Built-in Skills
Available Skills
SkillDescriptionRequirements
datetimeDate/time informationpytz
mathMathematical calculations(none)
web_searchWeb search via Google APIAPI key
wikipedia_searchWikipedia lookups(none)
weather_apiWeather informationAPI key
jokeTell jokes(none)
play_background_filePlay audio files(none)
swml_transferTransfer to SWML endpoint(none)
datasphereDataSphere document searchAPI credentials
native_vector_searchLocal vector searchsearch extras
mcp_gatewayMCP server integrationMCP Gateway service
google_mapsAddress validation & routingGoogle Maps API key
info_gathererStructured question collection(none)
claude_skillsLoad SKILL.md files as toolsPyYAML
api_ninjas_triviaTrivia questions from API NinjasAPI key
ask_claudeAnthropic Claude reasoning / sub-queriesANTHROPIC_API_KEY
custom_skillsRegister one-off SWAIG tools from config(none)
datasphere_serverlessDataSphere search via DataMap (no server callback)API credentials
spiderWeb scraping & crawlingcheerio (TS) / lxml (Python)
datetime
Get current date and time information with timezone support. This is one of the most commonly used skills — callers often ask “what time is it?” or need scheduling help.
Functions:
  • get_current_time - Get current time in a timezone
  • get_current_date - Get today’s date
Requirements: pytz package (usually installed automatically)
Parameters:
This skill takes no configuration parameters. Timezone is specified per call via the timezone argument on get_current_time; UTC is the default when omitted.
Output format:
  • Time: “The current time in America/New_York is 2:30 PM”
  • Date: “Today’s date is November 25, 2024”
Common use cases:
  • “What time is it?” / “What time is it in Tokyo?”
  • “What’s today’s date?”
  • Scheduling and appointment contexts
  • Time zone conversions
Limitations:
  • Requires valid timezone names (e.g., “America/New_York”, not “EST”)
  • Doesn’t do time math or calculate durations
  • Doesn’t handle historical dates
LanguageAdding datetime
Pythonself.add_skill("datetime")
TypeScriptawait agent.addSkillByName('datetime')
class TimeAgent(AgentBase):
super().__init__(name="time-agent")
self.prompt_add_section(
"Role",
"You help users with date and time information."
math
Perform mathematical calculations safely. The skill uses a secure expression evaluator that supports common operations without executing arbitrary code.
Functions:
  • calculate - Evaluate mathematical expressions
Requirements: None
Parameters:
This skill takes no configuration parameters. The registered tool is always named calculate.
Supported operations:
  • Basic: +, -, *, /, ** (power), % (modulo)
  • Functions: sqrt, sin, cos, tan, log, abs, round
  • Constants: pi, e
  • Parentheses for grouping
Common use cases:
  • “What’s 15 percent of 230?”
  • “Calculate 45 times 67”
  • “What’s the square root of 256?”
  • Price calculations, tip calculations
Limitations:
  • Limited to supported functions (no arbitrary Python)
  • Large numbers may lose precision
  • Can’t solve equations or do symbolic math
class CalculatorAgent(AgentBase):
super().__init__(name="calculator")
self.add_skill("math")
"Role",
"You are a calculator that helps with math."
Search the web using Google Custom Search API. Results are filtered for quality and summarized for voice delivery.
Functions:
  • web_search - Search the web and return summarized results
Requirements:
  • Google Custom Search API key (from Google Cloud Console)
  • Search Engine ID (from Programmable Search Engine)
Setup:
  1. Create a project in Google Cloud Console
  2. Enable the Custom Search JSON API
  3. Create an API key
  4. Create a Programmable Search Engine at https://programmablesearchengine.google.com/
  5. Get the Search Engine ID
Parameters:
ParameterTypeDescriptionDefault
api_keystringGoogle API key (falls back to GOOGLE_SEARCH_API_KEY)Required
search_engine_idstringSearch engine ID (falls back to GOOGLE_SEARCH_ENGINE_ID)Required
tool_namestringCustom function name (set per instance)“web_search”
num_resultsintegerResults to return3
delaynumberSeconds between requests0.5
max_content_lengthintegerMax characters of scraped page content32768
oversample_factornumberFetch extra results then re-rank2.5
min_quality_scorenumberQuality threshold (0-1)0.3
no_results_messagestringMessage returned when nothing matchesdefault
safe_searchstring"off", "medium", or "high"”medium”
Multi-instance support: Yes - add multiple instances with unique tool_name values (e.g. search_news, search_docs).
class SearchAgent(AgentBase):
super().__init__(name="search-agent")
self.add_skill("web_search", {
"api_key": "YOUR_GOOGLE_API_KEY",
"search_engine_id": "YOUR_SEARCH_ENGINE_ID",
"num_results": 3
"Role",
"You search the web to answer questions."
Search Wikipedia for information. A free, no-API-key alternative to web search for factual queries.
Functions:
  • search_wikipedia - Search and retrieve Wikipedia article summaries
Requirements: None (uses public Wikipedia API)
Parameters:
num_resultsintegerMax articles returned (1-5)1
no_results_messagestringMessage returned when nothing matchesdefault template
class WikiAgent(AgentBase):
super().__init__(name="wiki-agent")
self.add_skill("wikipedia_search", {
"num_results": 3 # Return up to three articles
"Role",
"You look up information on Wikipedia to answer factual questions."
weather_api
Get current weather information for locations worldwide. Commonly used for small talk, travel planning, and location-aware services.
Functions:
  • get_weather - Get current weather conditions for a location
Requirements: WeatherAPI.com API key (free tier available)
Setup:
  1. Sign up at https://www.weatherapi.com/
  2. Get your API key from the dashboard
  3. Free tier allows 1 million calls/month
Parameters:
api_keystringWeatherAPI.com API key (falls back to WEATHER_API_KEY)Required
tool_namestringCustom function name”get_weather”
unitsstring"metric", "imperial", "standard", "celsius", or "fahrenheit"”fahrenheit”
class WeatherAgent(AgentBase):
super().__init__(name="weather-agent")
self.add_skill("weather_api", {
"api_key": "YOUR_WEATHER_API_KEY"
"Role",
"You provide weather information for any location."
joke
Tell jokes to lighten the mood or entertain callers. Uses a curated joke database for clean, family-friendly humor.
Functions:
  • get_joke - Get a random joke. Takes a required type argument, jokes or dadjokes
Requirements: None
Parameters:
tool_namestringCustom function name”get_joke”
class FunAgent(AgentBase):
super().__init__(name="fun-agent")
self.add_skill("joke")
"Role",
"You are a fun assistant that tells jokes when asked."
Play audio files in the background during calls. Audio plays while conversation continues, useful for hold music, ambient sound, or audio cues.
Functions:
  • play_background_file - Start playing audio file
  • stop_background_file - Stop currently playing audio
Requirements: None (audio file must be accessible via URL)
Parameters:
Preload named files via files; the caller selects one by key:
tool_namestringCustom play function name”play_background_file”
filesarrayList of { key, description, url, wait? } entriesRequired
Supported formats: MP3, WAV, OGG
class MusicAgent(AgentBase):
super().__init__(name="music-agent")
self.add_skill("play_background_file", {
"files": [
"key": "hold_music",
"description": "Looping hold music",
"url": "https://example.com/hold-music.mp3",
swml_transfer
Transfer calls to another SWML endpoint.
Functions:
  • transfer_call (default name) - Transfer based on matched pattern
Requirements: None
Parameters:
transfersobjectPattern → { url | address, message?, return_message?, post_process?, final?, from_addr? }Required (or use patterns)
patternsarrayAlternative shape: list of pattern entriesRequired (or use transfers)
allow_arbitrarybooleanAccept caller-supplied URL instead of matching a patternfalse
tool_namestringCustom function name”transfer_call”
descriptionstringTool descriptiondefault
parameter_namestringArgument name the LLM supplies”transfer_type”
parameter_descriptionstringArgument descriptiondefault
default_messagestringMessage when no pattern matchesdefault
default_post_processbooleanDefault for transferred calls returning to the agentfalse
required_fieldsobjectExtra per-pattern required fields{}
class TransferAgent(AgentBase):
super().__init__(name="transfer-agent")
self.add_skill("swml_transfer", {
"transfers": {
"specialist": {
"url": "https://your-server.com/other-agent",
"message": "Transferring you to a specialist."
datasphere
Search SignalWire DataSphere documents.
Functions:
  • search_knowledge (default name) - Search uploaded documents
Requirements: DataSphere API credentials
Parameters:
space_namestringDataSphere space nameRequired
project_idstringProject IDRequired
tokenstringAPI tokenRequired
document_idstringDocument ID to search withinRequired
tool_namestringCustom function name”search_knowledge”
countintegerResults to return (1-10)1
distancenumberDistance threshold (0-10)3.0
tagsarrayFilter by document tags—
languagestringLanguage filter—
pos_to_expandarrayPOS tags to expand (NOUN, VERB, ADJ, ADV)—
max_synonymsintegerSynonym expansion limit (1-10)—
no_results_messagestringMessage when nothing matchesdefault
class KnowledgeAgent(AgentBase):
super().__init__(name="knowledge-agent")
self.add_skill("datasphere", {
"space_name": "your-space",
"project_id": "YOUR_PROJECT_ID",
"token": "YOUR_API_TOKEN",
"document_id": "your-document-id"
Local vector search using .swsearch index files.
Functions:
  • Dynamic name (default search_knowledge) - Search a local vector index
Requirements: Search extras installed (pip install "signalwire-sdk[search]")
Parameters:
index_filestringSQLite .swsearch path (SQLite backend)—
backendstring"sqlite" or "pgvector"”sqlite”
connection_stringstringPostgreSQL URL (pgvector backend)—
collection_namestringTable/collection name (pgvector backend)—
build_indexbooleanRebuild index on startupfalse
source_dirstringSource directory when building—
remote_urlstringRemote search-server URL (alternative to local index)—
index_namestringNamed index on remote server”default”
countintegerResults to return (1-20)5
similarity_thresholdnumberMinimum score (0.0-1.0)0.0
tagsarrayFilter results by tag[]
global_tagsarrayAlways-applied tag filter[]
file_typesarrayFile extensions to index["md","txt","pdf","docx","html"]
exclude_patternsarrayGlob patterns to skipdefaults
no_results_messagestringMessage when nothing matchesdefault template
response_prefixstringPrepended to result text—
response_postfixstringAppended to result text—
max_content_lengthintegerMax result chars32768
descriptionstringTool description override—
class LocalSearchAgent(AgentBase):
super().__init__(name="local-search")
self.add_skill("native_vector_search", {
"index_file": "/path/to/knowledge.swsearch",
"tool_name": "search_docs"
mcp_gateway
Connect to MCP (Model Context Protocol) servers via the MCP Gateway service. This skill dynamically creates SWAIG functions from MCP tools, enabling your agent to use any MCP-compatible tool.
Functions: Dynamically created based on connected MCP services
Requirements:
  • MCP Gateway service running
  • Gateway URL and authentication credentials
Parameters:
gateway_urlstringMCP Gateway service URLRequired
auth_userstringBasic auth usernameNone
auth_passwordstringBasic auth passwordNone
auth_tokenstringBearer token (alternative auth)None
servicesarrayServices and tools to enableAll
session_timeoutintegerSession timeout (seconds)300
tool_prefixstringPrefix for function names”mcp_“
retry_attemptsintegerConnection retries3
request_timeoutintegerRequest timeout (seconds)30
verify_sslbooleanVerify SSL certificatestrue
How it works:
  1. Skill connects to gateway and discovers available tools
  2. Each MCP tool becomes a SWAIG function (e.g., mcp_todo_add_todo)
  3. Sessions persist per call_id, enabling stateful tools
  4. Session automatically closes when call ends
class MCPAgent(AgentBase):
super().__init__(name="mcp-agent")
self.add_skill("mcp_gateway", {
"gateway_url": "http://localhost:8080",
"auth_user": "admin",
"auth_password": "secure-password",
"services": [
{"name": "todo", "tools": "*"},
{"name": "calculator", "tools": ["add", "multiply"]}
"Role",
"You help users manage tasks and perform calculations."
google_maps
Validate addresses and compute driving routes using Google Maps. Supports geocoding, spoken number normalization (e.g., “seven one four” becomes “714”), and location-biased search.
Functions:
  • lookup_address - Validate and geocode a street address or business name
  • compute_route - Compute driving distance and estimated travel time between two points
Requirements: Google Maps API key with Geocoding and Routes APIs enabled
Parameters:
api_keystringGoogle Maps API key (falls back to GOOGLE_MAPS_API_KEY)Required
lookup_tool_namestringAddress lookup function name”lookup_address”
route_tool_namestringRoute computation function name”compute_route”
class DeliveryAgent(AgentBase):
super().__init__(name="delivery-agent")
self.add_skill("google_maps", {
"api_key": "YOUR_GOOGLE_MAPS_API_KEY"
"Role",
"You help customers verify delivery addresses and estimate delivery times."
info_gatherer
Gather answers to a configurable list of questions. This is the skill version of the InfoGathererAgent prefab, designed to be embedded within larger agents.
Functions:
  • start_questions - Begin the question sequence
  • submit_answer - Submit an answer and get the next question
Requirements: None
Parameters:
questionslistList of question dictionaries (key_name, question_text, confirm, prompt_add)Required
prefixstringPrefix for tool names and namespace (enables multi-instance)None
completion_messagestringMessage read after the last questiondefault template
Multi-instance support: Yes - use the prefix parameter to run multiple question sets on a single agent. With prefix="intake", tools become intake_start_questions and intake_submit_answer, and state is stored under skill:intake in global_data.
class MultiFormAgent(AgentBase):
super().__init__(name="multi-form")
# First question set
self.add_skill("info_gatherer", {
"prefix": "contact",
"questions": [
{"key_name": "name", "question_text": "What is your name?"},
{"key_name": "email", "question_text": "What is your email?", "confirm": True}
# Second question set
"prefix": "feedback",
"questions": [
{"key_name": "rating", "question_text": "How would you rate our service?"},
{"key_name": "comments", "question_text": "Any additional comments?"}
claude_skills
Load Claude Code-style SKILL.md files as agent tools. Each SKILL.md file in the configured directory becomes a SWAIG function, with YAML frontmatter parsed for metadata (name, description, parameters).
Functions: Dynamically created from SKILL.md files (prefixed with claude_ by default)
Requirements: PyYAML package
Parameters:
skills_pathstringPath to directory containing SKILL.md filesRequired
includearrayGlob patterns of SKILL.md files to load["*"]
excludearrayGlob patterns to skip[]
tool_prefixstringPrefix for generated function names”claude_“
prompt_titlestringSection title added to agent prompt”Claude Skills”
prompt_introstringProse introducing the loaded skillsdefault template
skill_descriptionsobjectOverride descriptions, keyed by skill name{}
response_prefixstringPrepended to each skill response—
response_postfixstringAppended to each skill response—
allow_shell_injectionbooleanPermit shell metacharacters in argumentsfalse
allow_script_executionbooleanPermit running scripts referenced by a skillfalse
ignore_invocation_controlbooleanBypass per-skill invocation gatingfalse
shell_timeoutintegerShell command timeout (seconds)30
class ClaudeSkillsAgent(AgentBase):
super().__init__(name="claude-skills-agent")
self.add_skill("claude_skills", {
"skills_path": "/path/to/skills/directory",
"tool_prefix": "skill_"
Skills Summary Table
SkillFunctionsAPI RequiredMulti-Instance
datetime2NoNo
math1NoNo
web_search1YesYes
wikipedia_search1NoNo
weather_api1YesNo
joke1NoNo
play_background_file2NoNo
swml_transfer1NoYes
datasphere1YesYes
native_vector_search1NoYes
mcp_gatewayDynamicNo*Yes
google_maps2YesNo
info_gatherer2NoYes
claude_skillsDynamicNoYes
api_ninjas_trivia1YesYes
ask_claude1YesNo
custom_skillsDynamicNoNo
datasphere_serverless1YesYes
spider1NoYes
* Requires MCP Gateway service, not external API
