# Call Flow Customization
> Control call flow with verb insertion points for pre-answer, post-answer, and post-AI actions.
[ref-agentbase]: /docs/server-sdks/reference/python/agents/agent-base
### Understanding Call Flow
By default, [`AgentBase`][ref-agentbase] generates a simple call flow:
```text
answer -> ai
The SDK provides three insertion points to customize this flow:
<Frame caption="Call flow insertion points">
  <img class="diagram" src="https://files.buildwithfern.com/signalwire.docs.buildwithfern.com/docs/a85f1c4a852ea56438815c08d89b487b4bb8505be2928e147047d9b128e352cb/assets/images/sdks/diagrams/03_07_call-flow_diagram1.webp" alt="Call flow insertion points for pre-answer, post-answer, and post-AI verbs." />
</Frame>
### Verb Insertion Methods
| Method                   | Purpose                 | Common Uses                  |
| `add_pre_answer_verb()`  | Before answering        | Ringback, screening, routing |
| `add_post_answer_verb()` | After answer, before AI | Announcements, disclaimers   |
| `add_post_ai_verb()`     | After AI ends           | Cleanup, transfers, surveys  |
The verb insertion methods are available in all languages:
| Language   | Pre-Answer                          | Post-Answer                          | Post-AI                          |
| Python     | `add_pre_answer_verb(verb, params)` | `add_post_answer_verb(verb, params)` | `add_post_ai_verb(verb, params)` |
| TypeScript | `addPreAnswerVerb(verb, params)`    | `addPostAnswerVerb(verb, params)`    | `addPostAiVerb(verb, params)`    |
### Pre-Answer Verbs
Pre-answer verbs run while the call is still ringing. Use them for:
* **Ringback tones**: Play audio before answering
* **Call screening**: Check caller ID or time
* **Conditional routing**: Route based on variables
<Tabs>
  <Tab title="Python">
    #!/usr/bin/env python3
    class RingbackAgent(AgentBase):
        """Agent that plays ringback tone before answering."""
            super().__init__(name="ringback", port=3000)
            # Play US ringback tone before answering
            # IMPORTANT: auto_answer=False prevents play from answering the call
            self.add_pre_answer_verb("play", {
                "urls": ["ring:us"],
                "auto_answer": False
            # Configure AI
        agent = RingbackAgent()
  </Tab>
  <Tab title="TypeScript">
    ```typescript
    import { AgentBase } from '@signalwire/sdk';
    const agent = new AgentBase({ name: 'ringback', port: 3000 });
    agent.addPreAnswerVerb('play', { urls: ['ring:us'], auto_answer: false });
    agent.addLanguage({ name: 'English', code: 'en-US', voice: 'rime.spore' });
    agent.promptAddSection('Role', { body: 'You are a helpful assistant.' });
    agent.run();
  </Tab>
</Tabs>
**Generated SWML:**
```json
  "sections": {
    "main": [
      {"play": {"urls": ["ring:us"], "auto_answer": false}},
      {"answer": {}},
      {"ai": {...}}
#### Pre-Answer Safe Verbs
Only certain verbs can run before the call is answered:
| Verb       | Pre-Answer Safe | Notes                         |
| `play`     | Yes\*           | Requires `auto_answer: false` |
| `connect`  | Yes\*           | Requires `auto_answer: false` |
| `sleep`    | Yes             | Wait for duration             |
| `set`      | Yes             | Set variables                 |
| `request`  | Yes             | HTTP request                  |
| `switch`   | Yes             | Variable-based branching      |
| `cond`     | Yes             | Conditional branching         |
| `if`       | Yes             | If/then/else                  |
| `eval`     | Yes             | Evaluate expressions          |
| `goto`     | Yes             | Jump to label                 |
| `label`    | Yes             | Define jump target            |
| `hangup`   | Yes             | Reject call                   |
| `transfer` | Yes             | Route elsewhere               |
\*These verbs auto-answer by default. Set `auto_answer: false` for pre-answer use.
#### Available Ringback Tones
| Tone      | Description            |
| `ring:us` | US ringback tone       |
| `ring:uk` | UK ringback tone       |
| `ring:it` | Italian ringback tone  |
| `ring:at` | Austrian ringback tone |
### Post-Answer Verbs
Post-answer verbs run after the call is connected but before the AI speaks:
<Tabs>
    class WelcomeAgent(AgentBase):
        """Agent that plays welcome message before AI."""
            super().__init__(name="welcome", port=3000)
            # Play welcome announcement
            self.add_post_answer_verb("play", {
                "url": "say:Thank you for calling Acme Corporation. "
                       "Your call may be recorded for quality assurance."
            # Brief pause before AI speaks
            self.add_post_answer_verb("sleep", {"time": 500})
            # Configure AI
            self.prompt_add_section(
                "Role",
                "You are a customer service representative. "
                "The caller has just heard the welcome message."
        agent = WelcomeAgent()
  </Tab>
    ```typescript
    const agent = new AgentBase({ name: 'welcome', port: 3000 });
    agent.addPostAnswerVerb('play', {
      url: 'say:Thank you for calling Acme Corporation. Your call may be recorded for quality assurance.',
    agent.addPostAnswerVerb('sleep', { time: 500 });
      body: 'You are a customer service representative. The caller has just heard the welcome message.',
    agent.run();
  </Tab>
</Tabs>
**Generated SWML:**
```json
  "sections": {
    "main": [
      {"answer": {}},
      {"play": {"url": "say:Thank you for calling..."}},
      {"sleep": {"time": 500}},
      {"ai": {...}}
#### Common Post-Answer Uses
| Use Case         | Example                                       |
| Welcome message  | `{"url": "say:Thank you for calling..."}`     |
| Legal disclaimer | `{"url": "say:This call may be recorded..."}` |
| Hold music       | `{"url": "https://example.com/hold.mp3"}`     |
| Pause            | `{"time": 500}` (milliseconds)                |
| Recording        | Use `record_call=True` in constructor         |
### Post-AI Verbs
Post-AI verbs run after the AI conversation ends:
class SurveyAgent(AgentBase):
    """Agent that logs call outcome after conversation."""
        super().__init__(name="survey", port=3000)
        # Configure AI
        self.prompt_add_section("Role", "You are a support agent.")
        # After AI ends, log the call and hang up
        self.add_post_ai_verb("request", {
            "url": "https://api.example.com/call-complete",
            "method": "POST"
        self.add_post_ai_verb("hangup", {})
    agent = SurveyAgent()
#### Common Post-AI Uses
| Use Case          | Verb          | Example                        |
| Clean disconnect  | `hangup`      | `{}`                           |
| Transfer to human | `transfer`    | `{"dest": "tel:+15551234567"}` |
| Post-call survey  | `prompt`      | DTMF collection                |
| Log outcome       | `request`     | HTTP POST to API               |
| Connect to queue  | `enter_queue` | `{"name": "support"}`          |
### Complete Example
Here's an agent with all three insertion points:
<Tabs>
    class CallFlowAgent(AgentBase):
        """Agent demonstrating complete call flow customization."""
            super().__init__(name="call-flow", port=3000)
            # PRE-ANSWER: Ringback tone
            # POST-ANSWER: Welcome and disclaimer
                "url": "say:Welcome to Acme Corporation."
                "url": "say:This call may be recorded for quality assurance."
            # Configure AI
                "Role",
                "You are a friendly customer service representative. "
            self.set_params({
                "end_of_speech_timeout": 1000,
                "attention_timeout": 10000
            # POST-AI: Clean disconnect
        agent = CallFlowAgent()
  </Tab>
    ```typescript
    const agent = new AgentBase({ name: 'call-flow', port: 3000 });
    agent.addPostAnswerVerb('play', { url: 'say:Welcome to Acme Corporation.' });
    agent.addPostAnswerVerb('play', { url: 'say:This call may be recorded for quality assurance.' });
      body: 'You are a friendly customer service representative. The caller has just heard the welcome message.',
    agent.setParams({ end_of_speech_timeout: 1000, attention_timeout: 10000 });
    agent.addPostAiVerb('hangup', {});
    agent.run();
  </Tab>
</Tabs>
**Generated SWML:**
```json
  "sections": {
    "main": [
      {"answer": {}},
      {"play": {"url": "say:Welcome to Acme Corporation."}},
      {"play": {"url": "say:This call may be recorded..."}},
      {"ai": {...}},
      {"hangup": {}}
### Controlling Answer Behavior
#### Disable Auto-Answer
Set `auto_answer=False` to prevent automatic answering:
class ManualAnswerAgent(AgentBase):
        # Disable auto-answer
        super().__init__(name="manual", port=3000, auto_answer=False)
        # Pre-answer: Play ringback
#### Customize Answer Verb
Use `add_answer_verb()` to configure the answer verb:
# Set max call duration to 1 hour
agent.add_answer_verb({"max_duration": 3600})
### Dynamic Call Flow
Modify call flow based on caller information using `on_swml_request()`:
class DynamicFlowAgent(AgentBase):
        super().__init__(name="dynamic", port=3000)
        self.prompt_add_section("Role", "You are a receptionist.")
        # VIP numbers get special treatment
        self.vip_numbers = ["+15551234567", "+15559876543"]
    def on_swml_request(self, request_data=None, callback_path=None, request=None):
        call_data = (request_data or {}).get("call", {})
        caller = call_data.get("from", "")
        if caller in self.vip_numbers:
            # VIP: No ringback, immediate welcome
            self.clear_pre_answer_verbs()
                "url": "say:Welcome back, valued customer!"
        else:
            # Regular caller: Ringback tone
### Clear Methods
Remove verbs from insertion points:
agent.clear_pre_answer_verbs()   # Remove all pre-answer verbs
agent.clear_post_answer_verbs()  # Remove all post-answer verbs
agent.clear_post_ai_verbs()      # Remove all post-AI verbs
### Method Chaining
All verb insertion methods return `self` for chaining:
agent = AgentBase(name="chained", port=3000)
agent.add_pre_answer_verb("play", {"urls": ["ring:us"], "auto_answer": False}) \
     .add_post_answer_verb("play", {"url": "say:Welcome"}) \
     .add_post_answer_verb("sleep", {"time": 500}) \
