Mapping Numbers
SignalWire uses SWML Script resources to connect phone numbers to your agent. When a call comes in, SignalWire fetches SWML from your agent’s URL and executes it.
Caller dials a SignalWire number and the call is routed to your agent.
Caller dials
Step 1: Create a SWML Script Resource
  1. Log in to SignalWire dashboard
  2. Navigate to My Resources in the left sidebar
  3. Click Script
  4. Click New SWML Script
  5. Fill in the fields:
    • Name: Give your script a name (e.g., “my-agent”)
    • Handle Calls Using: Select External URL
    • Primary Script URL: Enter your agent URL with credentials
      • Format: https://user:pass@your-domain.com/agent
  6. Click Create
Creating a new SWML Script resource in the SignalWire dashboard.
New SWML Script
Step 2: Add a Phone Number or Address
After creating the script, you’ll see the resource configuration page.
Resource configuration page in the SignalWire dashboard.
Back to Resources
  1. Click the Addresses & Phone Numbers tab
  2. Click + Add
  3. Choose your address type:
    • Phone Number: For receiving calls from regular phones (PSTN)
    • SIP Address: For receiving SIP calls
    • Alias: For referencing this resource by a custom name
  4. Follow the prompts to select or purchase a phone number
  5. Your number is now connected to your agent!
Adding a phone number or address to a SWML Script resource.
Add an Address
Step 3: Test Your Setup
  1. Ensure your agent is running locally
  2. Ensure ngrok is running (if using tunneling)
  3. Call your SignalWire phone number
  4. Hear your agent respond!
URL Format
Your agent URL structure depends on your setup:
Single Agent:
https://your-server.com/
Multiple Agents:
https://your-server.com/support
https://your-server.com/sales
https://your-server.com/billing
With Authentication (recommended):
https://user:pass@your-server.com/
Using ngrok for Development
# Start your agent locally
python my_agent.py
# In another terminal, start ngrok
ngrok http 3000
# Use the ngrok HTTPS URL in SignalWire
# https://abc123.ngrok.io
For a static URL that doesn’t change on restart:
ngrok http --url=https://your-name.ngrok-free.app 3000
Basic Authentication
The SDK automatically generates authentication credentials on startup:
Agent 'my-agent' is available at:
URL: http://localhost:3000
Basic Auth: signalwire:7vVZ8iMTOWL0Y7-BG6xaN3qhjmcm4Sf59nORNdlF9bs (source: generated)
For persistent credentials, set environment variables:
export SWML_BASIC_AUTH_USER=signalwire
export SWML_BASIC_AUTH_PASSWORD=your-secure-password
In SignalWire, use URL with credentials:
https://signalwire:your-secure-password@your-server.com/
Multi-Agent Server
Run multiple agents on one server:
LanguageServer Registration
Pythonserver.register(SupportAgent(), "/support")
TypeScriptserver.register(new SupportAgent(), "/support")
from signalwire import AgentServer
server = AgentServer()
# Register agents at different paths
server.register(BillingAgent(), "/billing")
server.run(host="0.0.0.0", port=3000)
Create a separate SWML Script resource for each agent:
NumberSWML Script URL
+1 (555) 111-1111https://server.com/support
+1 (555) 222-2222https://server.com/sales
+1 (555) 333-3333https://server.com/billing
Fallback URL
Configure a fallback for errors:
SettingValue
Primary URLhttps://your-server.com/agent
Fallback URLhttps://backup-server.com/agent
Fallback triggers on:
  • Connection timeout
  • HTTP 5xx errors
  • Invalid SWML response
Troubleshooting
Common Issues
SymptomLikely CauseFix
Connection errorsngrok not runningStart ngrok in a terminal
502 Bad GatewayWrong portMatch ngrok port to agent port
401 UnauthorizedAuth mismatchCheck credentials match agent output
502/503 errorsAgent crashedCheck agent terminal, restart
Test Checklist
# 1. Agent running?
curl http://localhost:3000/
# 2. Tunnel working?
curl https://your-name.ngrok-free.app/
# 3. Auth working?
curl https://user:pass@your-name.ngrok-free.app/
# 4. SWML valid?
swaig-test agent.py --dump-swml
Verification Checklist
Before going live:
  • Agent is deployed and running
  • HTTPS URL is accessible
  • URL returns valid SWML on POST request
  • Basic auth is configured
  • SWML Script resource created in SignalWire
  • Phone number added to SWML Script resource
  • Test call completes successfully
