Multi-Agent Servers
Multi-agent servers let you run several specialized agents from a single process. This simplifies deployment, reduces resource overhead, and provides unified management. Instead of running separate processes for sales, support, and billing agents, you run one server that routes requests to the appropriate agent.
This architecture is especially useful when you have related agents that share infrastructure but have different personas and capabilities.
Single Agent vs Multi-Agent: Decision Guide
Choosing between agent.run() and AgentServer depends on your deployment needs.
Use single agent (agent.run()) when:
  • You have one agent with a single purpose
  • You want the simplest possible deployment
  • Each agent needs isolated resources (memory, CPU)
  • Agents have very different scaling requirements
  • You’re using container orchestration that handles multi-instance deployment
Use AgentServer when:
  • You have multiple related agents (sales, support, billing)
  • Agents share the same deployment environment
  • You want unified health monitoring
  • SIP routing determines which agent handles a call
  • You want to reduce operational overhead of managing multiple processes
  • Agents share common code or resources
Single Agent (agent.run())AgentServer
One agent per processMultiple agents per process
Simple deploymentShared resources
Separate ports per agentSingle port, multiple routes
Independent scalingShared scaling
Isolated failuresUnified monitoring
SIP username routing
Unified health checks
Basic AgentServer
from signalwire import AgentBase, AgentServer
class SalesAgent(AgentBase):
super().__init__(name="sales-agent")
self.prompt_add_section("Role", "You are a sales representative.")
super().__init__(name="support-agent")
self.prompt_add_section("Role", "You are a support specialist.")
server = AgentServer(host="0.0.0.0", port=3000)
server.register(SupportAgent(), "/support")
server.run()
Agents are available at:
EndpointDescription
http://localhost:3000/salesSales agent
http://localhost:3000/supportSupport agent
http://localhost:3000/healthBuilt-in health check
AgentServer Configuration
host="0.0.0.0", # Bind address
port=3000, # Listen port
log_level="info" # debug, info, warning, error, critical
Registering Agents
With Explicit Route
Using Agent’s Default Route
class BillingAgent(AgentBase):
super().__init__(
name="billing-agent",
route="/billing" # Default route
server.register(BillingAgent()) # Uses "/billing"
Server Architecture
Diagram showing AgentServer routing requests to different agents based on URL path.
AgentServer architecture with path-based routing.
Managing Agents
Get All Agents
agents = server.get_agents()
for route, agent in agents:
print(f"{route}: {agent.get_name()}")
Get Specific Agent
sales_agent = server.get_agent("/sales")
Unregister Agent
server.unregister("/sales")
SIP Routing
Route SIP calls to specific agents based on username:
server = AgentServer()
# Enable SIP routing
server.setup_sip_routing("/sip", auto_map=True)
# Manual SIP username mapping
server.register_sip_username("sales-team", "/sales")
server.register_sip_username("help-desk", "/support")
server.run()
When auto_map=True, the server automatically creates mappings:
  • Agent name to route (e.g., “salesagent” to “/sales”)
  • Route path to route (e.g., “sales” to “/sales”)
SIP Routing Flow
Diagram showing how SIP usernames are mapped to agent routes through the AgentServer.
SIP routing flow showing username-to-agent mapping.
Health Check Endpoint
AgentServer provides a built-in health check:
curl http://localhost:3000/health
Response:
"status": "ok",
"agents": 2,
"routes": ["/sales", "/support"]
Serverless Deployment
AgentServer supports serverless environments automatically:
class MyAgent(AgentBase):
server.register(MyAgent(), "/agent")
## AWS Lambda handler
def lambda_handler(event, context):
return server.run(event, context)
## CGI mode (auto-detected)
server.run()
Complete Example
#!/usr/bin/env python3
## multi_agent_server.py - Server with multiple specialized agents
"Role",
"You are a sales representative for Acme Corp."
self.define_tool(
name="get_pricing",
description="Get product pricing",
parameters={
"type": "object",
"properties": {
"product": {"type": "string", "description": "Product name"}
"required": ["product"]
handler=self.get_pricing
def get_pricing(self, args, raw_data):
product = args.get("product", "")
return FunctionResult(f"The price for {product} is $99.99")
"Role",
"You are a technical support specialist."
self.define_tool(
name="create_ticket",
description="Create a support ticket",
parameters={
"type": "object",
"properties": {
"issue": {"type": "string", "description": "Issue description"}
"required": ["issue"]
handler=self.create_ticket
def create_ticket(self, args, raw_data):
issue = args.get("issue", "")
return FunctionResult(f"Created ticket #12345 for: {issue}")
super().__init__(name="billing-agent")
"Role",
"You help customers with billing questions."
# Create server
# Register agents
server.register(BillingAgent(), "/billing")
# Custom SIP mappings
server.register_sip_username("sales", "/sales")
server.register_sip_username("help", "/support")
server.register_sip_username("accounts", "/billing")
print("Agents available:")
for route, agent in server.get_agents():
print(f" {route}: {agent.get_name()}")
server.run()
AgentServer Methods Summary
MethodPurpose
register(agent, route)Register an agent at a route
unregister(route)Remove an agent
get_agents()Get all registered agents
get_agent(route)Get agent by route
setup_sip_routing(route, auto_map)Enable SIP-based routing
register_sip_username(username, route)Map SIP username to route
run()Start the server
Performance Considerations
Running multiple agents in a single process has implications:
Memory: Each agent maintains its own state, but they share the Python interpreter. For most deployments, this reduces overall memory compared to separate processes.
CPU: Agents share CPU resources. A heavy-load agent can affect others. Monitor and adjust if needed.
Startup time: All agents initialize when the server starts. More agents = longer startup.
Isolation: A crash in one agent’s handler can affect the entire server. Implement proper error handling in your handlers.
Scaling: You scale the entire server, not individual agents. If one agent needs more capacity, you scale everything. For very different scaling needs, consider separate deployments.
Shared State Between Agents
Agents in an AgentServer are independent instances — they don’t share state by default. Each agent has its own prompts, functions, and configuration.
If you need shared state:
Use external storage (Redis, database) rather than Python globals:
import redis
class SharedStateAgent(AgentBase):
def __init__(self, redis_client):
super().__init__(name="shared-state-agent")
self.redis = redis_client
# ... setup
def some_handler(self, args, raw_data):
# Read shared state
shared_value = self.redis.get("shared_key")
# Update shared state
self.redis.set("shared_key", "new_value")
return FunctionResult("Done")
# In main
redis_client = redis.Redis(host='localhost', port=6379)
server.register(SharedStateAgent(redis_client), "/agent1")
server.register(AnotherAgent(redis_client), "/agent2")
Sharing configuration:
For shared configuration like API keys or business rules, use a shared module:
# config.py
SHARED_CONFIG = {
"company_name": "Acme Corp",
"support_hours": "9 AM - 5 PM",
"api_key": os.environ.get("API_KEY")
# agents.py
from config import SHARED_CONFIG
"Company",
f"You work for {SHARED_CONFIG['company_name']}"
Routing Logic
AgentServer routes requests based on URL path and SIP username. Understanding this routing helps you design your agent structure.
Path-based routing is straightforward:
  • Request to /sales routes to the Sales agent
  • Request to /support routes to the Support agent
SIP routing extracts the username from the SIP address:
  • sip:sales@example.com looks up “sales” and routes to /sales
  • sip:help-desk@example.com looks up “help-desk” and routes based on mapping
Auto-mapping creates automatic mappings from agent names and route paths:
# Creates mappings like:
# "salesagent" -> "/sales" (from agent name, normalized)
# "sales" -> "/sales" (from route path without leading /)
Manual mapping gives explicit control:
server.register_sip_username("tech-support", "/support")
Common Patterns
Department-Based Routing
server.register(ReceptionistAgent(), "/main") # Default/main line
Time-Based Routing
class TimeSensitiveServer:
self.server = AgentServer()
self.server.register(LiveAgent(), "/live")
self.server.register(AfterHoursAgent(), "/afterhours")
def get_current_agent_route(self):
from datetime import datetime
hour = datetime.now().hour
if 9 <= hour < 17: # Business hours
return "/live"
return "/afterhours"
Feature-Based Agents
server.register(GeneralAgent(), "/general") # Basic Q&A
server.register(OrderAgent(), "/orders") # Order management
server.register(TechnicalAgent(), "/technical") # Technical support
server.register(EscalationAgent(), "/escalation") # Human escalation
Best Practices
DO:
  • Use meaningful route names (/sales, /support, /billing)
  • Enable SIP routing for SIP-based deployments
  • Monitor /health endpoint for availability
  • Use consistent naming between routes and SIP usernames
  • Implement proper error handling in all agent handlers
  • Use external storage for shared state
  • Log which agent handles each request for debugging
DON’T:
  • Register duplicate routes
  • Forget to handle routing conflicts
  • Mix agent.run() and AgentServer for the same agent
  • Store shared state in Python globals (use external storage)
  • Put agents with very different scaling needs in the same server
