# Skills
> Skills are modular, reusable capabilities that add functions, prompts, and integrations to your agents without custom code.
[understanding-skills]: /docs/server-sdks/guides/understanding-skills
[built-in-skills]: /docs/server-sdks/guides/builtin-skills
[adding-skills]: /docs/server-sdks/guides/adding-skills
[custom-skills]: /docs/server-sdks/guides/custom
[skill-configuration]: /docs/server-sdks/guides/skill-config
[ref-skillbase]: /docs/server-sdks/reference/python/agents/skill-base
## What You'll Learn
This chapter covers the skills system:
1. **Understanding Skills** - What skills are and how they work
2. **Built-in Skills** - Pre-built skills available in the SDK
3. **Adding Skills** - How to add skills to your agents
4. **Custom Skills** - Creating your own skills
5. **Skill Configuration** - Parameters and advanced options
## What Are Skills?
Skills are pre-packaged capabilities that add:
* **Functions** - SWAIG tools the AI can call
* **Prompts** - Instructions for how to use the skill
* **Hints** - Speech recognition keywords
* **Global Data** - Variables available throughout the call
| Without Skills         | With Skills                  |
| Write weather function | `agent.add_skill("weather")` |
| Add API integration    |                              |
| Write prompts          | Done!                        |
| Add speech hints       |                              |
| Handle errors          |                              |
The `add_skill()` method is available across all SDK languages:
| Language   | Syntax                                      |
| Python     | `agent.add_skill("weather")`                |
| TypeScript | `await agent.addSkillByName('weather_api')` |
## Quick Start
Add a skill in one line:
#### Python
class MyAgent(AgentBase):
        # Add datetime capability
        self.add_skill("datetime")
        # Add math capability
        self.add_skill("math")
        self.prompt_add_section(
            "Role",
            "You are a helpful assistant that can tell time and do math."
#### TypeScript
```typescript
import { AgentBase, DateTimeSkill, MathSkill } from '@signalwire/sdk';
const agent = new AgentBase({ name: 'my-agent' });
agent.addLanguage({ name: 'English', code: 'en-US', voice: 'rime.spore' });
// Add datetime capability
await agent.addSkill(new DateTimeSkill());
// Add math capability
await agent.addSkill(new MathSkill());
agent.promptAddSection('Role', {
  body: 'You are a helpful assistant that can tell time and do math.',
await agent.run();
## Available Built-in Skills
| Skill                   | Description                              |
| `datetime`              | Get current date and time                |
| `math`                  | Perform calculations                     |
| `web_search`            | Search the web (requires API key)        |
| `wikipedia_search`      | Search Wikipedia                         |
| `weather_api`           | Get weather information                  |
| `joke`                  | Tell jokes                               |
| `play_background_file`  | Play audio files                         |
| `swml_transfer`         | Transfer calls to SWML endpoints         |
| `datasphere`            | Search DataSphere documents              |
| `native_vector_search`  | Local vector search                      |
| `mcp_gateway`           | Connect to MCP server tools              |
| `google_maps`           | Address validation and routing           |
| `info_gatherer`         | Structured question collection           |
| `claude_skills`         | Load SKILL.md files as tools             |
| `api_ninjas_trivia`     | Trivia questions from API Ninjas         |
| `ask_claude`            | Anthropic Claude reasoning / sub-queries |
| `custom_skills`         | Register one-off SWAIG tools from config |
| `datasphere_serverless` | DataSphere search via serverless DataMap |
| `spider`                | Web scraping and crawling                |
## Chapter Contents
| Section                                      | Description                      |
| [Understanding Skills][understanding-skills] | How skills work internally       |
| [Built-in Skills][built-in-skills]           | Reference for included skills    |
| [Adding Skills][adding-skills]               | How to use skills in your agents |
| [Custom Skills][custom-skills]               | Creating your own skills         |
| [Skill Configuration][skill-configuration]   | Parameters and advanced options  |
## Skills vs Functions
| Aspect            | SWAIG Function  | Skill                                |
| **Scope**         | Single function | Multiple functions + prompts + hints |
| **Reusability**   | Per-agent       | Across all agents                    |
| **Setup**         | `define_tool()` | `add_skill()`                        |
| **Customization** | Full control    | Parameters only                      |
| **Maintenance**   | You maintain    | SDK maintains                        |
The `add_skill()` vs `define_tool()` distinction applies across all languages:
| Language   | add\_skill                           | define\_tool             |
| Python     | `agent.add_skill("name")`            | `agent.define_tool(...)` |
| TypeScript | `await agent.addSkillByName('name')` | `agent.defineTool(...)`  |
## When to Use Skills
### Use Built-in Skills When:
* Standard capability needed (datetime, search, etc.)
* Want quick setup without custom code
* Need tested, maintained functionality
### Create Custom Skills When:
* Reusing capability across multiple agents
* Want to share functionality with team/community
* Packaging complex integrations
### Use SWAIG Functions When:
* One-off custom logic
* Agent-specific business rules
* Need full control over implementation
## Complete Example
#### Python
#!/usr/bin/env python3
# assistant_agent.py - Agent with multiple skills
class AssistantAgent(AgentBase):
        super().__init__(name="assistant")
        # Add multiple skills
            "Role",
            "You are a helpful assistant named Alex."
            "Capabilities",
            body="You can help with:",
            bullets=[
                "Telling the current date and time",
                "Performing math calculations"
    agent = AssistantAgent()
#### TypeScript
```typescript
const agent = new AgentBase({ name: 'assistant' });
// Add multiple skills
agent.promptAddSection('Role', { body: 'You are a helpful assistant named Alex.' });
agent.promptAddSection('Capabilities', {
  body: 'You can help with:',
  bullets: [
    'Telling the current date and time',
    'Performing math calculations',
await agent.run();
Let's start by understanding how skills work internally.
## Skill Architecture
```mermaid
flowchart TD
    add["Agent calls add_skill()"] --> lookup["SkillRegistry looks up the class<br />in loaded skills, built-ins, then external paths"]
    lookup --> instantiate["SkillManager creates the skill<br />with agent reference and configuration"]
    instantiate --> setup["setup() validates packages and environment,<br />then initializes APIs or connections"]
    setup --> register["register_tools() adds SWAIG functions"]
    register --> apply["Apply prompts, speech hints, and global data"]
### SkillBase (Abstract Base Class)
**Required Methods:**
* `setup()` - Initialize the skill
* `register_tools()` - Register SWAIG functions
**Optional Methods:**
* `get_hints()` - Speech recognition hints
* `get_global_data()` - Session data
* `get_prompt_sections()` - Prompt additions
* `cleanup()` - Resource cleanup
### SkillRegistry (Discovery & Loading)
* Discovers skills from directories
* Loads skills on-demand (lazy loading)
* Validates requirements (packages, env vars)
* Supports external skill paths
## How Skills Work
Skills are a convenience layer built on top of SWAIG functions. When you add a skill, it registers one or more SWAIG functions with the agent, adds relevant prompts, and configures hints -- all from a single `add_skill()` call.
Understanding this helps when debugging: a skill's function behaves exactly like a SWAIG function you'd define yourself. The only difference is that the skill packages everything together.
## Skill Directory Structure
Built-in skills live in the SDK:
```text
signalwire/
    skills/
        datetime/
            __init__.py
            skill.py
        math/
            __init__.py
            skill.py
        web_search/
            __init__.py
            skill.py
            requirements.txt
Each skill directory contains:
| File               | Purpose                     |
| `skill.py`         | Skill class implementation  |
| `__init__.py`      | Python package marker       |
| `requirements.txt` | Optional extra dependencies |
## SkillBase Class
All skills inherit from [`SkillBase`][ref-skillbase]. The pattern is similar across all SDK languages:
| Language   | Pattern        |
| Python     | `class MySkill(SkillBase): def setup(self, agent): ...`                  |
| TypeScript | `class MySkill extends SkillBase { async setup() { ... return true; } }` |
from signalwire.skills import SkillBase
    # Required class attributes
    SKILL_NAME = "my_skill"
    SKILL_DESCRIPTION = "Does something useful"
    SKILL_VERSION = "1.0.0"
    # Optional requirements
    REQUIRED_PACKAGES = []      # Python packages needed
    REQUIRED_ENV_VARS = []      # Environment variables needed
    # Multi-instance support
    SUPPORTS_MULTIPLE_INSTANCES = False
    def setup(self) -> bool:
        """Initialize the skill. Return True if successful."""
        return True
    def register_tools(self) -> None:
        """Register SWAIG tools with the agent."""
        self.define_tool(
            name="my_function",
            description="Does something",
            parameters={},
            handler=self.my_handler
        """Handle function calls."""
        return FunctionResult("Result")
## Skill Lifecycle
```text
Discover -> Load -> Setup -> Register -> Active -> Cleanup
| Stage        | Description                                             |
| **Discover** | Registry finds skill class in directory                 |
| **Load**     | Skill class is imported and validated                   |
| **Setup**    | `setup()` validates requirements, initializes resources |
| **Register** | `register_tools()` adds functions to agent              |
| **Active**   | Skill is ready, functions can be called                 |
| **Cleanup**  | `cleanup()` releases resources on shutdown              |
## Skill Contributions
Skills can contribute to the agent in multiple ways:
### 1. Tools (Functions)
    self.define_tool(
        name="get_time",
        description="Get current time",
        parameters={
            "timezone": {
                "type": "string",
                "description": "Timezone name"
        handler=self.get_time_handler
### 2. Prompt Sections
def get_prompt_sections(self):
    return [
            "title": "Time Information",
            "body": "You can tell users the current time.",
            "bullets": [
                "Use get_time for time queries",
                "Support multiple timezones"
### 3. Speech Hints
def get_hints(self):
    return ["time", "date", "clock", "timezone"]
### 4. Global Data
def get_global_data(self):
    return {
        "datetime_enabled": True,
        "default_timezone": "UTC"
## Skill Discovery Paths
Skills are discovered from multiple locations in priority order:
| Priority | Source                                | Example                                                        |
| 1        | Already registered skills (in memory) | -                                                              |
| 2        | Entry points (pip installed packages) | `entry_points={'signalwire.skills': ['my_skill = pkg:Skill']}` |
| 3        | Built-in skills directory             | `signalwire/skills/`                                           |
| 4        | External paths                        | `skill_registry.add_skill_directory('/opt/custom_skills')`     |
| 5        | Environment variable paths            | `SIGNALWIRE_SKILL_PATHS=/path1:/path2`                         |
## Lazy Loading
Skills are loaded on-demand to minimize startup time:
# Skill NOT loaded yet
agent = MyAgent()
# Skill loaded when first referenced
agent.add_skill("datetime")  # datetime skill loaded here
# Already loaded, reused
agent.add_skill("datetime")  # Uses cached class
## Multi-Instance Skills
Some skills support multiple instances with different configurations:
    SUPPORTS_MULTIPLE_INSTANCES = True
    def get_instance_key(self) -> str:
        # Unique key for this instance
        tool_name = self.params.get('tool_name', self.SKILL_NAME)
        return f"{self.SKILL_NAME}_{tool_name}"
Usage across languages:
| Language   | Adding multiple instances        |
| Python     | `agent.add_skill("web_search", {"tool_name": "search_news", "api_key": "KEY"})`          |
| TypeScript | `await agent.addSkillByName('web_search', { tool_name: 'search_news', api_key: 'KEY' })` |
# Add two instances with different configs
    "search_engine_id": "NEWS_ENGINE_ID",
    "api_key": "KEY"
    "tool_name": "search_docs",
    "search_engine_id": "DOCS_ENGINE_ID",
    "api_key": "KEY"
## Parameter Passing
Parameters flow through skills in a structured way:
**At add\_skill() time:**
self.add_skill("web_search", {
    "api_key": "your-key",
    "tool_name": "custom_search",
    "max_results": 5
The skill receives these in `self.params` during setup:
    self.api_key = self.params.get("api_key")
    self.max_results = self.params.get("max_results", 3)
    return True
**At function call time:**
The AI calls the function with arguments:
def search_handler(self, args, raw_data):
    query = args.get("query")  # From AI's function call
    max_results = self.max_results  # From skill config
## Result Handling
Skill handlers return `FunctionResult` just like regular SWAIG functions:
    # Success case
    return FunctionResult("The result is 42")
    # With actions
    return (
        FunctionResult("Updated your preferences")
        .update_global_data({"preference": "value"})
    # Error case - still return a result for the AI
    return FunctionResult("I couldn't complete that request. Please try again.")
The result goes back to the AI, which uses it to formulate a response to the user.
## Error Handling and Propagation
Skills should handle errors gracefully and return meaningful messages:
def api_handler(self, args, raw_data):
    try:
        result = self.call_external_api(args)
        return FunctionResult(f"Result: {result}")
    except requests.Timeout:
            "The service is taking too long to respond. Please try again."
    except requests.RequestException as e:
        self.agent.log.error(f"API error: {e}")
            "I'm having trouble connecting to the service right now."
    except Exception as e:
        self.agent.log.error(f"Unexpected error: {e}")
            "Something went wrong. Please try again."
**Error handling principles:**
* Always return a `FunctionResult`, even on errors
* Make error messages user-friendly (the AI will relay them)
* Log technical details for debugging
* Don't expose internal errors to users
## Debugging Skills
When skills don't work as expected:
**1. Check if the skill loaded:**
# In your agent
print(f"Skills loaded: {list(self._skill_manager._skills.keys())}")
**2. Verify functions are registered:**
```bash
swaig-test your_agent.py --dump-swml | grep -A 5 "functions"
**3. Test the function directly:**
```bash
swaig-test your_agent.py --exec skill_function_name --param "value"
**4. Check for missing requirements:**
Skills log warnings if required packages or environment variables are missing. Check your logs during agent startup.
**5. Look at skill source:**
Built-in skills are in the SDK source. Examine them to understand how they work:
```bash
pip show signalwire
# Find location, then look in signalwire/skills/
