> This page is for Server SDKs.
# Exposing Your Agent to the Internet
> Use ngrok to create a public URL for your local agent so SignalWire can send webhook requests to it.
[Architecture]: /docs/server-sdks/guides/architecture
[signalwire-integration]: /docs/server-sdks/guides/phone-numbers
[deployment]: /docs/server-sdks/guides/deploy
### Why You Need a Public URL
SignalWire's cloud needs to reach your agent via HTTP:
```mermaid
flowchart LR
    cloud["SignalWire Cloud"] -. "cannot reach a private address" .-> local["Your agent<br />localhost:3000"]
```mermaid
sequenceDiagram
    participant Cloud as SignalWire Cloud
    participant Ngrok as ngrok cloud tunnel<br />https://abc123.ngrok.io
    participant Agent as Your agent<br />http://localhost:3000
    Cloud->>Ngrok: HTTP request to public URL
    Ngrok->>Agent: Forward request through tunnel
    Agent-->>Ngrok: HTTP response
    Ngrok-->>Cloud: Forward response
### Installing ngrok
#### macOS (Homebrew)
```bash
brew install ngrok
#### Linux
```bash
## Download
curl -s https://ngrok-agent.s3.amazonaws.com/ngrok.asc | \
  sudo tee /etc/apt/trusted.gpg.d/ngrok.asc >/dev/null && \
  echo "deb https://ngrok-agent.s3.amazonaws.com buster main" | \
  sudo tee /etc/apt/sources.list.d/ngrok.list
## Install
sudo apt update && sudo apt install ngrok
#### Windows
```powershell
## Using Chocolatey
choco install ngrok
## Or download from https://ngrok.com/download
#### Direct Download
Visit [ngrok.com/download](https://ngrok.com/download) and download for your platform.
### Create an ngrok Account (Free)
1. Go to [ngrok.com](https://ngrok.com) and sign up
2. Get your auth token from the dashboard
3. Configure ngrok with your token:
```bash
ngrok config add-authtoken YOUR_AUTH_TOKEN_HERE
This enables:
* Longer session times
* Custom subdomains (paid)
* Multiple tunnels
### Basic Usage
Start your agent in one terminal:
```bash
## Terminal 1 (use the command for your language)
python my_agent.py       # Python
npx tsx my_agent.ts      # TypeScript
go run my_agent.go       # Go
ruby my_agent.rb         # Ruby
java MyAgent             # Java
perl my_agent.pl         # Perl
./my_agent               # C++ (compiled)
php my_agent.php         # PHP
Start ngrok in another terminal:
```bash
## Terminal 2
ngrok http 3000
You'll see output like:
```text
ngrok                                                           (Ctrl+C to quit)
Session Status                online
Account                       your-email@example.com (Plan: Free)
Version                       3.x.x
Region                        United States (us)
Latency                       45ms
Web Interface                 http://127.0.0.1:4040
Forwarding                    https://abc123def456.ngrok-free.app -> http://localhost:3000
Connections                   ttl     opn     rt1     rt5     p50     p90
                              0       0       0.00    0.00    0.00    0.00
Your public URL is: `https://abc123def456.ngrok-free.app`
### Test the Tunnel
```bash
## Test locally (use credentials from agent startup output or env vars)
curl -u "$SWML_BASIC_AUTH_USER:$SWML_BASIC_AUTH_PASSWORD" http://localhost:3000/
## Test through ngrok (use YOUR URL from ngrok output)
curl -u "$SWML_BASIC_AUTH_USER:$SWML_BASIC_AUTH_PASSWORD" https://abc123def456.ngrok-free.app/
Both should return the same SWML document.
### ngrok Web Interface
ngrok provides a web interface at `http://127.0.0.1:4040` showing:
* All requests coming through the tunnel
* Request/response headers and bodies
* Timing information
* Ability to replay requests
This is invaluable for debugging SignalWire webhook calls!
### Static Domains (Recommended)
Free ngrok gives you random URLs that change each restart. For easier development, use a static domain:
#### Free Static Domain (ngrok account required)
1. Go to ngrok Dashboard -> Domains
2. Create a free static domain (e.g., `your-name.ngrok-free.app`)
3. Use it:
```bash
ngrok http --url=https://your-name.ngrok-free.app 3000
Now your URL stays the same across restarts!
### Understanding Basic Authentication
> **Note**
> The SDK automatically secures your agent with HTTP Basic Authentication. Every time you start your agent, you'll see:
> ```text
> Agent 'my-agent' is available at:
> URL: http://localhost:3000
> Basic Auth: signalwire:7vVZ8iMTOWL0Y7-BG6xaN3qhjmcm4Sf59nORNdlF9bs (source: provided)
> **The password changes on every restart** unless you set environment variables.
#### Setting Persistent Credentials
For development, set these environment variables to use the same credentials across restarts:
```bash
## In your .env file or shell
export SWML_BASIC_AUTH_USER=signalwire
export SWML_BASIC_AUTH_PASSWORD=your-secure-password-here
Then start your agent:
```bash
python my_agent.py
Now it will show:
```text
Basic Auth: signalwire:your-secure-password-here (source: environment)
**Why this matters:**
* SignalWire needs these credentials to call your agent
* Random passwords mean reconfiguring SignalWire on every restart
* Set environment variables once for consistent development
### Configure Your Agent for ngrok
Set the `SWML_PROXY_URL_BASE` environment variable so your agent generates correct webhook URLs:
```bash
SWML_PROXY_URL_BASE=https://your-name.ngrok-free.app
Or set them when running:
```bash
SWML_PROXY_URL_BASE=https://your-name.ngrok-free.app \
SWML_BASIC_AUTH_USER=signalwire \
SWML_BASIC_AUTH_PASSWORD=your-secure-password-here \
python my_agent.py
This ensures:
* SWAIG function webhook URLs point to your public ngrok URL, not localhost
* Authentication credentials remain consistent across restarts
### Complete Development Setup
Here's the full workflow:
```bash
## Terminal 1: Start ngrok with static domain
## Terminal 2: Start agent with environment variables
export SWML_PROXY_URL_BASE=https://your-name.ngrok-free.app
python my_agent.py
## Terminal 3: Test (use the credentials from Terminal 2)
curl -u signalwire:your-secure-password-here https://your-name.ngrok-free.app/
curl -u signalwire:your-secure-password-here https://your-name.ngrok-free.app/debug
### Using a Script
Create `start-dev.sh`:
```bash
#!/bin/bash
## start-dev.sh - Start development environment
NGROK_DOMAIN="your-name.ngrok-free.app"
AUTH_USER="signalwire"
AUTH_PASS="your-secure-password-here"
echo "Starting development environment..."
echo "Public URL: https://${NGROK_DOMAIN}"
echo "Basic Auth: ${AUTH_USER}:${AUTH_PASS}"
echo ""
## Start ngrok in background
ngrok http --url=https://${NGROK_DOMAIN} 3000 &
NGROK_PID=$!
## Wait for ngrok to start
sleep 2
## Start agent with environment variables
export SWML_PROXY_URL_BASE="https://${NGROK_DOMAIN}"
export SWML_BASIC_AUTH_USER="${AUTH_USER}"
export SWML_BASIC_AUTH_PASSWORD="${AUTH_PASS}"
python my_agent.py
## Cleanup on exit
trap "kill $NGROK_PID 2>/dev/null" EXIT
Make it executable:
```bash
chmod +x start-dev.sh
./start-dev.sh
### Alternative Tunneling Solutions
#### Cloudflare Tunnel (Free)
```bash
## Install cloudflared
brew install cloudflared  # macOS
## Quick tunnel (no account needed)
cloudflared tunnel --url http://localhost:3000
#### localtunnel (Free, no signup)
```bash
## Install
npm install -g localtunnel
## Run
lt --port 3000
#### tailscale Funnel (Requires Tailscale)
```bash
## If you use Tailscale
tailscale funnel 3000
### Production Alternatives
For production, don't use ngrok. Instead:
| Option         | Description                                         |
| **Cloud VM**   | Deploy to AWS, GCP, Azure, DigitalOcean             |
| **Serverless** | AWS Lambda, Google Cloud Functions, Azure Functions |
| **Container**  | Docker on Kubernetes, ECS, Cloud Run                |
| **VPS**        | Any server with a public IP                         |
See the [Deployment][deployment] chapter for production deployment guides.
### Troubleshooting
#### ngrok shows "ERR_NGROK_108"
Your auth token is invalid or expired. Get a new one from the ngrok dashboard:
```bash
ngrok config add-authtoken YOUR_NEW_TOKEN
#### Connection refused
Your agent isn't running or is on a different port:
```bash
## Check agent is running
curl http://localhost:3000/
## If using different port
ngrok http 8080
#### Webhook URLs still show localhost
Set `SWML_PROXY_URL_BASE`:
```bash
export SWML_PROXY_URL_BASE=https://your-domain.ngrok-free.app
python my_agent.py
#### ngrok tunnel expires
Free ngrok tunnels expire after a few hours. Solutions:
* Restart ngrok
* Use a static domain (stays same after restart)
* Upgrade to paid ngrok plan
* Use an alternative like Cloudflare Tunnel
### What's Next?
Your agent is now accessible at a public URL. You're ready to connect it to SignalWire!
### You've Completed Phase 1!
* [x] Installed the SDK
* [x] Created your first agent
* [x] Set up development environment
* [x] Exposed agent via ngrok
Your agent is ready at: `https://your-domain.ngrok-free.app`
**Next Chapter: [Architecture][Architecture]** - Deep dive into SWML, SWAIG, and agent architecture
**Or jump to: [SignalWire Integration][signalwire-integration]** - Connect your agent to phone numbers
