Local Development
Server configuration
Custom host and port
LanguageCustom Host and Port
Pythonagent.run(host="0.0.0.0", port=8080)
TypeScriptagent.run({ host: "0.0.0.0", port: 8080 })
Using serve() directly (Python)
For more control, use serve() instead of run():
# Development server
agent.serve(host="127.0.0.1", port=3000)
# Listen on all interfaces
agent.serve(host="0.0.0.0", port=3000)
Development endpoints
EndpointMethodPurpose
/GET/POSTSWML document
/swaigPOSTSWAIG function calls
/post_promptPOSTPost-prompt handling
/debugGET/POSTDebug information
/debug_eventsPOSTReal-time debug events (when enable_debug_events() is active)
/healthGETHealth check (AgentServer only)
Testing your agent
View SWML output
# Get the SWML document (use credentials from agent startup output or env vars)
curl -u "$SWML_BASIC_AUTH_USER:$SWML_BASIC_AUTH_PASSWORD" http://localhost:3000/
# Pretty print with jq
curl -u "$SWML_BASIC_AUTH_USER:$SWML_BASIC_AUTH_PASSWORD" http://localhost:3000/ | jq .
Using swaig-test CLI
# List available functions
swaig-test my_agent.py --list-tools
# Test a specific function
swaig-test my_agent.py --exec get_weather --city "Seattle"
# Dump SWML output
Exposing local server
SignalWire needs to reach your agent via a public URL. Use ngrok or similar:
Connection Flow: SignalWire Cloud —> ngrok tunnel —> localhost:3000
Steps:
  1. Start your agent (see run command table above)
  2. Start ngrok: ngrok http 3000
  3. Use ngrok URL in SignalWire: https://abc123.ngrok.io
Using ngrok
# Start your agent (example with Python; substitute your language's run command)
python my_agent.py
# In another terminal, start ngrok
ngrok http 3000
ngrok provides a public URL like https://abc123.ngrok.io that forwards to your local server.
Using localtunnel
# Install
npm install -g localtunnel
# Start tunnel
lt --port 3000
Environment variables for development
These environment variables work across all SDK languages:
VariablePurposeDefault
SWML_BASIC_AUTH_PASSWORDAuth passwordAuto-generated
SWML_BASIC_AUTH_USERAuth usernamesignalwire
SWML_PROXY_URL_BASEPublic URL (behind proxy)Auto-detected
SWML_ALLOW_PRIVATE_URLSAllow private IP requestsfalse
# Authentication (username defaults to 'signalwire' when not set)
# Only the password is required; omit both to disable auth for local testing
export SWML_BASIC_AUTH_PASSWORD="test123"
# Or disable authentication entirely for local testing
export SWML_BASIC_AUTH_USER=""
export SWML_BASIC_AUTH_PASSWORD=""
# Override proxy URL if behind ngrok
export SWML_PROXY_URL_BASE="https://abc123.ngrok.io"
# APP_URL is also accepted as a fallback (useful for Dokku deployments)
# Allow DataMap/skill requests to private IPs (e.g., local backend services)
export SWML_ALLOW_PRIVATE_URLS=true
Proxy URL configuration
When behind ngrok or another proxy, the SDK needs to know the public URL:
import os
# Option 1: Environment variable
os.environ['SWML_PROXY_URL_BASE'] = 'https://abc123.ngrok.io'
# Option 2: Auto-detection from X-Forwarded headers
# The SDK automatically detects proxy from request headers
Development workflow
1. Code
Write/modify your agent code.
2. Test Locally
  • swaig-test my_agent.py --dump-swml
  • swaig-test my_agent.py --exec function_name --param value
3. Run Server
python my_agent.py (or your language’s equivalent run command)
4. Expose Publicly
ngrok http 3000
5. Test with SignalWire
Point phone number to ngrok URL and make test call.
Debug mode
Enable debug logging:
import logging
logging.basicConfig(level=logging.DEBUG)
agent = MyAgent()
Or via environment variable:
export SIGNALWIRE_LOG_MODE=default
python my_agent.py
Hot reloading
For automatic reloading during development, use uvicorn directly:
# Install uvicorn with reload support
pip install "uvicorn[standard]"
# Run with auto-reload
uvicorn my_agent:agent._app --reload --host 0.0.0.0 --port 3000
Or create a development script:
# dev.py
from my_agent import MyAgent
agent = MyAgent()
app = agent._app # Expose the ASGI app for uvicorn
Then run:
uvicorn dev:app --reload --port 3000
Serving static files
Use AgentServer.serve_static_files() to serve static files alongside your agents. This is useful for web dashboards, documentation, or any static content:
from signalwire import AgentServer
from pathlib import Path
# Create your agents
from my_agents import SupportAgent, SalesAgent
HOST = "0.0.0.0"
PORT = 3000
server = AgentServer(host=HOST, port=PORT)
server.register(SupportAgent(), "/support")
# Serve static files from web directory
web_dir = Path(__file__).parent / "web"
if web_dir.exists():
server.serve_static_files(str(web_dir))
server.run()
Directory Structure:
my_project/
├── server.py
├── my_agents.py
└── web/
├── index.html
├── styles.css
└── app.js
Key Points:
  • Use server.serve_static_files(directory) to serve static files
  • Agent routes always take priority over static files
  • Requests to / serve index.html from the static directory
  • Both /support and /support/ work correctly with agents
Route Priority:
RouteHandler
/supportSupportAgent
/salesSalesAgent
/healthAgentServer health check
/*Static files (fallback)
Common development issues
IssueSolution
Port already in useUse different port: agent.run(port=8080)
401 UnauthorizedCheck SWML_BASIC_AUTH_* env vars
Functions not foundVerify function registration
SWML URL wrongSet SWML_PROXY_URL_BASE for ngrok
Connection refusedEnsure agent is running on correct port
Static files not foundCheck web_dir.exists() and path is correct
