CGI Mode
CGI overview
CGI (Common Gateway Interface) allows web servers to execute scripts and return their output as HTTP responses.
CGI mode is primarily supported by the Python and Perl SDKs. Compiled languages (Go, C++, Java) are better served by their built-in HTTP servers. TypeScript and Ruby can use CGI via their respective interpreters but this is uncommon.
LanguageCGI SupportNotes
PythonFullAutomatic detection via GATEWAY_INTERFACE
Benefits:
  • Works with shared hosting
  • Simple deployment - just upload files
  • No separate process management
  • Compatible with Apache, nginx
Drawbacks:
  • New process per request (slower)
  • No persistent connections
  • Limited scalability
CGI detection
The SDK detects CGI mode via the GATEWAY_INTERFACE environment variable:
## Automatic detection
if os.getenv('GATEWAY_INTERFACE'):
# CGI mode detected
mode = 'cgi'
Basic CGI script
## agent.py - Basic CGI agent script (add #!/usr/bin/env python3 shebang)
class MyAgent(AgentBase):
agent = MyAgent()
agent.run() # Automatically detects CGI mode
Make scripts executable:
chmod +x agent.py agent.pl
CGI request flow
CGI request flow diagram showing web server, CGI script execution, and SignalWire Cloud.
CGI Request Flow
Apache configuration
Enable CGI
## Enable CGI module
LoadModule cgi_module modules/mod_cgi.so
## Configure CGI directory
<Directory "/var/www/cgi-bin">
Options +ExecCGI
AddHandler cgi-script .py
Require all granted
</Directory>
Virtual host configuration
<VirtualHost *:443>
ServerName agent.example.com
SSLEngine on
SSLCertificateFile /etc/ssl/certs/agent.crt
SSLCertificateKeyFile /etc/ssl/private/agent.key
ScriptAlias / /var/www/cgi-bin/agent.py
Options +ExecCGI
SetHandler cgi-script
Require all granted
</Directory>
# Set environment variables
SetEnv SWML_BASIC_AUTH_USER "myuser"
SetEnv SWML_BASIC_AUTH_PASSWORD "mypassword"
</VirtualHost>
nginx configuration
nginx doesn’t natively support CGI, but you can use FastCGI with fcgiwrap:
server {
listen 443 ssl;
server_name agent.example.com;
ssl_certificate /etc/ssl/certs/agent.crt;
ssl_certificate_key /etc/ssl/private/agent.key;
location / {
fastcgi_pass unix:/var/run/fcgiwrap.socket;
fastcgi_param SCRIPT_FILENAME /var/www/cgi-bin/agent.py;
fastcgi_param GATEWAY_INTERFACE CGI/1.1;
fastcgi_param PATH_INFO $uri;
fastcgi_param SWML_BASIC_AUTH_USER "myuser";
fastcgi_param SWML_BASIC_AUTH_PASSWORD "mypassword";
include fastcgi_params;
CGI host configuration
In CGI mode, the SDK needs to know the external hostname for generating URLs:
## Using swaig-test to simulate CGI mode
swaig-test my_agent.py --simulate-serverless cgi --cgi-host agent.example.com
Or set environment variable:
SetEnv SWML_PROXY_URL_BASE "https://agent.example.com"
Testing CGI locally
Use swaig-test to simulate CGI environment:
## Test SWML generation in CGI mode
swaig-test my_agent.py --simulate-serverless cgi --dump-swml
## With custom host
swaig-test my_agent.py --simulate-serverless cgi --cgi-host mysite.com --dump-swml
## Test a function
swaig-test my_agent.py --simulate-serverless cgi --exec function_name --param value
Authentication in CGI mode
The SDK checks basic auth in CGI mode:
## Authentication is automatic when these are set
## SWML_BASIC_AUTH_USER
## SWML_BASIC_AUTH_PASSWORD
## The SDK reads Authorization header and validates
If authentication fails, returns 401 with WWW-Authenticate header.
Directory structure
/var/www/cgi-bin/
├── agent.py # Main CGI script
├── requirements.txt # Dependencies
└── venv/ # Virtual environment (optional)
Shared hosting deployment
For shared hosting where you can’t install system packages:
## agent_shared.py - CGI agent for shared hosting (add #!/usr/bin/env python3 shebang)
import sys
import os
## Add local packages directory
sys.path.insert(0, os.path.join(os.path.dirname(__file__), 'packages'))
agent = MyAgent()
Install packages locally:
pip install --target=./packages signalwire-sdk
CGI best practices
Performance
  • Keep imports minimal - each request starts fresh
  • Consider FastCGI for better performance
  • Cache what you can (but remember process dies)
Security
  • Set proper file permissions (750 or 755)
  • Don’t expose .py files directly if possible
  • Use HTTPS always
  • Set auth credentials as environment variables
Debugging
  • Check web server error logs
  • Verify shebang line (#!/usr/bin/env python3)
  • Test script from command line first
  • Ensure proper line endings (LF, not CRLF)
Common CGI issues
IssueSolution
500 Internal Server ErrorCheck error logs, verify permissions
Permission deniedchmod +x agent.py
Module not foundCheck sys.path, install dependencies
Wrong Python versionUpdate shebang to correct Python
Malformed headersEnsure proper Content-Type output
TimeoutOptimize code, increase server timeout
Migration from CGI
CGI to FastCGI
Keep same code, use fcgiwrap or gunicorn. Better performance, persistent processes.
CGI to server mode
Same code works - just run differently (python agent.py instead of CGI). Add systemd service, nginx reverse proxy.
CGI to serverless
Same code works with minor changes. Add Lambda handler wrapper. Deploy to AWS/GCP/Azure.
