Adding Skills
Basic Usage
Add a skill with no configuration:
LanguageSyntax
Pythonself.add_skill("datetime")
TypeScriptawait agent.addSkill(new DateTimeSkill())
class MyAgent(AgentBase):
# Add skill with default settings
With Configuration
Pass parameters as a dictionary (or map/hash depending on language):
LanguageSyntax
Pythonself.add_skill("web_search", {"api_key": "KEY", "num_results": 5})
TypeScriptawait agent.addSkill(new WebSearchSkill({ api_key: 'KEY', num_results: 5 }))
# Add skill with configuration
"api_key": "YOUR_API_KEY",
"search_engine_id": "YOUR_ENGINE_ID",
"num_results": 5
Method Chaining
add_skill() returns self for chaining (in languages that support it):
LanguageChaining syntax
Pythonself.add_skill("datetime").add_skill("math").add_skill("joke")
TypeScriptawait agent.addSkill(new DateTimeSkill()); await agent.addSkill(new MathSkill()); await agent.addSkill(new JokeSkill());
# Chain multiple skills
(self
.add_skill("math")
.add_skill("joke"))
Multiple Skills
Add as many skills as needed:
class AssistantAgent(AgentBase):
super().__init__(name="assistant")
# Add multiple capabilities
self.add_skill("math")
self.add_skill("wikipedia_search")
self.prompt_add_section(
"Role",
"You are a helpful assistant."
"Capabilities",
body="You can help with:",
bullets=[
"Date and time information",
"Math calculations",
"Wikipedia lookups"
Checking Loaded Skills
## Check if skill is loaded
if agent.has_skill("datetime"):
print("Datetime skill is active")
## List all loaded skills
skills = agent.list_skills()
print(f"Loaded skills: {skills}")
Removing Skills
## Remove a skill
agent.remove_skill("datetime")
Multi-Instance Skills
Some skills support multiple instances. Give each instance a unique tool_name:
LanguageTwo instances of web_search
Pythonself.add_skill("web_search", {"tool_name": "search_news", ...})
TypeScriptawait agent.addSkill(new WebSearchSkill({ tool_name: 'search_news', ... }))
class MultiSearchAgent(AgentBase):
super().__init__(name="multi-search")
# First search instance for news
"search_engine_id": "NEWS_ENGINE_ID"
# Second search instance for documentation
"tool_name": "search_docs",
"search_engine_id": "DOCS_ENGINE_ID"
"Role",
"You can search news and documentation separately."
SWAIG Fields
Add extra SWAIG metadata to skill functions:
self.add_skill("datetime", {
"swaig_fields": {
"fillers": {
"en-US": ["Let me check the time..."]
Error Handling
Skills may fail to load:
try:
agent.add_skill("web_search", {
"api_key": "invalid"
except ValueError as e:
print(f"Skill failed to load: {e}")
Common errors:
ErrorCauseSolution
Skill not foundInvalid skill nameCheck spelling
Missing parametersRequired config not providedAdd required params
Package not installedMissing Python dependencyInstall with pip
Env var missingRequired environment variableSet the variable
Skills with Environment Variables
Some skills read from environment variables:
import os
## Set API key via environment
os.environ["GOOGLE_SEARCH_API_KEY"] = "your-key"
## Skill can read from env
"api_key": os.environ["GOOGLE_SEARCH_API_KEY"],
"search_engine_id": "your-engine-id"
Complete Example
#!/usr/bin/env python3
## full_featured_agent.py - Agent with multiple configured skills
class FullFeaturedAgent(AgentBase):
super().__init__(name="full-featured")
# Simple skills (no config needed)
"Role",
"You are a versatile assistant named Alex."
"Capabilities",
bullets=[
"Current date and time",
"Math calculations"
agent = FullFeaturedAgent()
Skills like web_search and joke require additional configuration or API keys. See the Built-in Skills section for details on each skill’s requirements.
Best Practices
DO:
  • Add skills in init before prompt configuration
  • Use environment variables for API keys
  • Check skill availability with has_skill() if conditional
  • Update prompts to mention skill capabilities
DON’T:
  • Hardcode API keys in source code
  • Add duplicate skills (unless multi-instance)
  • Assume skills are available without checking
  • Forget to handle skill loading errors
