Docker & Kubernetes
Dockerfile
Each language has a different Dockerfile. Choose the one matching your SDK language.
FROM python:3.11-slim
WORKDIR /app
## Install dependencies
COPY requirements.txt .
RUN pip install --no-cache-dir -r requirements.txt
## Copy application
COPY . .
## Create non-root user
RUN useradd -m appuser && chown -R appuser:appuser /app
USER appuser
## Expose port
EXPOSE 3000
## Run with uvicorn
CMD ["uvicorn", "app:app", "--host", "0.0.0.0", "--port", "3000", "--workers", "4"]
Application entry point (Python)
## app.py
class MyAgent(AgentBase):
agent = MyAgent()
app = agent._app
Building and running
## Build image
docker build -t signalwire-agent .
## Run container
docker run -d \
-p 3000:3000 \
-e SWML_BASIC_AUTH_USER=myuser \
-e SWML_BASIC_AUTH_PASSWORD=mypassword \
--name agent \
signalwire-agent
## View logs
docker logs -f agent
## Stop container
docker stop agent
Docker Compose
## docker-compose.yml
version: '3.8'
services:
agent:
build: .
ports:
- "3000:3000"
environment:
- SWML_BASIC_AUTH_USER=${SWML_BASIC_AUTH_USER}
- SWML_BASIC_AUTH_PASSWORD=${SWML_BASIC_AUTH_PASSWORD}
- SWML_PROXY_URL_BASE=${SWML_PROXY_URL_BASE}
restart: unless-stopped
healthcheck:
test: ["CMD", "curl", "-f", "http://localhost:3000/health"]
interval: 30s
timeout: 10s
retries: 3
nginx:
image: nginx:alpine
ports:
- "443:443"
- "80:80"
volumes:
- ./nginx.conf:/etc/nginx/nginx.conf:ro
- ./certs:/etc/ssl/certs:ro
depends_on:
- agent
Run with:
docker-compose up -d
Kubernetes deployment
Kubernetes manifests are language-agnostic. The only difference is the Docker image referenced and any build steps. Use the appropriate Dockerfile from the section above to build your image, then deploy with the same manifests regardless of language.
LanguageImage Build Command
Pythondocker build -f Dockerfile.python -t your-registry/agent:latest .
TypeScriptdocker build -f Dockerfile.ts -t your-registry/agent:latest .
Deployment manifest
## deployment.yaml
apiVersion: apps/v1
kind: Deployment
metadata:
labels:
app: signalwire-agent
spec:
replicas: 3
selector:
matchLabels:
template:
metadata:
labels:
spec:
containers:
- name: agent
image: your-registry/signalwire-agent:latest
ports:
- containerPort: 3000
env:
- name: SWML_BASIC_AUTH_USER
valueFrom:
secretKeyRef:
key: auth-user
- name: SWML_BASIC_AUTH_PASSWORD
valueFrom:
secretKeyRef:
key: auth-password
resources:
requests:
memory: "256Mi"
cpu: "250m"
limits:
memory: "512Mi"
cpu: "500m"
livenessProbe:
httpGet:
path: /health
port: 3000
initialDelaySeconds: 10
periodSeconds: 30
readinessProbe:
httpGet:
path: /health
port: 3000
initialDelaySeconds: 5
periodSeconds: 10
Service manifest
## service.yaml
apiVersion: v1
kind: Service
metadata:
spec:
selector:
ports:
- protocol: TCP
port: 80
targetPort: 3000
type: ClusterIP
Ingress manifest
## ingress.yaml
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
annotations:
nginx.ingress.kubernetes.io/ssl-redirect: "true"
cert-manager.io/cluster-issuer: "letsencrypt-prod"
spec:
ingressClassName: nginx
tls:
- hosts:
- agent.example.com
secretName: agent-tls
rules:
- host: agent.example.com
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
number: 80
Secrets
## secrets.yaml
apiVersion: v1
kind: Secret
metadata:
type: Opaque
stringData:
auth-user: your-username
auth-password: your-secure-password
Kubernetes architecture
Kubernetes architecture diagram showing pods, services, ingress, and SignalWire Cloud.
Kubernetes Architecture
Deploying to Kubernetes
## Create secrets
kubectl apply -f secrets.yaml
## Deploy application
kubectl apply -f deployment.yaml
kubectl apply -f service.yaml
kubectl apply -f ingress.yaml
## Check status
kubectl get pods -l app=signalwire-agent
kubectl get svc signalwire-agent
kubectl get ingress signalwire-agent
## View logs
kubectl logs -f -l app=signalwire-agent
## Scale deployment
kubectl scale deployment signalwire-agent --replicas=5
Horizontal Pod Autoscaler
## hpa.yaml
apiVersion: autoscaling/v2
kind: HorizontalPodAutoscaler
metadata:
spec:
scaleTargetRef:
apiVersion: apps/v1
kind: Deployment
minReplicas: 2
maxReplicas: 10
metrics:
- type: Resource
resource:
target:
type: Utilization
averageUtilization: 70
Multi-architecture builds
## Build for multiple architectures
FROM --platform=$TARGETPLATFORM python:3.11-slim
## ... rest of Dockerfile
Build with:
docker buildx build --platform linux/amd64,linux/arm64 -t your-registry/agent:latest --push .
Container best practices
Security
  • Run as non-root user
  • Use minimal base images (slim, alpine)
  • Scan images for vulnerabilities
  • Don’t store secrets in images
Performance
  • Use multi-stage builds to reduce image size
  • Layer dependencies efficiently
  • Set appropriate resource limits
Reliability
  • Add health checks
  • Use restart policies
  • Configure proper logging
  • Set graceful shutdown handling
