Skill Configuration
Configuration Methods
MethodDescription
Parameters dictPass config when calling add_skill()
Environment variablesSet via OS environment
SWAIG fieldsCustomize tool metadata
External directoriesRegister custom skill paths
Parameter Dictionary
Pass configuration when adding a skill:
LanguagePassing config parameters
Pythonself.add_skill("web_search", {"api_key": "...", "num_results": 5})
TypeScriptawait agent.addSkillByName('web_search', { api_key: '...', num_results: 5 })
"api_key": "your-api-key",
"search_engine_id": "your-engine-id",
"num_results": 5,
"min_quality_score": 0.4
Parameter Schema
Skills define their parameters via get_parameter_schema():
"api_key": {
"type": "string",
"description": "Google API key",
"required": True,
"hidden": True,
"env_var": "GOOGLE_API_KEY"
"num_results": {
"type": "integer",
"description": "Number of results",
"default": 3,
"min": 1,
"max": 10
"style": {
"type": "string",
"description": "Output style",
"enum": ["brief", "detailed"],
"default": "brief"
Parameter Properties
PropertyTypeDescription
typestringData type: string, integer, number, boolean, object, array
descriptionstringHuman-readable description
defaultanyDefault value if not provided
requiredboolWhether parameter is required
hiddenboolHide in UIs (for secrets)
env_varstringEnvironment variable source
enumarrayAllowed values
min/maxnumberValue range for numbers
Environment Variables
Skills can read from environment variables:
import os
## Set environment variable
os.environ["GOOGLE_API_KEY"] = "your-key"
## Skill reads from params or falls back to env
"api_key": os.getenv("GOOGLE_API_KEY"),
"search_engine_id": os.getenv("SEARCH_ENGINE_ID")
SWAIG Fields
Override SWAIG function metadata for skill tools:
LanguageSWAIG fields override
Pythonself.add_skill("datetime", {"swaig_fields": {"fillers": {...}}})
TypeScriptawait agent.addSkillByName('datetime', { swaig_fields: { fillers: {...} } })
"swaig_fields": {
# Add filler phrases while function executes
"fillers": {
"en-US": [
"Let me check the time...",
"One moment..."
# Disable security for testing
"secure": False
Available SWAIG fields:
FieldDescription
fillersLanguage-specific filler phrases
secureEnable/disable token validation
webhook_urlOverride webhook URL
External Skill Directories
Register custom skill directories:
from signalwire.skills.registry import skill_registry
## Add directory at runtime
skill_registry.add_skill_directory("/opt/custom_skills")
## Environment variable (colon-separated paths)
## SIGNALWIRE_SKILL_PATHS=/path1:/path2:/path3
Entry Points
Install skills via pip packages:
## In setup.py
setup(
name="my-skills-package",
entry_points={
"signalwire.skills": [
"weather = my_package.skills:WeatherSkill",
"stock = my_package.skills:StockSkill"
Listing Available Skills
## List all available skills
skills = skill_registry.list_skills()
for skill in skills:
print(f"{skill['name']}: {skill['description']}")
## Get complete schema for all skills
schema = skill_registry.get_all_skills_schema()
print(schema)
Multi-Instance Configuration
Skills supporting multiple instances need unique tool names:
LanguageMulti-instance with unique tool_name
Pythonself.add_skill("web_search", {"tool_name": "search_news", "api_key": "KEY"})
TypeScriptawait agent.addSkillByName('web_search', { tool_name: 'search_news', api_key: 'KEY' })
## Instance 1: News search
"tool_name": "search_news", # Unique function name
"api_key": "KEY",
"search_engine_id": "NEWS_ENGINE"
## Instance 2: Documentation search
"tool_name": "search_docs", # Different function name
"api_key": "KEY",
"search_engine_id": "DOCS_ENGINE"
Configuration Validation
Skill configuration validation flow diagram.
Validation Flow
Complete Configuration Example
import os
## Register external skills
skill_registry.add_skill_directory("/opt/my_company/skills")
class ConfiguredAgent(AgentBase):
super().__init__(name="configured-agent")
# Simple skill - no config
self.add_skill("datetime")
# Skill with parameters
"search_engine_id": os.getenv("SEARCH_ENGINE_ID"),
"num_results": 5,
# Skill with SWAIG field overrides
self.add_skill("math", {
"swaig_fields": {
"fillers": {
"en-US": ["Calculating..."]
# Multi-instance skill
self.add_skill("native_vector_search", {
"tool_name": "search_products",
"index_path": "/data/products.swsearch"
"tool_name": "search_faqs",
"index_path": "/data/faqs.swsearch"
self.prompt_add_section(
"Role",
"You are a customer service agent."
agent = ConfiguredAgent()
Configuration Best Practices
Security
  • Store API keys in environment variables
  • Never commit secrets to version control
  • Use hidden: true for sensitive parameters
Organization
  • Group related configuration
  • Use descriptive tool_name for multi-instance
  • Document required configuration
Validation
  • Check has_skill() before using conditionally
  • Handle ValueError from add_skill()
  • Validate parameters early in setup()
Next Steps
You’ve learned the complete skills system. Next, explore advanced topics like contexts, workflows, and state management.
