title: Account Setup
description: Create and configure your SignalWire account to connect agents to phone numbers.
slug: /guides/account-setup
max-toc-depth: 3
[account-setup]: /docs/server-sdks/guides/account-setup
[phone-numbers]: /docs/server-sdks/guides/phone-numbers
[mapping-numbers]: /docs/server-sdks/guides/mapping-numbers
[testing]: /docs/server-sdks/guides/testing
[troubleshooting]: /docs/server-sdks/guides/troubleshooting
## What You'll Learn
This chapter covers SignalWire integration:
1. **Account Setup** - Create and configure your SignalWire account
2. **Phone Numbers** - Purchase and manage phone numbers
3. **Mapping Numbers** - Connect phone numbers to your agents
4. **Testing** - Test your agents before going live
5. **Troubleshooting** - Common issues and solutions
## Integration Overview
<Frame caption="SignalWire Integration">
  <img class="diagram" src="https://files.buildwithfern.com/signalwire.docs.buildwithfern.com/docs/d2af6781d397c6656786341b2f1ce1ade8e9f5728d5ac3977fe325accfc0de93/assets/images/sdks/diagrams/08_01_account-setup_diagram1.webp" alt="SignalWire integration overview." />
</Frame>
## Prerequisites
Before connecting to SignalWire:
* Working agent (tested locally)
* Publicly accessible server
* SignalWire account
## Chapter Contents
| Section                            | Description                           |
| [Account Setup][account-setup]     | Create SignalWire account and project |
| [Phone Numbers][phone-numbers]     | Purchase and manage numbers           |
| [Mapping Numbers][mapping-numbers] | Connect numbers to agents             |
| [Testing][testing]                 | Test calls and debugging              |
| [Troubleshooting][troubleshooting] | Common issues and fixes               |
## Quick Integration Steps
### Step 1: Account Setup
* Create SignalWire account
* Create a project
* Note your Space Name
### Step 2: Phone Number
* Purchase a phone number
* Or use a SIP endpoint
### Step 3: Deploy Agent
* Deploy agent to public URL
* Verify HTTPS is working
* Test SWML endpoint responds
### Step 4: Connect
* Point phone number to agent URL
* Make test call
* Verify agent responds
## Architecture
<Frame caption="Call Flow Architecture">
  <img class="diagram" src="https://files.buildwithfern.com/signalwire.docs.buildwithfern.com/docs/a2108fedf6f5524f1dde83a9d1a8a35a7906859adf88cc0f570e11b6bb9a9721/assets/images/sdks/diagrams/08_01_account-setup_diagram2.webp" alt="Call flow architecture between SignalWire and your agent." />
</Frame>
## Required URLs
Your agent needs to be accessible at these endpoints:
| Endpoint | Method | Purpose              |
| `/`      | POST   | Main SWML document   |
| `/swaig` | POST   | SWAIG function calls |
## Security Considerations
* Always use HTTPS for production
* Enable basic auth for SWML endpoints
* Use secure tokens for SWAIG functions
* Don't expose sensitive data in prompts
* Monitor for unusual call patterns
Let's start with setting up your SignalWire account.
## Create Account
1. Go to [signalwire.com](https://signalwire.com)
2. Click [Sign Up](https://id.signalwire.com/onboarding) or [Login](https://id.signalwire.com/login/session/new)
3. Complete registration with email and password
4. Verify your email address
<Note>
  If you have problems verifying your account, email [support@signalwire.com](mailto:support@signalwire.com)
</Note>
## Create a Project
After logging in:
1. Navigate to Projects in the dashboard
2. Click "Create New Project"
3. Enter a project name (e.g., "Voice Agents")
4. Select your use case
## Space Name
Your Space Name is your unique SignalWire identifier.
**URL Format:** `https://YOUR-SPACE-NAME.signalwire.com`
**Example:** `https://mycompany.signalwire.com`
**You'll need this for:**
* API authentication
* Dashboard access
* SWML webhook configuration
## API Credentials
Get your API credentials from the project:
1. Go to [API Credentials](https://my.signalwire.com/?page=/credentials)
2. Note your Project ID
3. Create an API Token if needed
| Credential | Format                                       |
| Project ID | `xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx`       |
| API Token  | `PTxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx` |
| Space Name | `your-space`                                 |
<Warning>
  Keep these secure -- don't commit to version control!
</Warning>
## Environment Variables
Set these for your agent. These environment variables are used by all SDK languages:
```bash
export SIGNALWIRE_PROJECT_ID="your-project-id"
export SIGNALWIRE_API_TOKEN="your-api-token"
export SIGNALWIRE_SPACE="your-space.signalwire.com"
## Dashboard Overview
| Section                                                             | Purpose                              |
| **[Phone Numbers](https://my.signalwire.com/?page=/phone_numbers)** | Purchase and manage phone numbers    |
| **[SWML](https://my.signalwire.com/?page=/resources/scripts)**      | Configure SWML scripts and webhooks  |
| **[Logs](https://my.signalwire.com/?page=/logs/voices)**            | View call history and debugging info |
| **[API Credentials](https://my.signalwire.com/?page=/credentials)** | Credentials and API explorer         |
| **[Billing](https://my.signalwire.com/?page=/payment_methods)**     | Account balance and usage            |
## Add Credit
Before making calls:
1. Go to [Billing](https://my.signalwire.com/?page=/payment_methods)
2. Add payment method
3. Add credit to your account
Trial accounts may have limited credit for testing.
## Account Verification
Some features require account verification:
* Phone number purchases
* Outbound calling
* Certain number types
Complete verification in Account Settings if prompted.
## Next Steps
With your account ready:
1. [Purchase a phone number](https://my.signalwire.com/?page=/phone_numbers)
2. Deploy your agent
3. Connect the number to your agent
