> This page is for Server SDKs.
# Search and Knowledge
> Add RAG-style knowledge search to your agents using local vector indexes or PostgreSQL with pgvector, built with the sw-search CLI.
Knowledge search transforms your agent from a general-purpose assistant into a domain expert. By connecting your agent to documents -- FAQs, product manuals, policies, API docs -- it can answer questions based on your actual content rather than general knowledge.
This is called RAG (Retrieval-Augmented Generation): when asked a question, the agent first retrieves relevant documents, then uses them to generate an accurate response. The result is more accurate, verifiable answers grounded in your authoritative sources.
### When to Use Knowledge Search
**Good use cases:**
* Customer support with FAQ/knowledge base
* Product information lookup
* Policy and procedure questions
* API documentation assistant
* Internal knowledge management
* Training and onboarding assistants
**Not ideal for:**
* Real-time data (use APIs instead)
* Transactional operations (use SWAIG functions)
* Content that changes very frequently
* Highly personalized information (use database lookups)
### Search System Overview
**Build Time:**
```text
Documents -> sw-search CLI -> .swsearch file (SQLite + vectors)
**Runtime:**
```text
Agent -> native_vector_search skill -> SearchEngine -> Results
**Backends:**
| Backend  | Description                                            |
| SQLite   | `.swsearch` files - Local, portable, no infrastructure |
| pgvector | PostgreSQL extension for production deployments        |
| Remote   | Network mode for centralized search servers            |
```mermaid
flowchart TD
    question["User asks: What is the return policy?"] --> tool["AI calls search_documents()<br />with query: return policy"]
    tool --> engine["SearchEngine performs vector similarity,<br />keyword matching, metadata filtering,<br />and result ranking"]
    engine --> results["Return top matching document excerpts"]
    results --> answer["AI synthesizes an answer from the results"]
### Building Search Indexes
Use the `sw-search` CLI to create search indexes:
```bash
## Basic usage - index a directory
sw-search ./docs --output knowledge.swsearch
## Multiple directories
sw-search ./docs ./examples --file-types md,txt,py
## Specific files
sw-search README.md ./docs/guide.md
## Mixed sources
sw-search ./docs README.md ./examples --file-types md,txt
### Chunking Strategies
| Strategy    | Best For          | Parameters                           |
| `sentence`  | General text      | `--max-sentences-per-chunk 5`        |
| `paragraph` | Structured docs   | (default)                            |
| `sliding`   | Dense text        | `--chunk-size 100 --overlap-size 20` |
| `page`      | PDFs              | (uses page boundaries)               |
| `markdown`  | Documentation     | (header-aware, code detection)       |
| `semantic`  | Topic clustering  | `--semantic-threshold 0.6`           |
| `topic`     | Long documents    | `--topic-threshold 0.2`              |
| `qa`        | Q\&A applications | (optimized for questions)            |
#### Markdown Chunking (Recommended for Docs)
```bash
sw-search ./docs \
  --chunking-strategy markdown \
  --file-types md \
  --output docs.swsearch
This strategy:
* Chunks at header boundaries
* Detects code blocks and extracts language
* Adds "code" tags to chunks containing code
* Preserves section hierarchy in metadata
#### Sentence Chunking
```bash
sw-search ./docs \
  --chunking-strategy sentence \
  --max-sentences-per-chunk 10 \
### Installing Search Dependencies
```bash
## Query-only (smallest footprint)
pip install "signalwire-sdk[search-queryonly]"
## Build indexes + vector search
pip install "signalwire-sdk[search]"
## Full features (PDF, DOCX processing)
pip install "signalwire-sdk[search-full]"
## All features including NLP
pip install "signalwire-sdk[search-all]"
## PostgreSQL pgvector support
pip install "signalwire-sdk[pgvector]"
### Using Search in Agents
Add the `native_vector_search` skill to enable search:
| Language   | Syntax        |
| Python     | `self.add_skill("native_vector_search", index_file="./knowledge.swsearch", count=5, tool_name="search_documents")`                    |
| TypeScript | `await agent.addSkillByName('native_vector_search', { index_file: './knowledge.swsearch', count: 5, tool_name: 'search_documents' })` |
class KnowledgeAgent(AgentBase):
        super().__init__(name="knowledge-agent")
        self.prompt_add_section(
            "Role",
            "You are a helpful assistant with access to company documentation. "
            "Use the search_documents function to find relevant information."
        # Add search skill with local index
        self.add_skill(
            count=5,  # Number of results
            tool_name="search_documents",
            tool_description="Search the company documentation"
    agent = KnowledgeAgent()
### Skill Configuration Options
self.add_skill(
    # Index source (choose one)
    index_file="./knowledge.swsearch",       # Local SQLite index
    # OR
    # remote_url="http://search-server:8001", # Remote search server
    # index_name="default",
    # Search parameters
    count=5,                    # Results to return (1-20)
    similarity_threshold=0.0,     # Min score (0.0-1.0)
    tags=["docs", "api"],       # Filter by tags
    # Tool configuration
    tool_name="search_knowledge",
    tool_description="Search the knowledge base for information"
### pgvector Backend
For production deployments, use PostgreSQL with pgvector:
#### Python
self.add_skill(
    backend="pgvector",
    connection_string="postgresql://user:pass@localhost/db",
    collection_name="knowledge_base",
    count=5,
    tool_name="search_docs"
#### TypeScript
```typescript
  backend: 'pgvector',
  connection_string: 'postgresql://user:pass@localhost/db',
  collection_name: 'knowledge_base',
  count: 5,
  tool_name: 'search_docs',
### CLI Commands
#### Build Index
```bash
## Basic build
## With specific file types
sw-search ./docs --file-types md,txt,rst --output knowledge.swsearch
## With chunking strategy
sw-search ./docs --chunking-strategy markdown --output knowledge.swsearch
## With tags
sw-search ./docs --tags documentation,api --output knowledge.swsearch
#### Validate Index
```bash
sw-search validate knowledge.swsearch
#### Search Index
```bash
sw-search search knowledge.swsearch "how do I configure auth"
### Complete Example
#!/usr/bin/env python3
## documentation_agent.py - Agent that searches documentation
class DocumentationAgent(AgentBase):
    """Agent that searches documentation to answer questions"""
        super().__init__(name="docs-agent")
            "Role",
            "You are a documentation assistant. When users ask questions, "
            "search the documentation to find accurate answers. Always cite "
            "the source document when providing information."
            "Instructions",
            1. When asked a question, use search_docs to find relevant information
            2. Review the search results carefully
            3. Synthesize an answer from the results
            4. Mention which document the information came from
            5. If nothing relevant is found, say so honestly
        # Add a simple search function for demonstration
        # In production, use native_vector_search skill with a .swsearch index:
        # self.add_skill("native_vector_search", index_file="./docs.swsearch")
        self.define_tool(
            name="search_docs",
            description="Search the documentation for information",
            parameters={
                "type": "object",
                "properties": {
                    "query": {"type": "string", "description": "Search query"}
                "required": ["query"]
            handler=self.search_docs
    def search_docs(self, args, raw_data):
        """Stub search function for demonstration"""
        query = args.get("query", "")
        return FunctionResult(
            f"Search results for '{query}': This is a demonstration. "
            "In production, use native_vector_search skill with a .swsearch index file."
    agent = DocumentationAgent()
> **Note**
> This example uses a stub function for demonstration. In production, use the `native_vector_search` skill with a `.swsearch` index file built using `sw-search`.
### Multiple Knowledge Bases
Add multiple search instances for different topics:
## Product documentation
self.add_skill(
    index_file="./products.swsearch",
    tool_name="search_products",
    tool_description="Search product catalog and specifications"
## Support articles
self.add_skill(
    index_file="./support.swsearch",
    tool_name="search_support",
    tool_description="Search support articles and troubleshooting guides"
## API documentation
self.add_skill(
    index_file="./api-docs.swsearch",
    tool_name="search_api",
    tool_description="Search API reference documentation"
### Understanding Embeddings
Search works by converting text into numerical vectors (embeddings) that capture semantic meaning. Similar concepts have similar vectors, enabling "meaning-based" search rather than just keyword matching.
**How it works:**
1. **At index time**: Each document chunk is converted to a vector and stored
2. **At query time**: The search query is converted to a vector
3. **Matching**: Chunks with vectors closest to the query vector are returned
This means "return policy" will match documents about "refund process" or "merchandise exchange" even if they don't contain those exact words.
### Index Management
#### When to Rebuild Indexes
Rebuild your search index when:
* Source documents are added, removed, or significantly changed
* You change chunking strategy
* You want to add or modify tags
* Search quality degrades
#### Keeping Indexes Updated
For production systems, automate index rebuilding:
```bash
#!/bin/bash
# rebuild_index.sh - Run on document updates
sw-search ./docs \
  --output knowledge.swsearch.new
# Atomic replacement
mv knowledge.swsearch.new knowledge.swsearch
echo "Index rebuilt at $(date)"
#### Index Size and Performance
**Rough sizing:**
* 100 documents (\~50KB each) -- approximately 10-20MB index
* 1,000 documents -- approximately 100-200MB index
* 10,000+ documents -- Consider pgvector for better performance
### Query Optimization
#### Writing Good Prompts for Search
    "Search Instructions",
    When users ask questions:
    1. First search the documentation using search_docs
    2. Review all results before answering
    3. Cite which document your answer came from
    4. If results aren't relevant, try a different search query
    5. If no results help, acknowledge you couldn't find the answer
#### Tuning Search Parameters
**count**: Number of results to return
* `count=3`: Focused answers, faster response
* `count=5`: Good balance (default)
* `count=10`: More comprehensive, but may include less relevant results
**similarity_threshold**: Minimum relevance score (0.0 to 1.0) — higher is better.
* `0.0`: Return all results regardless of relevance
* `0.3`: Filter out clearly irrelevant results
* `0.5+`: Only high-confidence matches (may miss relevant content)
**tags**: Filter by document categories
self.add_skill(
    tags=["policies", "returns"],  # Only search these categories
    tool_name="search_policies"
### Troubleshooting
#### "No results found"
* Check that the index file exists and is readable
* Verify the query is meaningful (not too short or generic)
* Lower similarity_threshold if set too high
* Ensure documents were actually indexed (check with `sw-search validate`)
#### Poor result relevance
* Try different chunking strategies
* Increase count to see more results
* Review source documents for quality
* Consider adding tags to filter by category
#### Slow search performance
* For large indexes, use pgvector instead of SQLite
* Reduce count if you don't need many results
* Consider a remote search server for shared access
### Search Best Practices
#### Index Building
* Use markdown chunking for documentation
* Keep chunks reasonably sized (5-10 sentences)
* Add meaningful tags for filtering
* Rebuild indexes when source docs change
* Test search quality after building
* Version your indexes with your documentation
#### Agent Configuration
* Set count=3-5 for most use cases
* Use similarity_threshold to filter noise
* Give descriptive tool_name and tool_description
* Tell AI when/how to use search in the prompt
* Handle "no results" gracefully in your prompt
#### Production
* Use pgvector for high-volume deployments
* Consider remote search server for shared indexes
* Monitor search latency and result quality
* Automate index rebuilding when docs change
* Log search queries to understand user needs
