title: Mapping Numbers
description: Connect phone numbers to your agent using SignalWire's SWML Script resources.
slug: /guides/mapping-numbers
max-toc-depth: 3
### Overview
SignalWire uses **SWML Script** resources to connect phone numbers to your agent. When a call comes in, SignalWire fetches SWML from your agent's URL and executes it.
<Frame caption="Caller dials">
  <img class="diagram" src="https://files.buildwithfern.com/signalwire.docs.buildwithfern.com/docs/6e8bf262a3007839310b65fdbb821c13150f1abb355f6c72723ab2316e547b75/assets/images/sdks/diagrams/08_03_mapping-numbers_diagram1.webp" alt="Caller dials a SignalWire number and the call is routed to your agent." />
</Frame>
### Step 1: Create a SWML Script Resource
1. Log in to SignalWire dashboard
2. Navigate to **My Resources** in the left sidebar
3. Click **Script**
4. Click **New SWML Script**
5. Fill in the fields:
   * **Name:** Give your script a name (e.g., "my-agent")
   * **Handle Calls Using:** Select **External URL**
   * **Primary Script URL:** Enter your agent URL with credentials
     * Format: `https://user:pass@your-domain.com/agent`
6. Click **Create**
<Frame caption="New SWML Script">
  <img class="diagram" src="https://files.buildwithfern.com/signalwire.docs.buildwithfern.com/docs/1c71b94a99fe653355fc7351b6731aeea8796c17ea173f6d82a685d81de20b8f/assets/images/sdks/diagrams/08_03_mapping-numbers_diagram3.webp" alt="Creating a new SWML Script resource in the SignalWire dashboard." />
</Frame>
### Step 2: Add a Phone Number or Address
After creating the script, you'll see the resource configuration page:
<Frame caption="Back to Resources">
  <img class="diagram" src="https://files.buildwithfern.com/signalwire.docs.buildwithfern.com/docs/c345571bfa532c645c5e889a11c260b6e47e4dfd1f6fc593f3b0a2f83229ac07/assets/images/sdks/diagrams/08_03_mapping-numbers_diagram4.webp" alt="Resource configuration page in the SignalWire dashboard." />
</Frame>
1. Click the **Addresses & Phone Numbers** tab
2. Click **+ Add**
3. Choose your address type:
   * **Phone Number:** For receiving calls from regular phones (PSTN)
   * **SIP Address:** For receiving SIP calls
   * **Alias:** For referencing this resource by a custom name
4. Follow the prompts to select or purchase a phone number
5. Your number is now connected to your agent!
<Frame caption="Add an Address">
  <img class="diagram" src="https://files.buildwithfern.com/signalwire.docs.buildwithfern.com/docs/6816f0b7ae0b03cb039c67d3105343a0722f62c4a6e9005d7acc6f90043aec70/assets/images/sdks/diagrams/08_03_mapping-numbers_diagram5.webp" alt="Adding a phone number or address to a SWML Script resource." />
</Frame>
### Step 3: Test Your Setup
1. Ensure your agent is running locally
2. Ensure ngrok is running (if using tunneling)
3. Call your SignalWire phone number
4. Hear your agent respond!
### URL Format
Your agent URL structure depends on your setup:
**Single Agent:**
```text
https://your-server.com/
**Multiple Agents:**
```text
https://your-server.com/support
https://your-server.com/sales
https://your-server.com/billing
**With Authentication (recommended):**
```text
https://user:pass@your-server.com/
### Using ngrok for Development
```bash
# Start your agent locally
python my_agent.py
# In another terminal, start ngrok
ngrok http 3000
# Use the ngrok HTTPS URL in SignalWire
# https://abc123.ngrok.io
For a static URL that doesn't change on restart:
```bash
ngrok http --url=https://your-name.ngrok-free.app 3000
### Basic Authentication
The SDK automatically generates authentication credentials on startup:
```text
Agent 'my-agent' is available at:
URL: http://localhost:3000
Basic Auth: signalwire:7vVZ8iMTOWL0Y7-BG6xaN3qhjmcm4Sf59nORNdlF9bs (source: generated)
For persistent credentials, set environment variables:
```bash
export SWML_BASIC_AUTH_USER=signalwire
export SWML_BASIC_AUTH_PASSWORD=your-secure-password
In SignalWire, use URL with credentials:
```text
https://signalwire:your-secure-password@your-server.com/
### Multi-Agent Server
Run multiple agents on one server:
| Language   | Server Registration                               |
| Python     | `server.register(SupportAgent(), "/support")`     |
| TypeScript | `server.register(new SupportAgent(), "/support")` |
from signalwire import AgentServer
server = AgentServer()
# Register agents at different paths
server.register(BillingAgent(), "/billing")
server.run(host="0.0.0.0", port=3000)
Create a separate SWML Script resource for each agent:
| Number            | SWML Script URL              |
| +1 (555) 111-1111 | `https://server.com/support` |
| +1 (555) 222-2222 | `https://server.com/sales`   |
| +1 (555) 333-3333 | `https://server.com/billing` |
### Fallback URL
Configure a fallback for errors:
| Setting      | Value                             |
| Primary URL  | `https://your-server.com/agent`   |
| Fallback URL | `https://backup-server.com/agent` |
**Fallback triggers on:**
* Connection timeout
* HTTP 5xx errors
* Invalid SWML response
### Troubleshooting
#### Common Issues
| Symptom           | Likely Cause      | Fix                                  |
| Connection errors | ngrok not running | Start ngrok in a terminal            |
| 502 Bad Gateway   | Wrong port        | Match ngrok port to agent port       |
| 401 Unauthorized  | Auth mismatch     | Check credentials match agent output |
| 502/503 errors    | Agent crashed     | Check agent terminal, restart        |
#### Test Checklist
```bash
# 1. Agent running?
curl http://localhost:3000/
# 2. Tunnel working?
curl https://your-name.ngrok-free.app/
# 3. Auth working?
curl https://user:pass@your-name.ngrok-free.app/
# 4. SWML valid?
swaig-test agent.py --dump-swml
### Verification Checklist
Before going live:
* [ ] Agent is deployed and running
* [ ] HTTPS URL is accessible
* [ ] URL returns valid SWML on POST request
* [ ] Basic auth is configured
* [ ] SWML Script resource created in SignalWire
* [ ] Phone number added to SWML Script resource
* [ ] Test call completes successfully
