SWAIG Functions
What You’ll Learn
This chapter covers everything about SWAIG functions:
  1. Defining Functions - Creating functions the AI can call
  2. Parameters - Accepting arguments from the AI
  3. Results & Actions - Returning data and triggering actions
  4. DataMap - Serverless API integration without webhooks
  5. Native Functions - Built-in SignalWire functions
How SWAIG Functions Work
SWAIG function flow diagram.
SWAIG Function Flow
Quick Start Example
Here’s a complete agent with a SWAIG function:
class OrderAgent(AgentBase):
super().__init__(name="order-agent")
self.prompt_add_section(
"Role",
"You are an order status assistant. Help customers check their orders."
# Define a function the AI can call
self.define_tool(
name="check_order",
description="Look up order status by order number",
parameters={
"type": "object",
"properties": {
"order_number": {
"type": "string",
"description": "The order number to look up"
"required": ["order_number"]
handler=self.check_order
def check_order(self, args, raw_data):
order_number = args.get("order_number")
# Your business logic here - database lookup, API call, etc.
orders = {
"12345": "Shipped Monday, arriving Thursday",
"67890": "Processing, ships tomorrow"
status = orders.get(order_number, "Order not found")
return FunctionResult(f"Order {order_number}: {status}")
agent = OrderAgent()
Function Types
TypeDescription
Handler FunctionsDefined with define_tool(). Your handler runs on your server with full control over logic, database access, and API calls.
DataMap FunctionsServerless API integration that runs on SignalWire’s servers. No webhook endpoint needed - direct REST API calls.
Native FunctionsBuilt into SignalWire. No custom code required - handles transfer, recording, etc.
Chapter Contents
SectionDescription
Defining FunctionsCreating SWAIG functions with define_tool()
ParametersDefining and validating function parameters
Results & ActionsReturning results and triggering actions
DataMapServerless API integration
Native FunctionsBuilt-in SignalWire functions
When to Use SWAIG Functions
Use CaseApproach
Database lookupsHandler function
Complex business logicHandler function
Simple REST API callsDataMap
Pattern-based responsesDataMap expressions
Call transfersNative function or FunctionResult.connect()
SMS sendingFunctionResult.send_sms()
Key Concepts
Handler Functions: Python code that runs on your server when the AI decides to call a function. You have full access to databases, APIs, and any Python library.
FunctionResult: The return type for all SWAIG functions. Contains the response text the AI will speak and optional actions to execute.
Parameters: JSON Schema definitions that tell the AI what arguments your function accepts. The AI will extract these from the conversation.
Actions: Side effects like call transfers, SMS sending, or context changes that execute after the function completes.
DataMap: A way to define functions that call REST APIs without running any code on your server - the API calls happen directly on SignalWire’s infrastructure.
Let’s start by learning how to define functions.
Basic Function Definition
class MyAgent(AgentBase):
# Define a function
self.define_tool(
name="get_weather",
description="Get current weather for a city",
parameters={
"type": "object",
"properties": {
"city": {
"type": "string",
"description": "City name"
"required": ["city"]
handler=self.get_weather
def get_weather(self, args, raw_data):
city = args.get("city")
# Your logic here
return FunctionResult(f"The weather in {city} is sunny, 72 degrees")
define_tool() Across Languages
The define_tool() method is available in all SDK languages. The parameters JSON Schema is identical everywhere; only the calling syntax differs:
LanguageSyntax
Pythonagent.define_tool(name="x", description="d", parameters={...}, handler=self.fn)
TypeScriptagent.defineTool({ name: 'x', description: 'd', parameters: {...}, handler: (args) => {...} })
The define_tool() Method
Required Parameters:
ParameterDescription
nameUnique function name (lowercase, underscores)
descriptionWhat the function does (helps AI decide when to use)
parametersJSON Schema defining accepted arguments
handlerPython function to call
Optional Parameters:
secureRequire token validation (default: True)
fillersLanguage-specific filler phrases
webhook_urlExternal webhook URL (overrides local handler)
requiredList of required parameter names
Handler Function Signature
All handlers receive two arguments: the parsed function arguments and the full request data. The handler returns a FunctionResult with response text and optional actions.
Args:
args: Dictionary of parsed function arguments
{"city": "New York", "units": "fahrenheit"}
raw_data: Full request data including:
- call_id: Unique call identifier
- caller_id_num: Caller's phone number
- caller_id_name: Caller's name
- called_id_num: Number that was called
- And more...
Returns:
return FunctionResult("Response text")
The handler signature across languages:
LanguageSignature
Pythondef handler(self, args, raw_data): returns FunctionResult
TypeScript(args: Record<string, any>, raw?: Record<string, any>) => returns FunctionResult
Accessing Call Data
def check_account(self, args, raw_data):
# Get caller information
caller_number = raw_data.get("caller_id_num", "")
call_id = raw_data.get("call_id", "")
# Get function arguments
account_id = args.get("account_id")
# Use both for your logic
f"Account {account_id} for caller {caller_number} is active"
Multiple Functions
Register as many functions as your agent needs:
class CustomerServiceAgent(AgentBase):
super().__init__(name="customer-service")
# Order lookup
self.define_tool(
name="check_order",
parameters={
"type": "object",
"properties": {
"order_number": {
"type": "string",
"description": "The order number"
# Account balance
self.define_tool(
name="get_balance",
description="Get account balance for a customer",
parameters={
"type": "object",
"properties": {
"account_id": {
"type": "string",
"description": "Customer account ID"
"required": ["account_id"]
handler=self.get_balance
# Store hours
self.define_tool(
name="get_store_hours",
description="Get store hours for a location",
parameters={
"type": "object",
"properties": {
"location": {
"type": "string",
"description": "Store location or city"
"required": ["location"]
handler=self.get_store_hours
return FunctionResult(f"Order {order_number} is in transit")
def get_balance(self, args, raw_data):
return FunctionResult(f"Account {account_id} balance: $150.00")
def get_store_hours(self, args, raw_data):
location = args.get("location")
return FunctionResult(f"{location} store: Mon-Fri 9AM-9PM, Sat-Sun 10AM-6PM")
Function Fillers
Add per-function filler phrases for when the function is executing:
self.define_tool(
name="search_inventory",
description="Search product inventory",
parameters={
"type": "object",
"properties": {
"product": {"type": "string", "description": "Product to search"}
"required": ["product"]
handler=self.search_inventory,
fillers={
"en-US": [
"Let me check our inventory...",
"Searching our stock now...",
"One moment while I look that up..."
"es-MX": [
"Dejame revisar nuestro inventario...",
"Buscando en nuestro stock..."
The @tool Decorator
The @tool decorator is a Python-specific convenience. Other languages achieve the same result using define_tool() / defineTool() as shown in the examples above.
Alternative syntax using decorators:
@AgentBase.tool(
name="get_time",
description="Get the current time",
parameters={
"type": "object",
"properties": {
"timezone": {
"type": "string",
"description": "Timezone (e.g., 'EST', 'PST')"
def get_time(self, args, raw_data):
timezone = args.get("timezone", "UTC")
return FunctionResult(f"The current time in {timezone} is 3:45 PM")
define_tool() vs @tool: Choosing an Approach
Both methods register SWAIG functions with the same result. Choose based on your coding style and requirements.
Comparison
Aspectdefine_tool()@tool Decorator
Where definedInside __init__At method definition
Dynamic registrationEasyRequires workarounds
Conditional functionsStraightforwardMore complex
Code organizationDefinition separate from handlerSelf-documenting
InheritanceEasier to overrideWorks but less flexible
When to Use define_tool()
Conditional function registration:
def __init__(self, enable_admin=False):
# Always available
self.define_tool(name="get_info", ...)
# Only for admin mode
if enable_admin:
self.define_tool(name="admin_reset", ...)
Dynamic functions from configuration:
def __init__(self, functions_config):
for func in functions_config:
self.define_tool(
name=func["name"],
description=func["description"],
parameters=func["params"],
handler=getattr(self, func["handler_name"])
Handlers defined outside the class:
def external_handler(agent, args, raw_data):
return FunctionResult("Handled externally")
self.define_tool(
name="external_func",
description="Uses external handler",
parameters={...},
handler=lambda args, raw: external_handler(self, args, raw)
When to Use @tool Decorator
Static, self-documenting functions:
@AgentBase.tool(
name="check_order",
description="Look up order status",
parameters={...}
# Handler right here with its definition
return FunctionResult("...")
@AgentBase.tool(
name="get_balance",
description="Get account balance",
parameters={...}
The decorator keeps the function metadata with the implementation, making it easier to see what a function does at a glance.
Type-Inferred Functions
Type inference from function signatures is a Python-specific feature. Other languages require explicit JSON Schema parameter definitions via define_tool() / defineTool().
When using the @tool decorator (or define_tool()) without explicit parameters, the SDK automatically infers the JSON Schema from Python type hints. This eliminates boilerplate for straightforward functions.
from typing import Optional, Literal
class TypedAgent(AgentBase):
super().__init__(name="typed-agent")
@AgentBase.tool(name="check_order")
def check_order(self, order_number: str, include_tracking: bool = False):
"""Look up order status by order number.
Args:
order_number: The order number to look up
include_tracking: Include tracking URL in the response
status = "Shipped Monday, arriving Thursday"
result = f"Order {order_number}: {status}"
if include_tracking:
result += " Tracking: https://track.example.com/12345"
return FunctionResult(result)
@AgentBase.tool(name="set_priority")
def set_priority(self, ticket_id: str, level: Literal["low", "medium", "high"]):
"""Set the priority level for a support ticket.
Args:
ticket_id: The support ticket ID
level: Priority level to set
return FunctionResult(f"Ticket {ticket_id} set to {level} priority")
How type inference works:
Python TypeJSON Schema Type
str"string"
int"integer"
float"number"
bool"boolean"
list / List[str]"array" (with items)
dict"object"
Optional[X]Type of X, not required
Literal["a", "b"]"string" with enum
Rules:
  • Parameters without defaults and not Optional are marked as required
  • The function’s docstring summary becomes the tool description
  • Google-style Args: docstring sections provide per-parameter descriptions
  • A raw_data parameter is recognized and passed through (not included in schema)
  • If no type hints are present, the SDK falls back to the traditional (args, raw_data) convention
Accessing raw_data with typed functions:
@AgentBase.tool(name="caller_info")
def caller_info(self, raw_data: dict):
"""Get information about the current caller."""
caller = raw_data.get("caller_id_num", "unknown")
return FunctionResult(f"Your number is {caller}")
When to use type inference vs explicit parameters:
ScenarioRecommendation
Simple string/int/bool paramsType inference
Nested objects or complex schemasExplicit parameters
Enum constraintsLiteral type or explicit
Shared parameter schemasExplicit parameters
Mixing Both Approaches
You can use both in the same agent:
class HybridAgent(AgentBase):
def __init__(self, extra_functions=None):
super().__init__(name="hybrid")
# Dynamic functions via define_tool
if extra_functions:
for func in extra_functions:
self.define_tool(**func)
# Static function via decorator
@AgentBase.tool(
name="get_help",
description="Get help information",
parameters={"type": "object", "properties": {}}
def get_help(self, args, raw_data):
return FunctionResult("How can I help you?")
Registering Pre-Built SWAIG Functions
The register_swaig_function() method registers a function definition object directly (used with DataMap and external definitions). This is a lower-level method than define_tool():
LanguageSyntax
Pythonagent.register_swaig_function(dm.to_swaig_function())
TypeScriptagent.registerSwaigFunction(dm.toSwaigFunction())
External Webhook Functions
Route function calls to an external webhook:
self.define_tool(
name="external_lookup",
description="Look up data from external service",
parameters={
"type": "object",
"properties": {
"query": {"type": "string", "description": "Search query"}
"required": ["query"]
handler=None, # No local handler
webhook_url="https://external-service.com/api/lookup"
Function Security
By default, functions require token validation. Disable for testing:
# Secure function (default)
self.define_tool(
name="secure_function",
description="Requires token validation",
handler=self.secure_handler,
secure=True # Default
# Insecure function (testing only)
self.define_tool(
name="test_function",
description="No token validation (testing only)",
handler=self.test_handler,
secure=False # Disable for testing
Writing Good Descriptions
The description helps the AI decide when to use your function:
# Good - specific and clear
description="Look up order status by order number. Returns shipping status and estimated delivery date."
# Bad - too vague
description="Get order info"
# Good - mentions what triggers it
description="Check if a product is in stock. Use when customer asks about availability."
# Good - explains constraints
description="Transfer call to human support. Only use if customer explicitly requests to speak with a person."
Testing Functions
Use swaig-test to test your functions:
# List all functions
swaig-test my_agent.py --list-tools
# Test a specific function
swaig-test my_agent.py --exec check_order --order_number 12345
# See the generated SWML
Complete Example
The following example is shown in Python. All concepts demonstrated (multiple define_tool() calls, fillers, handlers) work identically in other SDK languages using the syntax shown in the Quick Start and define_tool() tables above.
#!/usr/bin/env python3
# restaurant_agent.py - Restaurant order assistant
class RestaurantAgent(AgentBase):
MENU = {
"burger": {"price": 12.99, "description": "Angus beef burger with fries"},
"pizza": {"price": 14.99, "description": "12-inch cheese pizza"},
"salad": {"price": 9.99, "description": "Garden salad with dressing"}
super().__init__(name="restaurant-agent")
"Role",
"You are a friendly restaurant order assistant."
self.define_tool(
name="get_menu_item",
description="Get details about a menu item including price and description",
parameters={
"type": "object",
"properties": {
"item_name": {
"type": "string",
"description": "Name of the menu item"
"required": ["item_name"]
handler=self.get_menu_item,
fillers={
"en-US": ["Let me check the menu..."]
self.define_tool(
name="place_order",
description="Place an order for menu items",
parameters={
"type": "object",
"properties": {
"items": {
"type": "array",
"items": {"type": "string"},
"description": "List of menu items to order"
"special_requests": {
"type": "string",
"description": "Any special requests or modifications"
"required": ["items"]
handler=self.place_order,
fillers={
"en-US": ["Placing your order now..."]
def get_menu_item(self, args, raw_data):
item_name = args.get("item_name", "").lower()
item = self.MENU.get(item_name)
if item:
f"{item_name.title()}: {item['description']}. Price: ${item['price']}"
return FunctionResult(f"Sorry, {item_name} is not on our menu.")
def place_order(self, args, raw_data):
items = args.get("items", [])
special = args.get("special_requests", "")
total = sum(
self.MENU.get(item.lower(), {}).get("price", 0)
for item in items
if total > 0:
msg = f"Order placed: {', '.join(items)}. Total: ${total:.2f}"
if special:
msg += f" Special requests: {special}"
return FunctionResult(msg)
return FunctionResult("Could not place order. Please check item names.")
agent = RestaurantAgent()
