Call Flow Customization
Understanding Call Flow
By default, AgentBase generates a simple call flow:
answer -> ai
The SDK provides three insertion points to customize this flow:
Call flow insertion points for pre-answer, post-answer, and post-AI verbs.
Verb Insertion Methods
MethodPurposeCommon Uses
add_pre_answer_verb()Before answeringRingback, screening, routing
add_post_answer_verb()After answer, before AIAnnouncements, disclaimers
add_post_ai_verb()After AI endsCleanup, transfers, surveys
The verb insertion methods are available in all languages:
LanguagePre-AnswerPost-AnswerPost-AI
Pythonadd_pre_answer_verb(verb, params)add_post_answer_verb(verb, params)add_post_ai_verb(verb, params)
TypeScriptaddPreAnswerVerb(verb, params)addPostAnswerVerb(verb, params)addPostAiVerb(verb, params)
Pre-Answer Verbs
Pre-answer verbs run while the call is still ringing. Use them for:
  • Ringback tones: Play audio before answering
  • Call screening: Check caller ID or time
  • Conditional routing: Route based on variables
#!/usr/bin/env python3
class RingbackAgent(AgentBase):
"""Agent that plays ringback tone before answering."""
super().__init__(name="ringback", port=3000)
# Play US ringback tone before answering
# IMPORTANT: auto_answer=False prevents play from answering the call
self.add_pre_answer_verb("play", {
"urls": ["ring:us"],
"auto_answer": False
# Configure AI
agent = RingbackAgent()
Generated SWML:
"sections": {
"main": [
{"play": {"urls": ["ring:us"], "auto_answer": false}},
{"answer": {}},
{"ai": {...}}
Pre-Answer Safe Verbs
Only certain verbs can run before the call is answered:
VerbPre-Answer SafeNotes
playYes*Requires auto_answer: false
connectYes*Requires auto_answer: false
sleepYesWait for duration
setYesSet variables
requestYesHTTP request
switchYesVariable-based branching
condYesConditional branching
ifYesIf/then/else
evalYesEvaluate expressions
gotoYesJump to label
labelYesDefine jump target
hangupYesReject call
transferYesRoute elsewhere
*These verbs auto-answer by default. Set auto_answer: false for pre-answer use.
Available Ringback Tones
ToneDescription
ring:usUS ringback tone
ring:ukUK ringback tone
ring:itItalian ringback tone
ring:atAustrian ringback tone
Post-Answer Verbs
Post-answer verbs run after the call is connected but before the AI speaks:
class WelcomeAgent(AgentBase):
"""Agent that plays welcome message before AI."""
super().__init__(name="welcome", port=3000)
# Play welcome announcement
self.add_post_answer_verb("play", {
"url": "say:Thank you for calling Acme Corporation. "
"Your call may be recorded for quality assurance."
# Brief pause before AI speaks
self.add_post_answer_verb("sleep", {"time": 500})
# Configure AI
self.prompt_add_section(
"Role",
"You are a customer service representative. "
"The caller has just heard the welcome message."
agent = WelcomeAgent()
Generated SWML:
"sections": {
"main": [
{"answer": {}},
{"play": {"url": "say:Thank you for calling..."}},
{"sleep": {"time": 500}},
{"ai": {...}}
Common Post-Answer Uses
Use CaseExample
Welcome message{"url": "say:Thank you for calling..."}
Legal disclaimer{"url": "say:This call may be recorded..."}
Hold music{"url": "https://example.com/hold.mp3"}
Pause{"time": 500} (milliseconds)
RecordingUse record_call=True in constructor
Post-AI Verbs
Post-AI verbs run after the AI conversation ends:
class SurveyAgent(AgentBase):
"""Agent that logs call outcome after conversation."""
super().__init__(name="survey", port=3000)
# Configure AI
self.prompt_add_section("Role", "You are a support agent.")
# After AI ends, log the call and hang up
self.add_post_ai_verb("request", {
"url": "https://api.example.com/call-complete",
"method": "POST"
self.add_post_ai_verb("hangup", {})
agent = SurveyAgent()
Common Post-AI Uses
Use CaseVerbExample
Clean disconnecthangup{}
Transfer to humantransfer{"dest": "tel:+15551234567"}
Post-call surveypromptDTMF collection
Log outcomerequestHTTP POST to API
Connect to queueenter_queue{"name": "support"}
Complete Example
Here’s an agent with all three insertion points:
class CallFlowAgent(AgentBase):
"""Agent demonstrating complete call flow customization."""
super().__init__(name="call-flow", port=3000)
# PRE-ANSWER: Ringback tone
# POST-ANSWER: Welcome and disclaimer
"url": "say:Welcome to Acme Corporation."
"url": "say:This call may be recorded for quality assurance."
# Configure AI
"Role",
"You are a friendly customer service representative. "
self.set_params({
"end_of_speech_timeout": 1000,
"attention_timeout": 10000
# POST-AI: Clean disconnect
agent = CallFlowAgent()
Generated SWML:
"sections": {
"main": [
{"answer": {}},
{"play": {"url": "say:Welcome to Acme Corporation."}},
{"play": {"url": "say:This call may be recorded..."}},
{"ai": {...}},
{"hangup": {}}
Controlling Answer Behavior
Disable Auto-Answer
Set auto_answer=False to prevent automatic answering:
class ManualAnswerAgent(AgentBase):
# Disable auto-answer
super().__init__(name="manual", port=3000, auto_answer=False)
# Pre-answer: Play ringback
Customize Answer Verb
Use add_answer_verb() to configure the answer verb:
# Set max call duration to 1 hour
agent.add_answer_verb({"max_duration": 3600})
Dynamic Call Flow
Modify call flow based on caller information using on_swml_request():
class DynamicFlowAgent(AgentBase):
super().__init__(name="dynamic", port=3000)
self.prompt_add_section("Role", "You are a receptionist.")
# VIP numbers get special treatment
self.vip_numbers = ["+15551234567", "+15559876543"]
def on_swml_request(self, request_data=None, callback_path=None, request=None):
call_data = (request_data or {}).get("call", {})
caller = call_data.get("from", "")
if caller in self.vip_numbers:
# VIP: No ringback, immediate welcome
self.clear_pre_answer_verbs()
"url": "say:Welcome back, valued customer!"
else:
# Regular caller: Ringback tone
Clear Methods
Remove verbs from insertion points:
agent.clear_pre_answer_verbs() # Remove all pre-answer verbs
agent.clear_post_answer_verbs() # Remove all post-answer verbs
agent.clear_post_ai_verbs() # Remove all post-AI verbs
Method Chaining
All verb insertion methods return self for chaining:
agent = AgentBase(name="chained", port=3000)
agent.add_pre_answer_verb("play", {"urls": ["ring:us"], "auto_answer": False}) \
.add_post_answer_verb("play", {"url": "say:Welcome"}) \
.add_post_answer_verb("sleep", {"time": 500}) \
