Native Functions
What Are Native Functions?
Native functions run directly on SignalWire’s platform. Enable them to give the AI access to built-in capabilities without creating handlers.
Handler FunctionNative Function
You define handlerSignalWire provides
Runs on your serverRuns on SignalWire
Custom logicPre-built behavior
Available Native Functions:
  • web_search - Search the web
  • debug - Debug mode for testing
Enabling Native Functions
Enable native functions in the constructor. The syntax varies by language:
LanguageSyntax
PythonAgentBase(name="my-agent", native_functions=["web_search"])
TypeScriptnew AgentBase({ name: 'my-agent', nativeFunctions: ['web_search'] })
class MyAgent(AgentBase):
super().__init__(
name="my-agent",
native_functions=["web_search"] # Enable web search
Web Search Function
Enable web search to let the AI autonomously search the web during conversations:
class ResearchAgent(AgentBase):
super().__init__(
name="research-agent",
self.prompt_add_section(
"Role",
"You are a research assistant. Search the web to answer questions."
How Web Search Works
When enabled, the AI can decide to search the web when it needs information to answer a question. The process is:
  1. AI decides to search: Based on the conversation, the AI determines a search is needed
  2. Query formulation: The AI creates a search query from the conversation context
  3. Search execution: SignalWire executes the search on the AI’s behalf
  4. Results processing: Search results are returned to the AI as context
  5. Response generation: The AI synthesizes the results into a spoken response
The caller doesn’t interact with search directly — the AI handles everything automatically.
What Web Search Returns
The AI receives search results including:
  • Page titles and snippets
  • URLs of matching pages
  • Relevant text excerpts
The AI then summarizes and presents this information conversationally. It doesn’t read URLs or raw HTML to the caller.
Web Search Limitations
No control over search behavior:
  • Cannot specify search engine (Google, Bing, etc.)
  • Cannot filter by domain or site
  • Cannot control result count
  • Cannot exclude specific sources
Content limitations:
  • Results may be outdated (search index lag)
  • Cannot access paywalled or login-required content
  • Cannot search private/internal sites
  • May not find very recent information
No result logging:
  • Search queries aren’t logged to your server
  • Cannot audit what was searched
  • Cannot cache results for reuse
Rate and cost:
  • Subject to SignalWire’s rate limits
  • May incur additional usage costs
  • Multiple searches per call add latency
Good use cases:
  • General knowledge questions (“What year was the Eiffel Tower built?”)
  • Current events (with freshness caveats)
  • Quick fact lookups during calls
  • Agents that need broad knowledge access
When to use alternatives instead:
NeedAlternative
Specific search engineweb_search skill with Google API
Domain-restricted searchCustom handler with filtered API
Result logging/auditingCustom handler with logging
Cached resultsCustom handler with caching layer
Internal/private contentCustom handler with your search backend
Guide the AI on when and how to use web search:
"Search Guidelines",
Use web search when:
- Asked about current events or recent information
- Need to verify facts you're uncertain about
- Question is outside your core knowledge
Don't search for:
- Information already in your prompt
- Customer-specific data (use account functions instead)
- Simple calculations or conversions
Debug Function
Enable debug mode for development and testing:
class DebugAgent(AgentBase):
super().__init__(
name="debug-agent",
native_functions=["debug"]
What Debug Provides
The debug function exposes diagnostic information during calls:
  • Current conversation state
  • Function call history
  • Configuration details
  • Timing information
When to Use Debug
Use during development:
  • Testing conversation flows
  • Verifying function registration
  • Checking prompt configuration
  • Troubleshooting unexpected behavior
Don’t use in production:
  • Exposes internal details to callers
  • May reveal sensitive configuration
  • Adds unnecessary function to AI’s options
  • Remove before deploying to production
Call Transfers
For call transfers, use FunctionResult.connect() in a custom handler function - there is no native transfer function:
class TransferAgent(AgentBase):
DEPARTMENTS = {
"sales": "+15551111111",
"support": "+15552222222",
"billing": "+15553333333"
super().__init__(name="transfer-agent")
"Role",
"You are a receptionist. Transfer callers to the appropriate department."
self.define_tool(
name="transfer_call",
description="Transfer the call to a department",
parameters={
"type": "object",
"properties": {
"department": {
"type": "string",
"description": "Department to transfer to",
"enum": ["sales", "support", "billing"]
"required": ["department"]
handler=self.transfer_call
def transfer_call(self, args, raw_data):
department = args.get("department")
number = self.DEPARTMENTS.get(department)
if not number:
return FunctionResult("Invalid department")
return (
FunctionResult(f"Transferring you to {department}")
.connect(number, final=True)
Combining Native and Custom Functions
The examples below use Python. The pattern of passing native_functions in the constructor and adding define_tool() calls works identically in all SDK languages using the syntax shown in the table above.
Use native functions alongside your custom handlers:
class HybridAgent(AgentBase):
super().__init__(
name="hybrid-agent",
native_functions=["web_search"] # Native
# Custom function alongside native ones
self.define_tool(
name="check_account",
description="Look up customer account information",
parameters={
"type": "object",
"properties": {
"account_id": {
"type": "string",
"description": "Account ID"
"required": ["account_id"]
handler=self.check_account
"Role",
"You are a customer service agent. "
"You can check accounts and search the web for information."
def check_account(self, args, raw_data):
account_id = args.get("account_id")
return FunctionResult(f"Account {account_id} is active")
When to Use Native vs Custom Functions
ScenarioRecommendation
Web search capabilityUse web_search native function
Development testingUse debug native function
Transfer to phone numberUse FunctionResult.connect() in custom handler
Transfer to SIP addressUse FunctionResult.connect() in custom handler
Custom business logicUse define_tool() with handler
Database lookupsUse define_tool() with handler
Native Functions Reference
FunctionDescriptionUse Case
web_searchSearch the webAnswer general questions
debugDebug informationDevelopment/testing
Next Steps
You’ve now learned all about SWAIG functions. Next, explore Skills to add pre-built capabilities to your agents.
