# MCP Gateway
> Bridge Model Context Protocol (MCP) servers with SignalWire AI agents, enabling your agents to use any MCP-compatible tool through a managed gateway service.
[built-in-skills]: /docs/server-sdks/guides/builtin-skills
[defining-functions]: /docs/server-sdks/guides/defining-functions
### What is MCP?
The Model Context Protocol (MCP) is an open standard for connecting AI systems to external tools and data sources. MCP servers expose "tools" (functions) that AI models can call -- similar to SWAIG functions but using a standardized protocol.
The MCP Gateway acts as a bridge: it runs MCP servers and exposes their tools as SWAIG functions that SignalWire agents can call. This lets you leverage the growing ecosystem of MCP tools without modifying your agent code.
### Architecture Overview
```mermaid
sequenceDiagram
    participant Agent as SignalWire Agent
    participant Gateway as MCP Gateway
    participant Server as MCP Server
    Agent->>Gateway: 1. Add skill
    Gateway-->>Agent: 2. Query tools
    Gateway->>Server: 3. List tools
    Server-->>Gateway: 4. Tool list
    Agent->>Gateway: 5. SWAIG call
    Gateway->>Server: 6. Spawn session
    Gateway->>Server: 7. Call MCP tool
    Server-->>Gateway: 8. MCP response
    Gateway-->>Agent: 9. SWAIG response
    Agent->>Gateway: 10. Call hangup
    Gateway->>Server: 11. Close session
### When to Use MCP Gateway
**Good use cases:**
* Integrating existing MCP tools without modification
* Using community MCP servers (database connectors, APIs, etc.)
* Isolating tool execution in sandboxed processes
* Managing multiple tool services from one gateway
* Session-based tools that maintain state across calls
**Consider alternatives when:**
* You need simple, stateless functions (use SWAIG directly)
* You're building custom tools from scratch (SWAIG is simpler)
* Low latency is critical (gateway adds network hop)
* You don't need MCP ecosystem compatibility
### Components
| Component          | Purpose                                              |
| Gateway Service    | HTTP server that manages MCP servers and sessions    |
| MCP Manager        | Spawns and communicates with MCP server processes    |
| Session Manager    | Tracks per-call sessions with automatic cleanup      |
| mcp\_gateway Skill | SignalWire skill that connects agents to the gateway |
### Installation
The MCP Gateway is included in the SignalWire Server SDK. Install with the gateway dependencies:
```bash
pip install "signalwire-sdk[mcp-gateway]"
Once installed, the `mcp-gateway` CLI command is available:
```bash
mcp-gateway --help
### Setting Up the Gateway
#### 1. Configuration
Create a configuration file for the gateway:
```json
    "server": {
        "host": "0.0.0.0",
        "port": 8080,
        "auth_user": "admin",
        "auth_password": "your-secure-password"
    "services": {
        "todo": {
            "command": ["python3", "./todo_mcp.py"],
            "description": "Todo list management",
            "enabled": true,
            "sandbox": {
                "enabled": true,
                "resource_limits": true
        "calculator": {
            "command": ["node", "./calc_mcp.js"],
            "description": "Mathematical calculations",
            "enabled": true
    "session": {
        "default_timeout": 300,
        "max_sessions_per_service": 100,
        "cleanup_interval": 60
Configuration supports environment variable substitution:
```json
    "server": {
        "auth_password": "${MCP_AUTH_PASSWORD|changeme}"
#### 2. Start the Gateway
```bash
# Using the installed CLI command
mcp-gateway -c config.json
# Or with Docker (in the mcp_gateway directory)
cd mcp_gateway
./mcp-docker.sh start
The gateway starts on the configured port (default 8080).
#### 3. Connect Your Agent
The `mcp_gateway` skill connects agents to the gateway across all languages:
| Language   | Syntax        |
| Python     | `self.add_skill("mcp_gateway", {"gateway_url": "http://localhost:8080", "services": [...]})`           |
| TypeScript | `await agent.addSkillByName('mcp_gateway', { gateway_url: 'http://localhost:8080', services: [...] })` |
class MCPAgent(AgentBase):
        super().__init__(name="mcp-agent")
        # Connect to MCP Gateway
            "auth_password": "your-secure-password",
            "services": [
                {"name": "todo", "tools": "*"},      # All tools
                {"name": "calculator", "tools": ["add", "multiply"]}  # Specific tools
        self.prompt_add_section(
            "Role",
            "You are an assistant with access to a todo list and calculator."
    agent = MCPAgent()
### Skill Configuration
The `mcp_gateway` skill accepts these parameters:
| Parameter         | Type    | Description                              | Default      |
| `gateway_url`     | string  | Gateway service URL                      | Required     |
| `auth_user`       | string  | Basic auth username                      | None         |
| `auth_password`   | string  | Basic auth password                      | None         |
| `auth_token`      | string  | Bearer token (alternative to basic auth) | None         |
| `services`        | array   | Services and tools to enable             | All services |
| `session_timeout` | integer | Session timeout in seconds               | 300          |
| `tool_prefix`     | string  | Prefix for SWAIG function names          | "mcp\_"      |
| `retry_attempts`  | integer | Connection retry attempts                | 3            |
| `request_timeout` | integer | Request timeout in seconds               | 30           |
| `verify_ssl`      | boolean | Verify SSL certificates                  | true         |
#### Service Configuration
Each service in the `services` array specifies:
    "name": "service_name",    # Service name from gateway config
    "tools": "*"               # All tools, or list: ["tool1", "tool2"]
Tools are exposed as SWAIG functions with names like `mcp_{service}_{tool}`.
### Gateway API
The gateway exposes these REST endpoints:
| Endpoint                 | Method | Purpose                  |
| `/health`                | GET    | Health check (no auth)   |
| `/services`              | GET    | List available services  |
| `/services/{name}/tools` | GET    | List tools for a service |
| `/services/{name}/call`  | POST   | Call a tool              |
| `/sessions`              | GET    | List active sessions     |
| `/sessions/{id}`         | DELETE | Close a session          |
#### Example API Calls
```bash
# List services
curl -u admin:password http://localhost:8080/services
# Get tools for a service
curl -u admin:password http://localhost:8080/services/todo/tools
# Call a tool
curl -u admin:password -X POST http://localhost:8080/services/todo/call \
  -d '{
    "tool": "add_todo",
    "arguments": {"text": "Buy groceries"},
    "session_id": "call-123",
    "timeout": 300
### Session Management
Sessions are tied to SignalWire call IDs:
1. **First tool call**: Gateway creates a new MCP process and session
2. **Subsequent calls**: Same session reused (process stays alive)
3. **Call ends**: Hangup hook closes session and terminates process
This enables stateful tools -- a todo list MCP can maintain items across multiple tool calls within the same phone call.
# Session persists across multiple tool calls in same call
# Call 1: "Add milk to my list" -> mcp_todo_add_todo(text="milk")
# Call 2: "What's on my list?"  -> mcp_todo_list_todos() -> Returns "milk"
# Call 3: "Add eggs"            -> mcp_todo_add_todo(text="eggs")
# Call 4: "Read my list"        -> mcp_todo_list_todos() -> Returns "milk, eggs"
### Security Features
#### Authentication
The gateway supports two authentication methods:
```json
    "server": {
        "auth_password": "secure-password",
        "auth_token": "optional-bearer-token"
#### Sandbox Isolation
MCP processes run in sandboxed environments:
```json
    "services": {
        "untrusted_tool": {
            "command": ["python3", "tool.py"],
            "sandbox": {
                "enabled": true,
                "resource_limits": true,
                "restricted_env": true
**Sandbox levels:**
| Level  | Settings                                                      | Use Case               |
| High   | `enabled: true, resource_limits: true, restricted_env: true`  | Untrusted tools        |
| Medium | `enabled: true, resource_limits: true, restricted_env: false` | Tools needing env vars |
| None   | `enabled: false`                                              | Trusted internal tools |
**Resource limits (when enabled):**
* CPU: 300 seconds
* Memory: 512 MB
* Processes: 10
* File size: 10 MB
#### Rate Limiting
Configure rate limits per endpoint:
```json
    "rate_limiting": {
        "default_limits": ["200 per day", "50 per hour"],
        "tools_limit": "30 per minute",
        "call_limit": "10 per minute"
### Writing MCP Servers
MCP servers communicate via JSON-RPC 2.0 over stdin/stdout. The gateway spawns these as child processes. Here's a minimal example:
#!/usr/bin/env python3
# greeter_mcp.py - Simple MCP server that the gateway can spawn
"""Simple MCP server example"""
import json
import sys
def handle_request(request):
    method = request.get("method")
    req_id = request.get("id")
    if method == "initialize":
        return {
            "jsonrpc": "2.0",
            "id": req_id,
            "result": {
                "protocolVersion": "2024-11-05",
                "serverInfo": {"name": "example", "version": "1.0.0"},
                "capabilities": {"tools": {}}
    elif method == "tools/list":
        return {
            "jsonrpc": "2.0",
            "id": req_id,
            "result": {
                "tools": [
                        "name": "greet",
                        "description": "Greet someone by name",
                        "inputSchema": {
                            "type": "object",
                            "properties": {
                                "name": {"type": "string", "description": "Name to greet"}
                            "required": ["name"]
    elif method == "tools/call":
        tool_name = request["params"]["name"]
        args = request["params"].get("arguments", {})
        if tool_name == "greet":
            name = args.get("name", "World")
            return {
                "jsonrpc": "2.0",
                "id": req_id,
                "result": {
                    "content": [{"type": "text", "text": f"Hello, {name}!"}]
    return {"jsonrpc": "2.0", "id": req_id, "error": {"code": -32601, "message": "Method not found"}}
def main():
    for line in sys.stdin:
        request = json.loads(line)
        response = handle_request(request)
        print(json.dumps(response), flush=True)
    main()
### Testing
#### Test with swaig-test
```bash
# List available tools (including MCP tools)
swaig-test greeter_agent.py --list-tools
# Execute the greet tool
swaig-test greeter_agent.py --call-id test-session --exec mcp_greeter_greet --name "World"
# Generate SWML
swaig-test greeter_agent.py --dump-swml
#### Test Gateway Directly
```bash
# Health check (no auth required)
curl http://localhost:8080/health
# List services
curl -u admin:secure-password http://localhost:8080/services
# Get tools for the greeter service
curl -u admin:secure-password http://localhost:8080/services/greeter/tools
# Call the greet tool
curl -u admin:secure-password -X POST http://localhost:8080/services/greeter/call \
  -d '{"tool": "greet", "session_id": "test", "arguments": {"name": "World"}}'
# List active sessions
curl -u admin:secure-password http://localhost:8080/sessions
### Docker Deployment
The gateway includes Docker support:
```bash
cd mcp_gateway
# Build and start
./mcp-docker.sh build
# Or use docker-compose
docker-compose up -d
# View logs
./mcp-docker.sh logs -f
# Stop
./mcp-docker.sh stop
### Complete Example
# greeter_agent.py - Agent with MCP Gateway integration
"""Agent with MCP Gateway integration using the greeter MCP server"""
class GreeterAgent(AgentBase):
        super().__init__(name="greeter-agent")
            "services": [
                {"name": "greeter", "tools": "*"}
            "Role",
            "You are a friendly assistant that can greet people by name."
            "Guidelines",
            bullets=[
                "When users want to greet someone, use the mcp_greeter_greet function",
                "Always be friendly and helpful",
                "The greet function requires a name parameter"
    agent = GreeterAgent()
### Troubleshooting
| Issue                | Solution                                        |
| "Connection refused" | Verify gateway is running and URL is correct    |
| "401 Unauthorized"   | Check auth credentials match gateway config     |
| "Service not found"  | Verify service name and that it's enabled       |
| "Tool not found"     | Check tool exists with `/services/{name}/tools` |
| "Session timeout"    | Increase `session_timeout` or `default_timeout` |
| Tools not appearing  | Verify `services` config includes the service   |
### See Also
| Topic           | Reference                                |
| Built-in Skills | [Built-in Skills][built-in-skills]       |
| SWAIG Functions | [Defining Functions][defining-functions] |
