Development Environment Setup
The project layout varies by language. Here are the recommended structures:
my-agent-project/
├── venv/ # Virtual environment
├── agents/ # Your agent modules
│ ├── __init__.py
│ ├── customer_service.py
│ └── support_agent.py
├── skills/ # Custom skills (optional)
│ └── my_custom_skill/
│ ├── __init__.py
│ └── skill.py
├── tests/ # Test files
│ ├── __init__.py
│ └── test_agents.py
├── .env # Environment variables (not in git)
├── .env.example # Example env file (in git)
├── .gitignore
├── requirements.txt
└── main.py # Entry point
Create the Project
## Create project directory
mkdir my-agent-project
cd my-agent-project
## Create virtual environment
python -m venv venv
source venv/bin/activate # Windows: venv\Scripts\activate
## Install dependencies
pip install signalwire-sdk
## Create directory structure
mkdir -p agents skills tests
## Create initial files
touch agents/__init__.py
touch tests/__init__.py
touch .env .env.example .gitignore requirements.txt main.py
Environment Variables
Create a .env file for configuration:
## .env - DO NOT COMMIT THIS FILE
## Authentication
## These set your agent's basic auth credentials.
## If not set, SDK uses username "signalwire" with an auto-generated
## password that changes on every invocation (printed to console).
SWML_BASIC_AUTH_USER=my_username
SWML_BASIC_AUTH_PASSWORD=my_secure_password_here
## Server Configuration
SWML_PROXY_URL_BASE=https://my-agent.ngrok.io
## SSL (optional, for production)
SWML_SSL_ENABLED=false
SWML_SSL_CERT_PATH=
SWML_SSL_KEY_PATH=
## Skill API Keys (as needed)
GOOGLE_API_KEY=your_google_api_key
GOOGLE_CX_ID=your_custom_search_id
WEATHER_API_KEY=your_weather_api_key
## Logging
SIGNALWIRE_LOG_MODE=default
Important: The SWML_BASIC_AUTH_USER and SWML_BASIC_AUTH_PASSWORD environment variables let you set stable credentials for your agent. Without these:
  • Username defaults to signalwire
  • Password is randomly generated on each startup
  • The generated password is printed to the console
For development, you can leave these unset and use the printed credentials. For production, always set explicit values.
Create .env.example as a template (safe to commit):
## .env.example - Template for environment variables
## Authentication (optional - SDK generates credentials if not set)
## Skill API Keys
GOOGLE_API_KEY=
WEATHER_API_KEY=
Loading Environment Variables
Install python-dotenv:
pip install python-dotenv
Load in your agent:
#!/usr/bin/env python3
## main.py - Main entry point with environment loading
"""Main entry point with environment loading."""
import os
from dotenv import load_dotenv
## Load environment variables from .env file
load_dotenv()
from agents.customer_service import CustomerServiceAgent
def main():
agent = CustomerServiceAgent()
# Use environment variables
host = os.getenv("AGENT_HOST", "0.0.0.0")
port = int(os.getenv("AGENT_PORT", "3000"))
print(f"Starting agent on {host}:{port}")
agent.run(host=host, port=port)
main()
The .gitignore File
## Virtual environment
venv/
.venv/
env/
## Environment variables
.env
.env.local
.env.*.local
## Python
__pycache__/
*.py[cod]
*$py.class
*.so
.Python
build/
dist/
*.egg-info/
## IDE
.idea/
.vscode/
*.swp
*.swo
## Testing
.pytest_cache/
.coverage
htmlcov/
## Logs
*.log
## OS
.DS_Store
Thumbs.db
Requirements File
Create requirements.txt:
signalwire-sdk
python-dotenv>=1.0.0
Or generate from current environment:
pip freeze > requirements.txt
IDE Configuration
VS Code
Create .vscode/settings.json:
"python.defaultInterpreterPath": "${workspaceFolder}/venv/bin/python",
"python.envFile": "${workspaceFolder}/.env",
"python.testing.pytestEnabled": true,
"python.testing.pytestArgs": ["tests"],
"editor.formatOnSave": true,
"python.formatting.provider": "black"
Create .vscode/launch.json for debugging:
"version": "0.2.0",
"configurations": [
"name": "Run Agent",
"type": "python",
"request": "launch",
"program": "${workspaceFolder}/main.py",
"console": "integratedTerminal",
"envFile": "${workspaceFolder}/.env"
"name": "Run Current File",
"type": "python",
"program": "${file}",
"name": "Test Agent with swaig-test",
"type": "python",
"module": "signalwire.cli.test_swaig",
"args": ["${file}", "--dump-swml"],
PyCharm
  1. Open Settings -> Project -> Python Interpreter
  2. Select your virtual environment
  3. Go to Run -> Edit Configurations
  4. Create a Python configuration:
    • Script path: main.py
    • Working directory: Project root
    • Environment variables: Load from .env
Using swaig-test for Development
The swaig-test CLI is essential for development:
## View SWML output (formatted)
swaig-test agents/customer_service.py --dump-swml
## View raw SWML JSON
swaig-test agents/customer_service.py --dump-swml --raw
## List all registered functions
swaig-test agents/customer_service.py --list-tools
## Execute a specific function
swaig-test agents/customer_service.py --exec get_customer --customer_id 12345
## Simulate serverless environment
swaig-test agents/customer_service.py --simulate-serverless lambda --dump-swml
Development Workflow
1. Edit Code
Modify your agent in agents/.
2. Quick Test
  • swaig-test agents/my_agent.py --dump-swml
  • Verify SWML looks correct
3. Function Test
  • swaig-test agents/my_agent.py --exec my_function --param_name value
  • Verify function returns expected result
4. Run Server
  • python main.py
  • curl http://localhost:3000/
5. Integration Test
  • Start ngrok (see next section)
  • Configure SignalWire webhook
  • Make test call
Sample Agent Module
## customer_service.py - Customer service agent
Customer Service Agent
A production-ready customer service agent template.
import os
class CustomerServiceAgent(AgentBase):
"""Customer service voice AI agent."""
super().__init__(
name="customer-service",
route="/",
host="0.0.0.0",
port=int(os.getenv("AGENT_PORT", "3000"))
self._configure_voice()
self._configure_prompts()
self._configure_functions()
def _configure_voice(self):
"""Set up voice and language."""
self.set_params({
"end_of_speech_timeout": 500,
"attention_timeout": 15000,
self.add_hints([
"account",
"billing",
"support",
"representative"
def _configure_prompts(self):
"""Set up AI prompts."""
self.prompt_add_section(
"Role",
"You are a helpful customer service representative for Acme Corp. "
"Help customers with their questions about accounts, billing, and products."
"Guidelines",
body="Follow these guidelines:",
bullets=[
"Be professional and courteous",
"Ask clarifying questions when needed",
"Offer to transfer to a human if you cannot help",
"Keep responses concise"
def _configure_functions(self):
"""Register SWAIG functions."""
self.define_tool(
name="lookup_account",
description="Look up a customer account by phone number or account ID",
parameters={
"type": "object",
"properties": {
"identifier": {
"type": "string",
"description": "Phone number or account ID"
"required": ["identifier"]
handler=self.lookup_account
self.define_tool(
name="transfer_to_human",
description="Transfer the call to a human representative",
handler=self.transfer_to_human
def lookup_account(self, args, raw_data):
"""Look up account information."""
identifier = args.get("identifier", "")
# In production, query your database here
return FunctionResult(
f"Found account for {identifier}: Status is Active, Balance is $0.00"
def transfer_to_human(self, args, raw_data):
"""Transfer to human support."""
"Transferring you to a human representative now."
).connect("+15551234567", final=True, from_addr="+15559876543")
## Allow running directly for testing
Testing Your Agent
## test_agents.py - Tests for agents
"""Tests for agents."""
import pytest
class TestCustomerServiceAgent:
"""Test customer service agent."""
def setup_method(self):
"""Set up test fixtures."""
self.agent = CustomerServiceAgent()
def test_agent_name(self):
"""Test agent has correct name."""
assert self.agent.name == "customer-service"
def test_lookup_account(self):
"""Test account lookup function."""
result = self.agent.lookup_account(
{"identifier": "12345"},
assert "Found account" in result
def test_has_functions(self):
"""Test agent has expected functions."""
functions = self.agent._tool_registry.get_function_names()
assert "lookup_account" in functions
assert "transfer_to_human" in functions
Run tests:
pytest tests/ -v
Next Steps
Your development environment is ready. Now let’s expose your agent to the internet so SignalWire can reach it.
