Prompts & POM
Why POM?
AspectRaw Text PromptPOM Structured Prompt
FormatOne long stringOrganized sections with body, bullets, subsections
MaintainabilityHard to maintainEasy to modify individual sections
StructureNo structureClear hierarchy (Role -> Guidelines -> Rules)
ExtensibilityDifficult to extendReusable components
Raw Text Problems:
  • Everything mixed together in one string
  • Hard to find and update specific instructions
  • Difficult to share sections between agents
POM Benefits:
  • Sections keep concerns separated
  • Bullets make lists scannable
  • Subsections add depth without clutter
  • Renders to clean, formatted markdown
POM Structure
POM hierarchy structure.
POM Hierarchy
Adding Sections
Basic Section with Body
The prompt_add_section method is the primary way to build prompts:
class MyAgent(AgentBase):
# Simple section with body text
self.prompt_add_section(
"Role",
"You are a helpful customer service representative for Acme Corp."
Section with Bullets
Adding bullets to a section follows a similar pattern across languages:
LanguageSyntax
Pythonprompt_add_section("Title", body="text", bullets=[...])
TypeScriptpromptAddSection('Title', { body: 'text', bullets: [...] })
## Section with bullet points
"Guidelines",
body="Follow these guidelines when speaking with customers:",
bullets=[
"Be professional and courteous at all times",
"Ask clarifying questions when the request is unclear",
"Keep responses concise - this is a voice conversation",
"Offer to transfer to a human if you cannot help"
Section with Numbered Bullets
## Use numbered list instead of bullets
"Process",
body="Follow this process for each call:",
bullets=[
"Greet the customer warmly",
"Identify the reason for their call",
"Resolve the issue or transfer",
"Thank them and end the call"
numbered_bullets=True # 1. 2. 3. instead of bullets
Subsections
Add nested structure within sections:
## First, create the parent section
"Policies",
body="Follow company policies in these areas:"
## Then add subsections
self.prompt_add_subsection(
"Policies", # Parent section title
"Returns", # Subsection title
body="For return requests:",
bullets=[
"Items can be returned within 30 days",
"Receipt is required for cash refunds",
"Exchanges are always available"
"Policies",
"Billing",
body="For billing inquiries:",
bullets=[
"Verify customer identity first",
"Review last 3 statements",
"Offer payment plans if needed"
Declarative Prompts (PROMPT_SECTIONS)
Define prompts declaratively as a class attribute:
class DeclarativeAgent(AgentBase):
PROMPT_SECTIONS = {
"Role": "You are a friendly assistant for a pizza restaurant.",
"Menu Knowledge": [
"Small pizza: $10",
"Medium pizza: $14",
"Large pizza: $18",
"Toppings: $1.50 each"
"Order Process": {
"body": "When taking orders:",
"bullets": [
"Confirm the size first",
"List available toppings",
"Repeat the order back",
"Provide total price"
"Policies": {
"body": "Restaurant policies:",
"subsections": [
"title": "Delivery",
"body": "Delivery information:",
"bullets": [
"Free delivery over $25",
"$5 fee under $25",
"30-45 minute delivery time"
"title": "Pickup",
"bullets": [
"Ready in 15-20 minutes",
"Call when you arrive"
super().__init__(name="pizza-agent")
POM Builder Direct Access
For advanced use, access the POM builder directly:
class AdvancedAgent(AgentBase):
super().__init__(name="advanced-agent")
# Direct POM access
self.pom.section("Role").body(
"You are an expert technical support agent."
self.pom.section("Expertise").bullets([
"Network troubleshooting",
"Software installation",
"Hardware diagnostics"
# Chain multiple calls
(self.pom
.section("Process")
.body("Follow these steps:")
.numbered_bullets([
"Identify the issue",
"Run diagnostics",
"Apply solution",
"Verify resolution"
Post-Call Prompts
Post-prompts run after a call ends, allowing the AI to generate summaries, extract data, or create structured output from the conversation.
When Post-Prompts Run
Post-prompts execute:
  • After the caller hangs up
  • After a transfer completes
  • After an inactivity timeout
  • Before any post-call webhooks fire
The AI has access to the full conversation history when generating the post-prompt response.
set_post_prompt() vs set_post_prompt_data()
Use set_post_prompt() for simple text instructions:
LanguageSyntax
Pythonself.set_post_prompt("Summarize this call...")
TypeScriptagent.setPostPrompt('Summarize this call...')
"Summarize this call including: "
"1) The customer's issue "
"2) How it was resolved "
"3) Any follow-up needed"
Use set_post_prompt_data() for full control over generation parameters:
self.set_post_prompt_data({
"text": "Generate a detailed call summary.",
"temperature": 0.3,
"top_p": 0.9
Post-Prompt Data Options
FieldTypeDefaultDescription
textstringRequiredThe post-prompt instruction
temperaturefloat0.3Creativity level (0-2, lower = more consistent)
top_pfloat1.0Nucleus sampling threshold
max_tokensint256Maximum output length
Common Post-Prompt Use Cases
Call summarization:
"Summarize this call in 2-3 sentences. Include the main topic, "
"outcome, and any commitments made."
Structured data extraction:
"text": """
Extract from this conversation and format as JSON:
"customer_name": "name if mentioned",
"issue_category": "billing|technical|sales|general",
"resolution": "resolved|escalated|pending|unknown",
"follow_up_required": true/false,
"sentiment": "positive|neutral|negative"
"temperature": 0.1 # Low for consistent structure
CRM notes:
"Generate CRM notes for this call. Include: "
"- Customer inquiry summary "
"- Actions taken by agent "
"- Next steps or follow-up items "
"- Any account changes discussed"
Compliance logging:
"Log compliance-relevant details: "
"- Was identity verified? "
"- What sensitive data was discussed? "
"- Were required disclosures given? "
"- Any compliance concerns noted?"
Post-Prompt Best Practices
DO:
  • Use low temperature (0.1-0.3) for structured extraction
  • Keep instructions clear and specific
  • Test with various conversation types
  • Use JSON format for machine-readable output
DON’T:
  • Expect post-prompt to modify call behavior (call already ended)
  • Use high temperature for data extraction
  • Request very long outputs (increases latency)
  • Assume all fields will always be populated
Voice-Optimized Prompts
Write prompts optimized for voice conversations:
class VoiceOptimizedAgent(AgentBase):
super().__init__(name="voice-agent")
"Voice Guidelines",
body="Optimize all responses for voice:",
bullets=[
"Keep sentences short - under 20 words",
"Avoid technical jargon unless necessary",
"Use conversational language, not formal",
"Pause naturally between topics",
"Don't list more than 3 items at once",
"Spell out acronyms on first use"
"Response Style",
bullets=[
"Start responses with the key information",
"Confirm understanding before long explanations",
"Ask 'Does that make sense?' after complex topics",
"Use filler words naturally: 'Let me check that for you'"
1. Lead with Role Definition
## Good - clear role first
"Role",
"You are Sarah, a senior customer service representative "
"at TechCorp with 5 years of experience helping customers "
"with software products."
2. Separate Concerns
## Good - each section has one purpose
self.prompt_add_section("Role", "...")
self.prompt_add_section("Knowledge", "...")
self.prompt_add_section("Guidelines", "...")
self.prompt_add_section("Restrictions", "...")
## Bad - everything mixed together
self.prompt_add_section("Instructions",
"You are an agent. Be nice. Don't share secrets. "
"You know about products. Follow the rules..."
3. Use Bullets for Lists
## Good - scannable bullets
"Products",
body="You can help with these products:",
bullets=["Basic Plan - $10/mo", "Pro Plan - $25/mo", "Enterprise - Custom"]
## Bad - inline list
"Products",
"Products include Basic Plan at $10/mo, Pro Plan at $25/mo, "
"and Enterprise with custom pricing."
4. Be Specific About Restrictions
## Good - explicit restrictions
"Restrictions",
bullets=[
"Never share customer passwords or security codes",
"Do not process refunds over $500 without transfer",
"Cannot modify account ownership",
"Must verify identity before account changes"
Generated Prompt Output
POM converts your structure to formatted text:
## Role
You are Sarah, a customer service representative for Acme Corp.
## Guidelines
Follow these guidelines:
* Be professional and courteous
* Ask clarifying questions when needed
* Keep responses concise for voice
## Policies
### Returns
* Items can be returned within 30 days
* Receipt required for cash refunds
### Billing
* Verify customer identity first
* Review recent statements
