title: Skill Configuration
description: Configure skills with parameters, environment variables, and SWAIG field overrides.
slug: /guides/skill-config
max-toc-depth: 3
### Configuration Methods
| Method                | Description                            |
| Parameters dict       | Pass config when calling `add_skill()` |
| Environment variables | Set via OS environment                 |
| SWAIG fields          | Customize tool metadata                |
| External directories  | Register custom skill paths            |
### Parameter Dictionary
Pass configuration when adding a skill:
| Language   | Passing config parameters                                            |
| Python     | `self.add_skill("web_search", {"api_key": "...", "num_results": 5})` |
| TypeScript | `agent.addSkill('web_search', { apiKey: '...', numResults: 5 })`     |
    "api_key": "your-api-key",
    "search_engine_id": "your-engine-id",
    "num_results": 5,
    "min_quality_score": 0.4
### Parameter Schema
Skills define their parameters via `get_parameter_schema()`:
    "api_key": {
        "type": "string",
        "description": "Google API key",
        "required": True,
        "hidden": True,
        "env_var": "GOOGLE_API_KEY"
    "num_results": {
        "type": "integer",
        "description": "Number of results",
        "default": 3,
        "min": 1,
        "max": 10
    "style": {
        "type": "string",
        "description": "Output style",
        "enum": ["brief", "detailed"],
        "default": "brief"
### Parameter Properties
| Property      | Type   | Description                                                |
| `type`        | string | Data type: string, integer, number, boolean, object, array |
| `description` | string | Human-readable description                                 |
| `default`     | any    | Default value if not provided                              |
| `required`    | bool   | Whether parameter is required                              |
| `hidden`      | bool   | Hide in UIs (for secrets)                                  |
| `env_var`     | string | Environment variable source                                |
| `enum`        | array  | Allowed values                                             |
| `min`/`max`   | number | Value range for numbers                                    |
### Environment Variables
Skills can read from environment variables:
import os
## Set environment variable
os.environ["GOOGLE_API_KEY"] = "your-key"
## Skill reads from params or falls back to env
    "api_key": os.getenv("GOOGLE_API_KEY"),
    "search_engine_id": os.getenv("SEARCH_ENGINE_ID")
### SWAIG Fields
Override SWAIG function metadata for skill tools:
| Language   | SWAIG fields override                                              |
| Python     | `self.add_skill("datetime", {"swaig_fields": {"fillers": {...}}})` |
| TypeScript | `agent.addSkill('datetime', { swaigFields: { fillers: {...} } })`  |
    "swaig_fields": {
        # Add filler phrases while function executes
        "fillers": {
            "en-US": [
                "Let me check the time...",
                "One moment..."
        # Disable security for testing
        "secure": False
Available SWAIG fields:
| Field         | Description                      |
| `fillers`     | Language-specific filler phrases |
| `secure`      | Enable/disable token validation  |
| `webhook_url` | Override webhook URL             |
### External Skill Directories
Register custom skill directories:
from signalwire.skills.registry import skill_registry
## Add directory at runtime
skill_registry.add_skill_directory("/opt/custom_skills")
## Environment variable (colon-separated paths)
## SIGNALWIRE_SKILL_PATHS=/path1:/path2:/path3
### Entry Points
Install skills via pip packages:
## In setup.py
setup(
    name="my-skills-package",
    entry_points={
        "signalwire.skills": [
            "weather = my_package.skills:WeatherSkill",
            "stock = my_package.skills:StockSkill"
### Listing Available Skills
## List all available skills
skills = skill_registry.list_skills()
for skill in skills:
    print(f"{skill['name']}: {skill['description']}")
## Get complete schema for all skills
schema = skill_registry.get_all_skills_schema()
print(schema)
### Multi-Instance Configuration
Skills supporting multiple instances need unique tool names:
| Language   | Multi-instance with unique tool\_name                                          |
| Python     | `self.add_skill("web_search", {"tool_name": "search_news", "api_key": "KEY"})` |
| TypeScript | `agent.addSkill('web_search', { toolName: 'search_news', apiKey: 'KEY' })`     |
## Instance 1: News search
    "tool_name": "search_news",      # Unique function name
    "api_key": "KEY",
    "search_engine_id": "NEWS_ENGINE"
## Instance 2: Documentation search
    "tool_name": "search_docs",      # Different function name
    "api_key": "KEY",
    "search_engine_id": "DOCS_ENGINE"
### Configuration Validation
<Frame caption="Validation Flow">
  <img class="diagram" src="https://files.buildwithfern.com/signalwire.docs.buildwithfern.com/docs/7df552e5a79cb1c755e0936a9c87d5a35d4ea0ecc9c253d93046b525b666c1f8/assets/images/sdks/diagrams/05_05_skill-config_diagram1.webp" alt="Skill configuration validation flow diagram." />
</Frame>
### Complete Configuration Example
import os
## Register external skills
skill_registry.add_skill_directory("/opt/my_company/skills")
class ConfiguredAgent(AgentBase):
        super().__init__(name="configured-agent")
        # Simple skill - no config
        self.add_skill("datetime")
        # Skill with parameters
            "search_engine_id": os.getenv("SEARCH_ENGINE_ID"),
            "num_results": 5,
        # Skill with SWAIG field overrides
        self.add_skill("math", {
            "swaig_fields": {
                "fillers": {
                    "en-US": ["Calculating..."]
        # Multi-instance skill
        self.add_skill("native_vector_search", {
            "tool_name": "search_products",
            "index_path": "/data/products.swsearch"
            "tool_name": "search_faqs",
            "index_path": "/data/faqs.swsearch"
        self.prompt_add_section(
            "Role",
            "You are a customer service agent."
    agent = ConfiguredAgent()
### Configuration Best Practices
#### Security
* Store API keys in environment variables
* Never commit secrets to version control
* Use hidden: true for sensitive parameters
#### Organization
* Group related configuration
* Use descriptive tool\_name for multi-instance
* Document required configuration
#### Validation
* Check has\_skill() before using conditionally
* Handle ValueError from add\_skill()
* Validate parameters early in setup()
### Next Steps
You've learned the complete skills system. Next, explore advanced topics like contexts, workflows, and state management.
