAgent(AgentBase):
super().__init__(name="knowledge-agent")
self.prompt_add_section(
"Role",
"You are a helpful assistant with access to company documentation. "
"Use the search_documents function to find relevant information."
# Add search skill with local index
self.add_skill(
count=5, # Number of results
tool_name="search_documents",
tool_description="Search the company documentation"
agent = KnowledgeAgent()
Skill Configuration Options
self.add_skill(
# Index source (choose one)
index_file="./knowledge.swsearch", # Local SQLite index
# OR
# remote_url="http://search-server:8001", # Remote search server
# index_name="default",
# Search parameters
count=5, # Results to return (1-20)
similarity_threshold=0.0, # Min score (0.0-1.0)
tags=["docs", "api"], # Filter by tags
# Tool configuration
tool_name="search_knowledge",
tool_description="Search the knowledge base for information"
pgvector Backend
For production deployments, use PostgreSQL with pgvector:
self.add_skill(
backend="pgvector",
connection_string="postgresql://user:pass@localhost/db",
collection_name="knowledge_base",
count=5,
tool_name="search_docs"
CLI Commands
Build Index
## Basic build
## With specific file types
sw-search ./docs --file-types md,txt,rst --output knowledge.swsearch
## With chunking strategy
sw-search ./docs --chunking-strategy markdown --output knowledge.swsearch
## With tags
sw-search ./docs --tags documentation,api --output knowledge.swsearch
Validate Index
sw-search validate knowledge.swsearch
Search Index
sw-search search knowledge.swsearch "how do I configure auth"
Complete Example
#!/usr/bin/env python3
## documentation_agent.py - Agent that searches documentation
class DocumentationAgent(AgentBase):
"""Agent that searches documentation to answer questions"""
super().__init__(name="docs-agent")
"Role",
"You are a documentation assistant. When users ask questions, "
"search the documentation to find accurate answers. Always cite "
"the source document when providing information."
"Instructions",
1. When asked a question, use search_docs to find relevant information
2. Review the search results carefully
3. Synthesize an answer from the results
4. Mention which document the information came from
5. If nothing relevant is found, say so honestly
# Add a simple search function for demonstration
# In production, use native_vector_search skill with a .swsearch index:
# self.add_skill("native_vector_search", index_file="./docs.swsearch")
self.define_tool(
name="search_docs",
description="Search the documentation for information",
parameters={
"type": "object",
"properties": {
"query": {"type": "string", "description": "Search query"}
"required": ["query"]
handler=self.search_docs
def search_docs(self, args, raw_data):
"""Stub search function for demonstration"""
query = args.get("query", "")
return FunctionResult(
f"Search results for '{query}': This is a demonstration. "
"In production, use native_vector_search skill with a .swsearch index file."
agent = DocumentationAgent()
This example uses a stub function for demonstration. In production, use the native_vector_search skill with a .swsearch index file built using sw-search.
Multiple Knowledge Bases
Add multiple search instances for different topics:
## Product documentation
self.add_skill(
index_file="./products.swsearch",
tool_name="search_products",
tool_description="Search product catalog and specifications"
## Support articles
self.add_skill(
index_file="./support.swsearch",
tool_name="search_support",
tool_description="Search support articles and troubleshooting guides"
## API documentation
self.add_skill(
index_file="./api-docs.swsearch",
tool_name="search_api",
tool_description="Search API reference documentation"
Understanding Embeddings
Search works by converting text into numerical vectors (embeddings) that capture semantic meaning. Similar concepts have similar vectors, enabling “meaning-based” search rather than just keyword matching.
How it works:
  1. At index time: Each document chunk is converted to a vector and stored
  2. At query time: The search query is converted to a vector
  3. Matching: Chunks with vectors closest to the query vector are returned
This means “return policy” will match documents about “refund process” or “merchandise exchange” even if they don’t contain those exact words.
Index Management
When to Rebuild Indexes
Rebuild your search index when:
  • Source documents are added, removed, or significantly changed
  • You change chunking strategy
  • You want to add or modify tags
  • Search quality degrades
Keeping Indexes Updated
For production systems, automate index rebuilding:
#!/bin/bash
# rebuild_index.sh - Run on document updates
sw-search ./docs \
--output knowledge.swsearch.new
# Atomic replacement
mv knowledge.swsearch.new knowledge.swsearch
echo "Index rebuilt at $(date)"
Index Size and Performance
Rough sizing:
  • 100 documents (~50KB each) — approximately 10-20MB index
  • 1,000 documents — approximately 100-200MB index
  • 10,000+ documents — Consider pgvector for better performance
Query Optimization
"Search Instructions",
When users ask questions:
1. First search the documentation using search_docs
2. Review all results before answering
3. Cite which document your answer came from
4. If results aren't relevant, try a different search query
5. If no results help, acknowledge you couldn't find the answer
Tuning Search Parameters
count: Number of results to return
  • count=3: Focused answers, faster response
  • count=5: Good balance (default)
  • count=10: More comprehensive, but may include less relevant results
similarity_threshold: Minimum relevance score (0.0 to 1.0) — higher is better.
  • 0.0: Return all results regardless of relevance
  • 0.3: Filter out clearly irrelevant results
  • 0.5+: Only high-confidence matches (may miss relevant content)
tags: Filter by document categories
self.add_skill(
tags=["policies", "returns"], # Only search these categories
tool_name="search_policies"
Troubleshooting
”No results found”
  • Check that the index file exists and is readable
  • Verify the query is meaningful (not too short or generic)
  • Lower similarity_threshold if set too high
  • Ensure documents were actually indexed (check with sw-search validate)
Poor result relevance
  • Try different chunking strategies
  • Increase count to see more results
  • Review source documents for quality
  • Consider adding tags to filter by category
Slow search performance
  • For large indexes, use pgvector instead of SQLite
  • Reduce count if you don’t need many results
  • Consider a remote search server for shared access
Search Best Practices
Index Building
  • Use markdown chunking for documentation
  • Keep chunks reasonably sized (5-10 sentences)
  • Add meaningful tags for filtering
  • Rebuild indexes when source docs change
  • Test search quality after building
  • Version your indexes with your documentation
Agent Configuration
  • Set count=3-5 for most use cases
  • Use similarity_threshold to filter noise
  • Give descriptive tool_name and tool_description
  • Tell AI when/how to use search in the prompt
  • Handle “no results” gracefully in your prompt
Production
  • Use pgvector for high-volume deployments
  • Consider remote search server for shared indexes
  • Monitor search latency and result quality
  • Automate index rebuilding when docs change
  • Log search queries to understand user needs
