Skills
What You’ll Learn
This chapter covers the skills system:
  1. Understanding Skills - What skills are and how they work
  2. Built-in Skills - Pre-built skills available in the SDK
  3. Adding Skills - How to add skills to your agents
  4. Custom Skills - Creating your own skills
  5. Skill Configuration - Parameters and advanced options
What Are Skills?
Skills are pre-packaged capabilities that add:
  • Functions - SWAIG tools the AI can call
  • Prompts - Instructions for how to use the skill
  • Hints - Speech recognition keywords
  • Global Data - Variables available throughout the call
Without SkillsWith Skills
Write weather functionagent.add_skill("weather")
Add API integration
Write promptsDone!
Add speech hints
Handle errors
The add_skill() method is available across all SDK languages:
LanguageSyntax
Pythonagent.add_skill("weather")
TypeScriptawait agent.addSkillByName('weather_api')
Quick Start
Add a skill in one line:
class MyAgent(AgentBase):
# Add datetime capability
self.add_skill("datetime")
# Add math capability
self.add_skill("math")
self.prompt_add_section(
"Role",
"You are a helpful assistant that can tell time and do math."
Available Built-in Skills
SkillDescription
datetimeGet current date and time
mathPerform calculations
web_searchSearch the web (requires API key)
wikipedia_searchSearch Wikipedia
weather_apiGet weather information
jokeTell jokes
play_background_filePlay audio files
swml_transferTransfer calls to SWML endpoints
datasphereSearch DataSphere documents
native_vector_searchLocal vector search
mcp_gatewayConnect to MCP server tools
google_mapsAddress validation and routing
info_gathererStructured question collection
claude_skillsLoad SKILL.md files as tools
api_ninjas_triviaTrivia questions from API Ninjas
ask_claudeAnthropic Claude reasoning / sub-queries
custom_skillsRegister one-off SWAIG tools from config
datasphere_serverlessDataSphere search via serverless DataMap
spiderWeb scraping and crawling
Chapter Contents
SectionDescription
Understanding SkillsHow skills work internally
Built-in SkillsReference for included skills
Adding SkillsHow to use skills in your agents
Custom SkillsCreating your own skills
Skill ConfigurationParameters and advanced options
Skills vs Functions
AspectSWAIG FunctionSkill
ScopeSingle functionMultiple functions + prompts + hints
ReusabilityPer-agentAcross all agents
Setupdefine_tool()add_skill()
CustomizationFull controlParameters only
MaintenanceYou maintainSDK maintains
The add_skill() vs define_tool() distinction applies across all languages:
Languageadd_skilldefine_tool
Pythonagent.add_skill("name")agent.define_tool(...)
TypeScriptawait agent.addSkillByName('name')agent.defineTool(...)
When to Use Skills
Use Built-in Skills When:
  • Standard capability needed (datetime, search, etc.)
  • Want quick setup without custom code
  • Need tested, maintained functionality
Create Custom Skills When:
  • Reusing capability across multiple agents
  • Want to share functionality with team/community
  • Packaging complex integrations
Use SWAIG Functions When:
  • One-off custom logic
  • Agent-specific business rules
  • Need full control over implementation
Complete Example
#!/usr/bin/env python3
# assistant_agent.py - Agent with multiple skills
class AssistantAgent(AgentBase):
super().__init__(name="assistant")
# Add multiple skills
"Role",
"You are a helpful assistant named Alex."
"Capabilities",
body="You can help with:",
bullets=[
"Telling the current date and time",
"Performing math calculations"
agent = AssistantAgent()
Let’s start by understanding how skills work internally.
Skill Architecture
Skill loading process diagram.
Skill Loading Process
SkillBase (Abstract Base Class)
Required Methods:
  • setup() - Initialize the skill
  • register_tools() - Register SWAIG functions
Optional Methods:
  • get_hints() - Speech recognition hints
  • get_global_data() - Session data
  • get_prompt_sections() - Prompt additions
  • cleanup() - Resource cleanup
SkillRegistry (Discovery & Loading)
  • Discovers skills from directories
  • Loads skills on-demand (lazy loading)
  • Validates requirements (packages, env vars)
  • Supports external skill paths
How Skills Work
Skills are a convenience layer built on top of SWAIG functions. When you add a skill, it registers one or more SWAIG functions with the agent, adds relevant prompts, and configures hints — all from a single add_skill() call.
Understanding this helps when debugging: a skill’s function behaves exactly like a SWAIG function you’d define yourself. The only difference is that the skill packages everything together.
Skill Directory Structure
Built-in skills live in the SDK:
signalwire/
skills/
datetime/
__init__.py
skill.py
math/
__init__.py
skill.py
web_search/
__init__.py
skill.py
requirements.txt
Each skill directory contains:
FilePurpose
skill.pySkill class implementation
__init__.pyPython package marker
requirements.txtOptional extra dependencies
SkillBase Class
All skills inherit from SkillBase. The pattern is similar across all SDK languages:
LanguagePattern
Pythonclass MySkill(SkillBase): def setup(self, agent): ...
TypeScriptclass MySkill extends SkillBase { async setup() { ... return true; } }
from signalwire.skills import SkillBase
# Required class attributes
SKILL_NAME = "my_skill"
SKILL_DESCRIPTION = "Does something useful"
SKILL_VERSION = "1.0.0"
# Optional requirements
REQUIRED_PACKAGES = [] # Python packages needed
REQUIRED_ENV_VARS = [] # Environment variables needed
# Multi-instance support
SUPPORTS_MULTIPLE_INSTANCES = False
def setup(self) -> bool:
"""Initialize the skill. Return True if successful."""
return True
def register_tools(self) -> None:
"""Register SWAIG tools with the agent."""
self.define_tool(
name="my_function",
description="Does something",
parameters={},
handler=self.my_handler
"""Handle function calls."""
return FunctionResult("Result")
Skill Lifecycle
Discover -> Load -> Setup -> Register -> Active -> Cleanup
StageDescription
DiscoverRegistry finds skill class in directory
LoadSkill class is imported and validated
Setupsetup() validates requirements, initializes resources
Registerregister_tools() adds functions to agent
ActiveSkill is ready, functions can be called
Cleanupcleanup() releases resources on shutdown
Skill Contributions
Skills can contribute to the agent in multiple ways:
1. Tools (Functions)
self.define_tool(
name="get_time",
description="Get current time",
parameters={
"timezone": {
"type": "string",
"description": "Timezone name"
handler=self.get_time_handler
2. Prompt Sections
def get_prompt_sections(self):
return [
"title": "Time Information",
"body": "You can tell users the current time.",
"bullets": [
"Use get_time for time queries",
"Support multiple timezones"
3. Speech Hints
def get_hints(self):
return ["time", "date", "clock", "timezone"]
4. Global Data
def get_global_data(self):
return {
"datetime_enabled": True,
"default_timezone": "UTC"
Skill Discovery Paths
Skills are discovered from multiple locations in priority order:
PrioritySourceExample
1Already registered skills (in memory)-
2Entry points (pip installed packages)entry_points={'signalwire.skills': ['my_skill = pkg:Skill']}
3Built-in skills directorysignalwire/skills/
4External pathsskill_registry.add_skill_directory('/opt/custom_skills')
5Environment variable pathsSIGNALWIRE_SKILL_PATHS=/path1:/path2
Lazy Loading
Skills are loaded on-demand to minimize startup time:
# Skill NOT loaded yet
agent = MyAgent()
# Skill loaded when first referenced
agent.add_skill("datetime") # datetime skill loaded here
# Already loaded, reused
agent.add_skill("datetime") # Uses cached class
Multi-Instance Skills
Some skills support multiple instances with different configurations:
SUPPORTS_MULTIPLE_INSTANCES = True
def get_instance_key(self) -> str:
# Unique key for this instance
tool_name = self.params.get('tool_name', self.SKILL_NAME)
return f"{self.SKILL_NAME}_{tool_name}"
Usage across languages:
LanguageAdding multiple instances
Pythonagent.add_skill("web_search", {"tool_name": "search_news", "api_key": "KEY"})
TypeScriptawait agent.addSkillByName('web_search', { tool_name: 'search_news', api_key: 'KEY' })
# Add two instances with different configs
"search_engine_id": "NEWS_ENGINE_ID",
"api_key": "KEY"
"tool_name": "search_docs",
"search_engine_id": "DOCS_ENGINE_ID",
"api_key": "KEY"
Parameter Passing
Parameters flow through skills in a structured way:
At add_skill() time:
self.add_skill("web_search", {
"api_key": "your-key",
"tool_name": "custom_search",
"max_results": 5
The skill receives these in self.params during setup:
self.api_key = self.params.get("api_key")
self.max_results = self.params.get("max_results", 3)
return True
At function call time: The AI calls the function with arguments:
def search_handler(self, args, raw_data):
query = args.get("query") # From AI's function call
max_results = self.max_results # From skill config
Result Handling
Skill handlers return FunctionResult just like regular SWAIG functions:
# Success case
return FunctionResult("The result is 42")
# With actions
return (
FunctionResult("Updated your preferences")
.update_global_data({"preference": "value"})
# Error case - still return a result for the AI
return FunctionResult("I couldn't complete that request. Please try again.")
The result goes back to the AI, which uses it to formulate a response to the user.
Error Handling and Propagation
Skills should handle errors gracefully and return meaningful messages:
def api_handler(self, args, raw_data):
try:
result = self.call_external_api(args)
return FunctionResult(f"Result: {result}")
except requests.Timeout:
"The service is taking too long to respond. Please try again."
except requests.RequestException as e:
self.agent.log.error(f"API error: {e}")
"I'm having trouble connecting to the service right now."
except Exception as e:
self.agent.log.error(f"Unexpected error: {e}")
"Something went wrong. Please try again."
Error handling principles:
  • Always return a FunctionResult, even on errors
  • Make error messages user-friendly (the AI will relay them)
  • Log technical details for debugging
  • Don’t expose internal errors to users
Debugging Skills
When skills don’t work as expected:
1. Check if the skill loaded:
# In your agent
print(f"Skills loaded: {list(self._skill_manager._skills.keys())}")
2. Verify functions are registered:
swaig-test your_agent.py --dump-swml | grep -A 5 "functions"
3. Test the function directly:
swaig-test your_agent.py --exec skill_function_name --param "value"
4. Check for missing requirements: Skills log warnings if required packages or environment variables are missing. Check your logs during agent startup.
5. Look at skill source: Built-in skills are in the SDK source. Examine them to understand how they work:
pip show signalwire
# Find location, then look in signalwire/skills/
