AgentBase
What You’ll Learn
This chapter covers everything you need to build production-quality agents:
  1. AgentBase - The foundation class and its capabilities
  2. Static vs Dynamic - Choosing the right pattern for your use case
  3. Prompts & POM - Crafting effective prompts with the Prompt Object Model
  4. Voice & Language - Configuring voices and multi-language support
  5. AI Parameters - Tuning conversation behavior
  6. Hints - Improving speech recognition accuracy
  7. Call Flow - Customizing when and how calls are answered
Prerequisites
Before building agents, you should understand:
  • Core concepts from Chapter 2 (SWML, SWAIG, Lifecycle)
  • Basic Python class structure
  • How SignalWire processes calls
Agent Architecture Overview
Agent components overview.
Agent Components
A Complete Agent Example
Here’s what a production agent looks like across all supported languages:
class CustomerSupportAgent(AgentBase):
"""Production customer support agent."""
super().__init__(
name="customer-support",
route="/support"
# Voice configuration
# AI behavior
self.set_params({
"end_of_speech_timeout": 500,
"attention_timeout": 15000,
"inactivity_timeout": 30000
# Prompts
self.prompt_add_section(
"Role",
"You are Alex, a friendly customer support agent for Acme Inc."
"Guidelines",
body="Follow these guidelines:",
bullets=[
"Be helpful and professional",
"Ask clarifying questions when needed",
"Keep responses concise for voice",
"Offer to transfer if you cannot help"
# Speech recognition hints
self.add_hints([
"Acme", "account number", "order status",
"refund", "billing", "representative"
# Functions
self.define_tool(
name="check_order",
description="Look up an order by order number",
parameters={
"type": "object",
"properties": {
"order_number": {
"type": "string",
"description": "The order number to look up"
"required": ["order_number"]
handler=self.check_order
# Skills
self.add_skill("datetime")
# Post-call summary
self.set_post_prompt(
"Summarize: issue type, resolution, customer satisfaction"
def check_order(self, args, raw_data):
order_number = args.get("order_number")
return FunctionResult(
f"Order {order_number}: Shipped on Monday, arriving Thursday"
agent = CustomerSupportAgent()
agent.run(host="0.0.0.0", port=3000)
Chapter Contents
SectionDescription
AgentBaseCore class and constructor options
Static vs DynamicChoosing the right pattern
Prompts & POMPrompt engineering for voice AI
Voice & LanguageVoice selection and multi-language
AI ParametersBehavior tuning
HintsSpeech recognition improvement
Call FlowCustomizing call answer behavior
Key Patterns
Pattern 1: Class-Based Agent
Best for complex agents with multiple functions:
class MyAgent(AgentBase):
self.configure()
def configure(self):
# All configuration here
pass
Pattern 2: Functional Agent
Quick agents for simple use cases:
LanguageFunctional Agent
Pythonagent = AgentBase(name="simple-agent")
TypeScriptconst agent = new AgentBase({ name: "simple-agent" })
agent.prompt_add_section("Role", "You are a helpful assistant.")
Pattern 3: Multi-Agent Server
Multiple agents on one server:
from signalwire import AgentServer
server = AgentServer()
server.register(SupportAgent(), "/support")
server.register(BillingAgent(), "/billing")
server.run(port=3000)
Testing Your Agent
Always test before deploying:
# View SWML output
# List registered functions
swaig-test my_agent.py --list-tools
# Test a function
swaig-test my_agent.py --exec check_order --order_number 12345
Class Overview
AgentBase inheritance diagram.
AgentBase Inheritance
Constructor Parameters
The constructor accepts the agent name plus optional configuration:
LanguageConstructor Syntax
PythonAgentBase(name="my-agent", route="/", port=3000)
TypeScriptnew AgentBase({ name: "my-agent", route: "/", port: 3000 })
Full Python constructor with all options:
agent = AgentBase(
# Required
name="my-agent", # Unique agent identifier
# Server Configuration
route="/", # HTTP route path (default: "/")
host="0.0.0.0", # Bind address (default: "0.0.0.0")
port=3000, # Server port (default: 3000)
# Authentication
basic_auth=("user", "pass"), # Override env var credentials
# Behavior
auto_answer=True, # Answer calls automatically
use_pom=True, # Use Prompt Object Model
# Recording
record_call=False, # Enable call recording
record_format="mp4", # Recording format
record_stereo=True, # Stereo recording
# Tokens and Security
token_expiry_secs=3600, # Function token expiration
# Advanced
default_webhook_url=None, # Override webhook URL
agent_id=None, # Custom agent ID (auto-generated)
native_functions=None, # Built-in SignalWire functions
schema_path=None, # Custom SWML schema path
suppress_logs=False, # Disable logging
config_file=None # Load from config file
Parameter Reference
ParameterTypeDefaultDescription
namestrRequiredUnique identifier for the agent
routestr”/“HTTP route where agent is accessible
hoststr”0.0.0.0”IP address to bind server
portint3000Port number for server
basic_authtupleNone(username, password) for auth
use_pomboolTrueEnable Prompt Object Model
auto_answerboolTrueAuto-answer incoming calls
record_callboolFalseEnable call recording
record_formatstr”mp4”Recording file format
record_stereoboolTrueRecord in stereo
token_expiry_secsint3600Token validity period
native_functionslistNoneSignalWire native functions
suppress_logsboolFalseDisable agent logs
Creating an Agent
self._setup()
def _setup(self):
self.define_tool(name="greet", description="Greet the user", parameters={}, handler=self.greet)
def greet(self, args, raw_data):
return FunctionResult("Hello! How can I help you today?")
agent = MyAgent()
Method 2: Instance-Based
agent = AgentBase(name="quick-agent")
Method 3: Declarative (PROMPT_SECTIONS)
class DeclarativeAgent(AgentBase):
PROMPT_SECTIONS = {
"Role": "You are a helpful customer service agent.",
"Guidelines": [
"Be professional and courteous",
"Keep responses concise"
"Rules": {
"body": "Always follow these rules:",
"bullets": [
"Never share customer data",
"Escalate complex issues"
super().__init__(name="declarative-agent")
Key Methods
Configuration Methods
MethodPython
Add languageadd_language(name, code, voice)
Add promptprompt_add_section(title, body)
Set paramsset_params(dict)
Add hintsadd_hints(list)
Define tooldefine_tool(name=..., handler=fn)
Post-promptset_post_prompt(text)
# Voice and Language
agent.add_language(name, code, voice) # Add language support
agent.set_languages(languages) # Set all languages at once
# Prompts
agent.prompt_add_section(title, body) # Add prompt section
agent.prompt_add_subsection(parent, title) # Add subsection
agent.set_post_prompt(text) # Set post-call summary prompt
# AI Parameters
agent.set_params(params_dict) # Set AI behavior parameters
agent.set_param_value(key, value) # Set single parameter
# Speech Recognition
agent.add_hints(hints_list) # Add speech hints
agent.add_hint(hint_string) # Add single hint
# Functions
agent.define_tool(name, description, ...) # Define SWAIG function
agent.add_skill(skill_name) # Add a skill
# Pronunciation
agent.add_pronunciation(replace, with_text) # Add pronunciation rule
Runtime Methods
# Start server
# Get SWML document
swml = agent.get_swml()
# Access components
agent.pom # Prompt Object Model
agent.data_map # DataMap builder
Agent Lifecycle
Agent lifecycle.
Agent Lifecycle
Configuration File
Load configuration from a YAML/JSON file:
agent = AgentBase(
name="my-agent",
config_file="config/agent.yaml"
# config/agent.yaml
route: /support
host: 0.0.0.0
port: 3000
Environment Variables
AgentBase respects these environment variables:
VariablePurpose
SWML_BASIC_AUTH_USERBasic auth username
SWML_BASIC_AUTH_PASSWORDBasic auth password
SWML_PROXY_URL_BASEBase URL for webhooks behind proxy
SWML_SSL_ENABLEDEnable SSL
SWML_SSL_CERT_PATHSSL certificate path
SWML_SSL_KEY_PATHSSL key path
SWML_DOMAINDomain for SSL
Multi-Agent Server
Run multiple agents on one server:
super().__init__(name="support", route="/support")
class SalesAgent(AgentBase):
super().__init__(name="sales", route="/sales")
server.register(SupportAgent())
server.register(SalesAgent())
server.run(host="0.0.0.0", port=3000)
Access agents at:
  • http://localhost:3000/support
  • http://localhost:3000/sales
Best Practices
  1. Use class-based agents for anything beyond simple prototypes
  2. Organize configuration into logical private methods
  3. Set explicit credentials in production via environment variables
  4. Use meaningful agent names for logging and debugging
  5. Test with swaig-test before deploying
class WellOrganizedAgent(AgentBase):
super().__init__(name="organized-agent")
self._configure_voice()
self._configure_prompts()
self._configure_functions()
self._configure_skills()
def _configure_voice(self):
self.set_params({"end_of_speech_timeout": 500, "attention_timeout": 15000})
def _configure_prompts(self):
def _configure_functions(self):
self.define_tool(name="help", description="Get help", parameters={}, handler=self.get_help)
def _configure_skills(self):
def get_help(self, args, raw_data):
return FunctionResult("I can help you with...")
