Account Setup
What You’ll Learn
This chapter covers SignalWire integration:
  1. Account Setup - Create and configure your SignalWire account
  2. Phone Numbers - Purchase and manage phone numbers
  3. Mapping Numbers - Connect phone numbers to your agents
  4. Testing - Test your agents before going live
  5. Troubleshooting - Common issues and solutions
Integration Overview
SignalWire integration overview.
SignalWire Integration
Prerequisites
Before connecting to SignalWire:
  • Working agent (tested locally)
  • Publicly accessible server
  • SignalWire account
Chapter Contents
SectionDescription
Account SetupCreate SignalWire account and project
Phone NumbersPurchase and manage numbers
Mapping NumbersConnect numbers to agents
TestingTest calls and debugging
TroubleshootingCommon issues and fixes
Quick Integration Steps
Step 1: Account Setup
  • Create SignalWire account
  • Create a project
  • Note your Space Name
Step 2: Phone Number
  • Purchase a phone number
  • Or use a SIP endpoint
Step 3: Deploy Agent
  • Deploy agent to public URL
  • Verify HTTPS is working
  • Test SWML endpoint responds
Step 4: Connect
  • Point phone number to agent URL
  • Make test call
  • Verify agent responds
Architecture
Call flow architecture between SignalWire and your agent.
Call Flow Architecture
Required URLs
Your agent needs to be accessible at these endpoints:
EndpointMethodPurpose
/POSTMain SWML document
/swaigPOSTSWAIG function calls
Security Considerations
  • Always use HTTPS for production
  • Enable basic auth for SWML endpoints
  • Use secure tokens for SWAIG functions
  • Don’t expose sensitive data in prompts
  • Monitor for unusual call patterns
Let’s start with setting up your SignalWire account.
Create Account
  1. Go to signalwire.com
  2. Click Sign Up or Login
  3. Complete registration with email and password
  4. Verify your email address
If you have problems verifying your account, email support@signalwire.com
Create a Project
After logging in:
  1. Navigate to Projects in the dashboard
  2. Click “Create New Project”
  3. Enter a project name (e.g., “Voice Agents”)
  4. Select your use case
Space Name
Your Space Name is your unique SignalWire identifier.
URL Format: https://YOUR-SPACE-NAME.signalwire.com
Example: https://mycompany.signalwire.com
You’ll need this for:
  • API authentication
  • Dashboard access
  • SWML webhook configuration
API Credentials
Get your API credentials from the project:
  1. Go to API Credentials
  2. Note your Project ID
  3. Create an API Token if needed
CredentialFormat
Project IDxxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
API Tokenswapi_xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Space Nameyour-space
Keep these secure — don’t commit to version control!
Environment Variables
Set these for your agent. These environment variables are used by all SDK languages:
export SIGNALWIRE_PROJECT_ID="your-project-id"
export SIGNALWIRE_API_TOKEN="your-api-token"
export SIGNALWIRE_SPACE="your-space.signalwire.com"
Dashboard Overview
SectionPurpose
Phone NumbersPurchase and manage phone numbers
SWMLConfigure SWML scripts and webhooks
LogsView call history and debugging info
API CredentialsCredentials and API explorer
BillingAccount balance and usage
Add Credit
Before making calls:
  1. Go to Billing
  2. Add payment method
  3. Add credit to your account
Trial accounts may have limited credit for testing.
Account Verification
Some features require account verification:
  • Phone number purchases
  • Outbound calling
  • Certain number types
Complete verification in Account Settings if prompted.
Next Steps
With your account ready:
  1. Purchase a phone number
  2. Deploy your agent
  3. Connect the number to your agent
