Exposing Your Agent to the Internet
Why You Need a Public URL
SignalWire’s cloud needs to reach your agent via HTTP:
Diagram showing that SignalWire's cloud cannot reach your agent running on localhost.
The Problem
Diagram showing ngrok creating a public tunnel from SignalWire's cloud to your local agent.
The Solution: ngrok
Installing ngrok
macOS (Homebrew)
brew install ngrok
Linux
## Download
curl -s https://ngrok-agent.s3.amazonaws.com/ngrok.asc | \
sudo tee /etc/apt/trusted.gpg.d/ngrok.asc >/dev/null && \
echo "deb https://ngrok-agent.s3.amazonaws.com buster main" | \
sudo tee /etc/apt/sources.list.d/ngrok.list
## Install
sudo apt update && sudo apt install ngrok
Windows
## Using Chocolatey
choco install ngrok
## Or download from https://ngrok.com/download
Direct Download
Visit ngrok.com/download and download for your platform.
Create an ngrok Account (Free)
  1. Go to ngrok.com and sign up
  2. Get your auth token from the dashboard
  3. Configure ngrok with your token:
ngrok config add-authtoken YOUR_AUTH_TOKEN_HERE
This enables:
  • Longer session times
  • Custom subdomains (paid)
  • Multiple tunnels
Basic Usage
Start your agent in one terminal:
## Terminal 1 (use the command for your language)
python my_agent.py # Python
npx tsx my_agent.ts # TypeScript
go run my_agent.go # Go
ruby my_agent.rb # Ruby
java MyAgent # Java
perl my_agent.pl # Perl
./my_agent # C++ (compiled)
php my_agent.php # PHP
Start ngrok in another terminal:
## Terminal 2
ngrok http 3000
You’ll see output like:
ngrok (Ctrl+C to quit)
Session Status online
Account your-email@example.com (Plan: Free)
Version 3.x.x
Region United States (us)
Latency 45ms
Web Interface http://127.0.0.1:4040
Forwarding https://abc123def456.ngrok-free.app -> http://localhost:3000
Connections ttl opn rt1 rt5 p50 p90
0 0 0.00 0.00 0.00 0.00
Your public URL is: https://abc123def456.ngrok-free.app
Test the Tunnel
## Test locally (use credentials from agent startup output or env vars)
curl -u "$SWML_BASIC_AUTH_USER:$SWML_BASIC_AUTH_PASSWORD" http://localhost:3000/
## Test through ngrok (use YOUR URL from ngrok output)
curl -u "$SWML_BASIC_AUTH_USER:$SWML_BASIC_AUTH_PASSWORD" https://abc123def456.ngrok-free.app/
Both should return the same SWML document.
ngrok Web Interface
ngrok provides a web interface at http://127.0.0.1:4040 showing:
  • All requests coming through the tunnel
  • Request/response headers and bodies
  • Timing information
  • Ability to replay requests
This is invaluable for debugging SignalWire webhook calls!
Free ngrok gives you random URLs that change each restart. For easier development, use a static domain:
Free Static Domain (ngrok account required)
  1. Go to ngrok Dashboard -> Domains
  2. Create a free static domain (e.g., your-name.ngrok-free.app)
  3. Use it:
ngrok http --url=https://your-name.ngrok-free.app 3000
Now your URL stays the same across restarts!
Understanding Basic Authentication
The SDK automatically secures your agent with HTTP Basic Authentication. Every time you start your agent, you’ll see:
Agent 'my-agent' is available at:
URL: http://localhost:3000
Basic Auth: signalwire:7vVZ8iMTOWL0Y7-BG6xaN3qhjmcm4Sf59nORNdlF9bs (source: provided)
The password changes on every restart unless you set environment variables.
Setting Persistent Credentials
For development, set these environment variables to use the same credentials across restarts:
## In your .env file or shell
export SWML_BASIC_AUTH_USER=signalwire
export SWML_BASIC_AUTH_PASSWORD=your-secure-password-here
Then start your agent:
python my_agent.py
Now it will show:
Basic Auth: signalwire:your-secure-password-here (source: environment)
Why this matters:
  • SignalWire needs these credentials to call your agent
  • Random passwords mean reconfiguring SignalWire on every restart
  • Set environment variables once for consistent development
Configure Your Agent for ngrok
Set the SWML_PROXY_URL_BASE environment variable so your agent generates correct webhook URLs:
SWML_PROXY_URL_BASE=https://your-name.ngrok-free.app
Or set them when running:
SWML_PROXY_URL_BASE=https://your-name.ngrok-free.app \
SWML_BASIC_AUTH_USER=signalwire \
SWML_BASIC_AUTH_PASSWORD=your-secure-password-here \
python my_agent.py
This ensures:
  • SWAIG function webhook URLs point to your public ngrok URL, not localhost
  • Authentication credentials remain consistent across restarts
Complete Development Setup
Here’s the full workflow:
## Terminal 1: Start ngrok with static domain
## Terminal 2: Start agent with environment variables
export SWML_PROXY_URL_BASE=https://your-name.ngrok-free.app
python my_agent.py
## Terminal 3: Test (use the credentials from Terminal 2)
curl -u signalwire:your-secure-password-here https://your-name.ngrok-free.app/
curl -u signalwire:your-secure-password-here https://your-name.ngrok-free.app/debug
Using a Script
Create start-dev.sh:
#!/bin/bash
## start-dev.sh - Start development environment
NGROK_DOMAIN="your-name.ngrok-free.app"
AUTH_USER="signalwire"
AUTH_PASS="your-secure-password-here"
echo "Starting development environment..."
echo "Public URL: https://${NGROK_DOMAIN}"
echo "Basic Auth: ${AUTH_USER}:${AUTH_PASS}"
echo ""
## Start ngrok in background
ngrok http --url=https://${NGROK_DOMAIN} 3000 &
NGROK_PID=$!
## Wait for ngrok to start
sleep 2
## Start agent with environment variables
export SWML_PROXY_URL_BASE="https://${NGROK_DOMAIN}"
export SWML_BASIC_AUTH_USER="${AUTH_USER}"
export SWML_BASIC_AUTH_PASSWORD="${AUTH_PASS}"
python my_agent.py
## Cleanup on exit
trap "kill $NGROK_PID 2>/dev/null" EXIT
Make it executable:
chmod +x start-dev.sh
./start-dev.sh
Alternative Tunneling Solutions
Cloudflare Tunnel (Free)
## Install cloudflared
brew install cloudflared # macOS
## Quick tunnel (no account needed)
cloudflared tunnel --url http://localhost:3000
localtunnel (Free, no signup)
## Install
npm install -g localtunnel
## Run
lt --port 3000
tailscale Funnel (Requires Tailscale)
## If you use Tailscale
tailscale funnel 3000
Production Alternatives
For production, don’t use ngrok. Instead:
OptionDescription
Cloud VMDeploy to AWS, GCP, Azure, DigitalOcean
ServerlessAWS Lambda, Google Cloud Functions, Azure Functions
ContainerDocker on Kubernetes, ECS, Cloud Run
VPSAny server with a public IP
See the Deployment chapter for production deployment guides.
Troubleshooting
ngrok shows “ERR_NGROK_108”
Your auth token is invalid or expired. Get a new one from the ngrok dashboard:
ngrok config add-authtoken YOUR_NEW_TOKEN
Connection refused
Your agent isn’t running or is on a different port:
## Check agent is running
curl http://localhost:3000/
## If using different port
ngrok http 8080
Webhook URLs still show localhost
Set SWML_PROXY_URL_BASE:
export SWML_PROXY_URL_BASE=https://your-domain.ngrok-free.app
python my_agent.py
ngrok tunnel expires
Free ngrok tunnels expire after a few hours. Solutions:
  • Restart ngrok
  • Use a static domain (stays same after restart)
  • Upgrade to paid ngrok plan
  • Use an alternative like Cloudflare Tunnel
What’s Next?
Your agent is now accessible at a public URL. You’re ready to connect it to SignalWire!
You’ve Completed Phase 1!
  • Installed the SDK
  • Created your first agent
  • Set up development environment
  • Exposed agent via ngrok
Your agent is ready at: https://your-domain.ngrok-free.app
Next Chapter: Architecture - Deep dive into SWML, SWAIG, and agent architecture
Or jump to: SignalWire Integration - Connect your agent to phone numbers
