REST Client
What Is the REST Client?
The RestClient provides a synchronous Python interface to all SignalWire REST APIs. It organizes the platform’s HTTP endpoints into namespaced resource objects with standard CRUD operations.
When to Use REST vs Relay vs Agents
ApproachBest For
AgentBase (SWML)AI-driven voice agents
Relay ClientReal-time call control over WebSocket
REST ClientResource management, provisioning, log queries, admin tasks
Use the REST client for tasks like purchasing phone numbers, managing fabric resources, querying call logs, or any operation that doesn’t require real-time event handling.
Quick Start
#!/usr/bin/env python3
"""REST client quick start."""
client = RestClient(
project="your-project-id",
token="your-api-token",
host="your-space.signalwire.com",
# List AI agents in your fabric
agents = client.fabric.ai_agents.list()
print(agents)
# Search for available phone numbers
available = client.phone_numbers.search(areacode="512")
print(available)
Authentication
Constructor Arguments
LanguageSyntax
PythonRestClient(project="...", token="...", host="...")
TypeScriptnew RestClient({ project: '...', token: '...', host: '...' })
Environment Variables
All credentials can be provided via environment variables:
VariablePurpose
SIGNALWIRE_PROJECT_IDProject ID
SIGNALWIRE_API_TOKENAPI token
SIGNALWIRE_SPACESpace hostname
# With env vars set, no arguments needed
client = RestClient()
Namespaced Resources
The client exposes all SignalWire APIs through typed namespace properties:
client.fabric # AI agents, SWML scripts, subscribers, call flows
client.calling # REST-based call control (37 commands)
client.phone_numbers # Search, purchase, manage numbers
client.video # Rooms, sessions, recordings, conferences
client.datasphere # Document management and semantic search
client.messages # Send SMS/MMS, redact sent messages
client.projects # Subprojects and signing keys
client.logs # Message, voice, fax, conference logs
client.registry # 10DLC brand/campaign management
client.queues # Call queue management
client.recordings # Recording management
client.project # Project-level token management
client.mfa # Multi-factor authentication
client.lookup # Phone number carrier/CNAM lookup
client.pubsub # PubSub token management
client.chat # Chat token management
CRUD Pattern
Most resources follow a standard CRUD pattern:
OperationPython
Listclient.phone_numbers.list()
Createclient.fabric.ai_agents.create(name="x", prompt=...)
Getclient.fabric.ai_agents.get("id")
Updateclient.fabric.ai_agents.update("id", name="y")
Deleteclient.fabric.ai_agents.delete("id")
# List resources
result = client.phone_numbers.list(page_size=10)
# Create a resource
new = client.fabric.ai_agents.create(
name="my-agent", prompt={"text": "You are a helpful assistant."}
# Get a single resource
agent = client.fabric.ai_agents.get("resource-id")
# Update a resource
client.fabric.ai_agents.update("resource-id", name="updated-name")
# Delete a resource
client.fabric.ai_agents.delete("resource-id")
Fabric Namespace
Manage SignalWire Fabric resources — AI agents, SWML scripts, subscribers, and call flows:
# AI agents
agent = client.fabric.ai_agents.create(
name="support-bot", prompt={"text": "You are a support agent."}
# SWML scripts
scripts = client.fabric.swml_scripts.list()
# SWML webhooks
webhooks = client.fabric.swml_webhooks.list()
# Subscribers
subs = client.fabric.subscribers.list()
# Subscriber SIP endpoints
endpoints = client.fabric.subscribers.list_sip_endpoints("subscriber-id")
client.fabric.subscribers.create_sip_endpoint(
"subscriber-id", username="ext100", password="a-strong-password"
# Call flows with versioning
flows = client.fabric.call_flows.list()
versions = client.fabric.call_flows.list_versions("flow-id")
client.fabric.call_flows.deploy_version("flow-id", {"call_flow_version_id": "v2"})
# Tokens (subscriber, guest, invite, embed)
token = client.fabric.tokens.create_subscriber_token(reference="sub-id")
guest = client.fabric.tokens.create_guest_token(allowed_addresses=["address-id"])
Phone Numbers
Search, purchase, and manage phone numbers:
# Search for available numbers
areacode="512",
max_results=5,
# List your numbers
numbers = client.phone_numbers.list()
# Get a specific number
number = client.phone_numbers.get("number-id")
# Update number configuration
client.phone_numbers.update("number-id", name="Support Line")
Calling Namespace
REST-based call control with 37+ commands. All commands are dispatched via POST:
# Initiate a call
result = client.calling.dial(
from_="+15559876543",
to="+15551234567",
# Play audio on a call
client.calling.play(call_id="call-id", play=[
{"type": "tts", "text": "Hello from REST!"}
# Record a call
client.calling.record(call_id="call-id", audio={})
# Control playback
client.calling.play_pause(call_id="call-id", control_id="ctrl-id")
client.calling.play_resume(call_id="call-id", control_id="ctrl-id")
client.calling.play_stop(call_id="call-id", control_id="ctrl-id")
# AI commands
client.calling.ai_message(call_id="call-id", message_text="New instruction")
client.calling.ai_hold(call_id="call-id")
client.calling.ai_unhold(call_id="call-id")
# End a call
client.calling.end(call_id="call-id", reason="hangup")
Video Namespace
Manage video rooms, conferences, sessions, and recordings:
# Create a video room
room = client.video.rooms.create(name="standup", max_members=10)
# List room sessions
sessions = client.video.room_sessions.list()
# Get session members
members = client.video.room_sessions.list_members("session-id")
# Manage conferences
conf = client.video.conferences.create(name="team-conf")
client.video.conferences.list_streams("conference-id")
Datasphere Namespace
Manage documents and run semantic search:
# List documents
docs = client.datasphere.documents.list()
# Upload a document
doc = client.datasphere.documents.create(
name="FAQ",
content="Your FAQ content here...",
# Semantic search
results = client.datasphere.documents.search(
query_string="How do I reset my password?",
count=5,
# Manage chunks
chunks = client.datasphere.documents.list_chunks("document-id")
client.datasphere.documents.delete_chunk("document-id", "chunk-id")
Logs Namespace
Query message, voice, fax, and conference logs:
# Voice call logs
calls = client.logs.voice.list(page_size=20)
call = client.logs.voice.get("log-id")
events = client.logs.voice.list_events("log-id")
# Message logs
messages = client.logs.messages.list()
# Fax logs
faxes = client.logs.fax.list()
# Conference logs
confs = client.logs.conferences.list()
Registry Namespace (10DLC)
Manage 10DLC brands and campaigns for A2P messaging compliance:
# List brands
brands = client.registry.brands.list()
# Create a brand
brand = client.registry.brands.create(
entity_type="PRIVATE_PROFIT",
display_name="My Company",
# Create a campaign under a brand
campaign = client.registry.brands.create_campaign(
"brand-id",
description="Customer notifications",
usecase="MIXED",
# Assign numbers to campaigns
order = client.registry.campaigns.create_order(
"campaign-id",
phone_number_ids=["number-id-1"],
Messages
Send an SMS or MMS and redact a sent message’s body:
# Send a message
msg = client.messages.create(
to="+15559876543",
from_="+15551234567",
body="Your table is ready.",
# Redact the body after delivery
client.messages.update(msg["id"], body="")
To query message history, use client.logs.messages instead.
Other Resources
# Queue management
queues = client.queues.list()
members = client.queues.list_members("queue-id")
next_member = client.queues.get_next_member("queue-id")
# Recordings
recordings = client.recordings.list()
# Phone number lookup
info = client.lookup.phone_number("+15551234567")
client.mfa.sms(to="+15551234567", from_="+15550000000", message="Your code: {code}")
client.mfa.verify("req-id", token="123456")
# SIP profile
profile = client.sip_profile.get()
client.sip_profile.update(domain_identifier="my-sip-domain")
# Verified caller IDs
callers = client.verified_callers.list()
Pagination
list() returns a single page. Most list resources also expose paginate(), which follows links.next and yields every item across all pages:
# Iterate all phone numbers across pages
for number in client.phone_numbers.paginate():
print(number["name"], number["number"])
Timeouts and retries
Pass a RequestOptions to the client for a default timeout and retry policy, or to any method for a one-off override:
from signalwire.rest import RestClient, RequestOptions
client = RestClient(request_options=RequestOptions(timeout=10.0, retries=3))
numbers = client.phone_numbers.list(request_options=RequestOptions(timeout=60.0))
In TypeScript, every list resource has a paginate() method that returns an async iterator over all pages:
for await (const number of client.phoneNumbers.paginate()) {
console.log(number.name, number.number);
Error Handling
REST errors raise SignalWireRestError. A request that never reaches the server raises SignalWireRestTransportError, a subclass with status_code set to None, so one except covers both. The error carries the platform request_id for support correlation.
from signalwire.rest import RestClient, SignalWireRestError
try:
client.phone_numbers.get("nonexistent-id")
except SignalWireRestError as e:
print(f"HTTP {e.status_code}: {e.body}")
print(f"URL: {e.method} {e.url}")
print(f"Request ID: {e.request_id}")
Practical Example: Provision and Configure
"""Provision a phone number and assign it to an AI agent."""
# Search for a local number
available = client.phone_numbers.search(areacode="512", max_results=1)
numbers = available.get("data", [])
if not numbers:
print("No numbers available")
exit(1)
# Purchase the first available number
purchased = client.phone_numbers.create(number=numbers[0]["e164"])
print(f"Purchased: {purchased['number']}")
# List AI agents
agent_list = agents.get("data", [])
if agent_list:
agent_id = agent_list[0]["id"]
print(f"Found agent: {agent_list[0].get('name', agent_id)}")
# Query recent call logs
logs = client.logs.voice.list(page_size=5)
for log in logs.get("data", []):
print(f" Call: {log.get('from')} -> {log.get('to')} ({log.get('status')})")
